Can one install a Syncro II insert without the special tool from Campy??
Quoted: 1641 Post(s)
Liked 831 Times
I got a replacement insert for my Syncro II shutterbug I'm not ready to spend on the special installation tool fro m Campy cause the dang thing's quite expensive. Anyone here replace their inserts without the tool? How did I you do it??
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Quoted: 4412 Post(s)
Liked 1,567 Times
My shifter accidentally came apart once 30 years ago, and I believe I put it back together by having only one spring in, pushing the insert hard sideway into that spring and then inserting the other spring with needlenose pliers. But I could be wrong. You may also try using a small blade or shim to slide the insert over the spring after getting the other side started (both springs starting in place).
I recall that I couldn't do it on the side of the road (rode home on friction), but I got it back together without too much struggle at home. If a 17 year old could figure it out, you'll be fine.
Bianchi Goddess
Quoted: 2936 Post(s)
Liked 2,933 Times
Special tool? Do you have a link?
Sugar "Kane" Kowalczyk
Liked 831 Times
Here you go:
I often wonder if Campy comes up with these tools before or after they design their components.
Quite expensive out there and I think it's mostly made out of plastic (Delrin?)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Quoted: 4722 Post(s)
Liked 3,039 Times
^ +1. Like many other tools it facilitates the process but isn't mandatory. Invaluable in an Italian LBS setting, where the mechanic had one too many Cinzano at lunch.
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,099 Times
I’ve done it three or four times using a small flat tip screwdriver and a dip into my bag of expletives.
Liked 831 Times
I'll give it a shot without the tool this evening then.....
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Bikes: Caylor, Basso, Sannino, Colnago, Masi
Quoted: 38 Post(s)
Bikes: 2007 Nagasawa with C-Record, 1992 Duell with Croce D'aune/Chorus, three Gazelles, M5 recumbent
Quoted: 47 Post(s)
Liked 25 Times
I also did it several times without the tool.
I didn't even knew there was a tool until a few years ago.
sailorbenjamin
Classic & Vintage
61
10-07-15 04:55 PM
pumabicycle
Bicycle Mechanics
36
04-27-14 07:20 PM
