Is “drip” wax a gateway drug to real wax?
Quoted: 1279 Post(s)
Liked 1,393 Times
mods, please delete. posted twice trying to fix title.
Liked 1,393 Times
is “drip” wax a gateway drug to real wax?
switched to one of those overpriced drip wax “lubricants.” I’m amazed how much cleaner everything is after a hundred miles or so. sounds/feels a tiny bit smoother too, although I doubt it’s the 5 watts (or whatever) I was promised.
is this a sign that I’d like immersion wax even more, or am I getting most of the benefits without most of the hassle?
Likes For mschwett:
Likes For znomit:
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
Liked 8,927 Times
Liked 8,927 Times
Likes For datlas:
Liked 8,927 Times
Liked 8,927 Times
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times
I don’t know. I moved to one of the drip based waxes (Squirt) about a year and a half ago. I’ve been riding off and on since I was a kid and I remember people waxing their chains in the ‘80’s but it never interested me. I took note and started wading my way through one of the recent waxing threads and although I find it interesting I still don’t see myself as adopting the practice.
i live in the heat of palm desert with temps regularly well over 100 and I’ve noticed that my wax based lube doesn’t exactly solidify during the summer so I would assume that if I did immersive wax in a garage that is regularly above 100 that I may end up with a bit more mess.
either way, so far I’m pretty happy with the performance and cleanliness of the drip wax.
Forum Moderator
Quoted: 3091 Post(s)
Liked 6,601 Times
merged duplicate threads
Likes For cb400bill:
Quoted: 3241 Post(s)
Liked 2,512 Times
If you have a "drip," depends will be helpful.
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,533 Times
Going drip I guess is somewhat of a gateway in that it gets you used to doing the OMS/Alcohol baths for stripping new chains of factory grease.
I like speed
No, actually put me off waxing. I tried Squirt and had to replace the chain after 2000 miles.
I honestly don't want to pull or swap the chain every other week to wax it.
Liked 1,393 Times
I started using squirt and I guess you could say it was a gateway to hot wax since I started doing that. For a while. I eventually got tired of having to pull the chain off every hundred miles or so. I slowly started migrating back to squirt and honestly, for my conditions, I think its better than hot wax. For one thing, If I'm in a hurry I can apply it in thirty seconds. It actually seems to go longer intervals before it starts making noise. I attribute this to it being a more liquid product, I think it can kind of flow back into where it needs to go, instead of just getting squished out. My use is some paved roads, gravel roads, and mostly dusty mountain bike trails. I rarely ride in the wet.
Quoted: 6196 Post(s)
Liked 4,810 Times
I've been using them for a handful of years and I have not succumbed to waxing my chain. If you'll check back on me later to see if I've gone over to the other side and need an intervention and/or re-hab, I'd appreciate it!.
Liked 1,393 Times
i touched my chain today and didn’t feel dirty and guilty afterwards ! pretty chuffed.
Likes For mschwett:
Quoted: 7652 Post(s)
Liked 3,478 Times
I get several hundred miles off a good wax but I don't crank out the big watts like you guys .... not sure if that makes a difference. But it is hard to fault wax-based drips for convenience.
Likes For Maelochs:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
Don't go all Breaking Bad with the OMS. Submerge chain in OMS in a clean pasta sauce jar. Shake vigorously for 30 seconds. Leave on top of laundry machine while washing a load.
Liked 1,471 Times
Once I have gone through the trouble of cleaning the chain, immersion waxing is actually easier than applying any lubricant roller by roller.
