Opinions on Campy Shamal Ultra wheels?
slow on any terrain
Hi, all. I'm considering these for a new build . . . what has your experience been? Many thanks!
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,001 Times
They are not as pretty as the original Shamals but I know people like them and with Campy wheels I believe they are all still handmade which is nice. Maybe more specifics might help if there is certain things you are looking for.
Quoted: 1821 Post(s)
Liked 1,696 Times
I have been riding the 2way fit version of these wheels for about 10 years. They came to me with tubeless valves already installed and I have been riding them tubeless since day 1. Great wheels, the only trouble I have ever had was having to replace the rear rim after hitting a huge pothole at high speed. The rim was dented, but the tire didn't flat. The impact was so hard that my water bottle was ejected, but I didn't crash.
I've been riding Campy Eurus and Zonda wheels for 10 years. Great performing and reliable wheels, and the Zonda's are a great value. Is it worth the hundreds of extra $ to get the Shamals? For me, no.
In terms of peace of mind, I'd rather have steel spokes, and the ceramic bearings have value I suppose if you never maintain your hubs. But the 100 grams of lower weight is about the only benefit of the Shamals.
Quoted: 800 Post(s)
Liked 512 Times
I put the 2way fit version of these wheels on my bike something like 12 years ago, maybe longer, and was an early adopter of tubeless back when Hutchinson was the ONLY tyre manufacturer out there. Oh how times have changed.
Anyway. These wheels were bomber! I smoked some major potholes and they remained true. Never had any issues with them and the only reason I moved away from the 2way fit wheels is b/c I bought a new bike and I wanted deep dish carbon wheels. Where it not for that, I'd still be rocking these wheels.
Thread Killer
Quoted: 3151 Post(s)
Liked 1,715 Times
Has Campy updated these, specifically in terms of internal width, or are they still 17mm? I always thought C17 was too little, too late when it came out in ‘16, and it’s far too little today. They don’t look aero at all, either, are quite shallow, and don’t support SRAM XDR freehub. I otherwise like the design and features, but they never made the cut for me.
Campy makes great wheels, but the rims are still narrow, but that's what you would expect with the tire size limitations imposed by most rim brake frames. I'd be inclined to spend less on Zondas for a rim brake build.
I moved on to disc frames, wider rims and wider tubeless tires at lower pressure about 2-1/2 years ago. There's a big improvement in ride when you do that.
Le Crocodile
Quoted: 370 Post(s)
Liked 787 Times
I run Vittoria 28's on my set, and it works great. The rims are "narrow" by today's standards. Mine are still 100% true, in fact, they have the least runout (in any direction) than any other wheelset that I have (15+).
Thread Killer
Liked 1,715 Times
I am happy with the 25s, however, and not particularly fussed about needing wider tires, at least not to the point of replacing the bike to the tune of several thousands of dollars in order to get them. My point being, even if tire clearance is frame limited to 25mm, having the extra volume in the rim width goes a long way in terms of handling and comfort, making it worthwhile to look beyond 17mm IW Campagnolo wheelsets,
My experience with the front wheel only - The new Ultra, while not as pretty or as aero looking as my old 2000 era Shamal, it somehow feels faster. Maybe because it is a lot lighter. When I first got it (great deal on EBAY from Chicken over in the UK), I was a bit disappointed. But the Ultra is more stiff and confidence inspiring for this Clydesdale. Even after rebuilding the old Shamal (the hub split open a couple months ago)... My average speeds are about the same but it just "feels" faster. I run Vittoria 25s on both.
Reviews around the web are almost always VERY positive.
