Do any of you actually use DELTA brakes??
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1084 Post(s)
Liked 1,821 Times
Yes, many words have been written about their design, and how they are heavy and not even aero.
We see them sell for $400+ on eBay all day.
And, they are in MOMA's permanant collection of industrial design of the last century.
I keep finding sets. generation 4 and 5 which fixed (??) the modulation or lack of issues.
So, do any of you actually ride with them? Do they work nicely? Do you trust them to do their job?
Thanks.
Thanks.
"Leave the gun. Take the Colnagos."
Edumacator
Quoted: 2440 Post(s)
Liked 3,133 Times
Not to stop with I imagine...more to reflect the sunlight.
Likes For jdawginsc:
Quoted: 175 Post(s)
Liked 452 Times
If the OP is referring to Campagnolo, they're going on 4 decades of controversial brakes. Legendary.
(Ps. Yes, use a third gen version Camp. Delta. They don't fair well with rain and dust getting into the insides. More tedious to setup, though work fine. Love the aesthetic.) (Pss. Also have Weinmann Delta type 531. Lighter in weight, simple, avg. in setting up yet still takes more attention. Once set, no fuss. Maybe I'm more lucky than others, but they work superior.)
Likes For chain_whipped:
Quoted: 2326 Post(s)
Liked 4,993 Times
Mine work just fine.
Steel is real...and comfy.
Making up the numbers
Quoted: 107 Post(s)
Liked 502 Times
I trained and raced on five-pivot Deltas in the late 1980s and had no concerns whatsoever. I largely used them with 22mm wide Omega Strada XL clincher and Sigma Strada tubular rims which I think work better than the narrower 19-20mm rims of the era.
I’d use them again in a flash if I could find a similar late-generation set in rider quality at well under USD400-
If I did I’d ditch old, dry and hard original black pads for new Kool Stops or somesuch…
Nothing quite says wall hanger like drillium toe straps
Likes For seagrade:
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 670 Post(s)
Liked 977 Times
Quoted: 3464 Post(s)
Liked 2,831 Times
When they arrived I did consider them interesting.
a definite different aesthetic.
maybe more at home on a Carbon fiber framed bike.
they went against my view of simple and straightforward.
the later Monoplaners - subordinate group were more interesting.
the dual pivots were a better answer a few years later for power and modulation
then they went all hidden pivot fasteners.
too fancy in assembly.
Quoted: 331 Post(s)
Liked 332 Times
Delta and AX lunacy.
As someone else mentioned they don't like the rain. Perhaps Kool pads would help but Delta pads are unique to the design
Funnily enough the Dura Ace AX (the direct competitor of Campy's Delta gruupo) also don't like the rain.
Legend has it the two manufacturers got together and agreed they'd both go broke if the continued with so much extra machining of parts and both groupsets were discontinued.
Sunbeam did a very similar brake caliper in the 1930s! They don't like the rain needless to say, nor the dry either but hey-ho.
Liked 2,831 Times
The Shimano AX dura-ace brake was a number of years before the Campagnolo Delta.
not really a direct competitor.
Shimano had evolved to the 7400 side pull brake- probably the direct step beyond of the Record Brake- plastic spring glides on the arms, slight ratchet feel to the eccentric quick release- same basic wheel guides- equal in finish.
I think even had the toothed washer to help hold the centering adjustment.
the Campagnolo patents had run out basically.
the good ideas were free.
Likes For repechage:
Bikes: Masi Gran Crit, Bianchi Campione D' Italia 84, Eddy Merckx Corsa Extra, Ibis Ripley, Co Motion Tandem, Merlin Agilis, Ritchey Breakaway, Bianchi Infinito CV, Colnago Master
Quoted: 68 Post(s)
Liked 129 Times
Thanks.
Thanks.
I have a pair on my Masi GC, and while occasionally the squeal, they work fine. They are finicky, heavy, overengineered and a great conversation piece. If it is all about performance, look elsewhere - monoplaners are better. But as a period piece, they are great.
Likes For Thalia949:
Quoted: 331 Post(s)
Liked 332 Times
As pointed out above the Record 'Delta' came out when the AX was ending. I didn't like cutting the brake lever cable so close to the retaining nut on the Delta brakes. I couldn't figure out a way to avoid this without the cable end scraping on the tire. I will have to check but I believe the AX has more room.
The rear derailleur on the AX is genuinely weird whereas the Delta derailleur has lots of seemingly unnecessary metal fairings - nothing wrong with that,bit like a 59 Cadillac but I don't think it particularly aero.The bare wired AX was supposed to be more aero than a outer/inner cable arrangement but the mind boggles.
I did see you can buy Kool Stop pads, they will definitely help the poor stopping performance of both calipers.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
No. They're so bling, I wear mine around my neck when I go clubbin'.
Quoted: 331 Post(s)
Liked 332 Times
Around your neck.
One problem in the UK is you daren't leave a bike with a Record groupset anywhere unsighted , as it wouldn't be there when you got back to it.
Quoted: 331 Post(s)
Liked 332 Times
Around your neck.
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,837 Times
Currently only running one of my sets.
Not the Weinmann set.
Quoted: 1627 Post(s)
Liked 630 Times
I had a bike with a pair of Deltas.
They sure looked cool.
Quoted: 12 Post(s)
Liked 8 Times
Used mine for 3 weeks in the Alps this summer and they got me home safely on a ride over to the water last evening. The modulation is a little different under heaving braking at that took a little getting used to on long descents the first day, but that's a bit like riding a bike with different geometry. Within a few minutes you tend to adapt.
Likes For JSL:
Quoted: 1641 Post(s)
Liked 831 Times
I'm running 3rd gen Deltas on my Montello. Braking performance is nothing to rave about. I rate them as just acceptable. I think people are dissapointed because they expect a large improvement from the expensive price and then tech forward design of the calipers.
I also run Weinmann Deltas on my ALAN Carbonio. They brake just about as good as the Campy Deltas in, but I think they can be easily improved with better/bigger brake pads, as the stock brake pads are so small.
Both brakesets would not be my choice for long fast descents down mountains. I would trust my Monoplanars more for that type of riding.
Bikes: Yes, probably too many but still have a roving eye...
Quoted: 317 Post(s)
Liked 2,807 Times
I've got a fancy pantographed set on my Somec, I've got Kool Stop pads in mine which were a big improvement on the stock ones but still perform not quite as good as the later double pivot Campag brakes. They work fine though and are works of sculpture as much as they are brakes. As mentioned cabling and set up is fiddly and you'll need a 3.5mm hex key to tighten the cable, and there's no 3.5mm hex keys on any multi tool I've ever seen so you'll need to find one of them.
Likes For botty kayer:
Liked 1,821 Times
Still so much controversy. Shimano vs Kitchenaide vs Amana vs Doc Johnson.
3.5 allen wrench. Who's great idea was that??
Sounds like some of you ride with them. Fiddly set up and all.
I thank you for your responses.
Quoted: 569 Post(s)
Liked 587 Times
Likes For easyupbug:
Quoted: 331 Post(s)
Liked 332 Times
AX and Delta
My 1984 Holdsworth 'Italia'.
Below the front cover lurks many problems.
I like to have a pig's tail on the end of my cables and unlike the Delta the AX allows that, whereas the Delta is a SOB. Surprisingly the big axles on the pedals for the AX is the only discernible improvement I find for the both the Campag and Shimano groupsets. Makes you wonder why they stuck with the traditional 5/8".
Likes For Johno59:
