Buying a bike repair stand question(s)
Bikes: Pedego Stretch 2016 (electric cargo bike for around town and grocery shopping, Small surly Ogre (2015), Bianchi Advantage (46cm) 1993, Bike Friday NWT, 2005
Quoted: 126 Post(s)
Liked 44 Times
Up until now, I have not had a bike repair stand. I just take my bike in for regular maintenance (which I will still do), but I've wished for a bike repair stand for awhile so I can more easily change tires or even line up a tire more easily.
Right now (and for the foreseeable future), if we want to ride our bikes, we need to haul them in in old Honda Fit. We can fit 2-3 bikes in the car if we take off the front wheel. The problem with this is getting the front wheel all centered up properly every time we do this. Maybe having a bike repair stand I can throw in the car will make that easier to center? (or is that silly?)
I figure I would also use this repair stand for cleaning the chain. It has to be easier than trying to do it while the bike is on the ground. I'm also thinking of getting the super heavy duty one because I have an electric cargo bike. The Pro Mechanic HD by FeedbackSports is the one I'm thinking of getting.
As you can figure out - I'm mostly an end user bike rider. I know how too change a tire, but that's about it.
Quoted: 1563 Post(s)
Liked 1,737 Times
I don't understand your problem. Is this a quick release front wheel? Just get the axle all the way into the drop out. There is no need to play around with anything. Put the wheel on the ground and put the fork over the wheel axle and gravity will center the axle in the drop outs.
Likes For icemilkcoffee:
Clark W. Griswold
Quoted: 4367 Post(s)
Liked 4,007 Times
That stand is rated for 70lbs max just keep that in mind. The electric moped looks like it could be quite a bit heavier (though removing the battery might help get it in the 70lbs range) and you will need to lift it by hand the Prepstand E-Up Pro from Topeak helps lift the bike up a little, it is not perfect but it makes it way easier than lifting by hand. It is going to be a bit more expensive but having used it, it is worth it.
Likes For veganbikes:
Quoted: 2339 Post(s)
Liked 2,831 Times
for learning about maintenance here is a great site https://www.parktool.com/en-us/blog/...saAuJQEALw_wcB
for books
https://www.amazon.com/Zinn-Art-Road...zcF9hdGY&psc=1
https://www.amazon.com/Park-Tool-Blu...s%2C153&sr=8-3
on repair stands, I recommend spending some money, I got a park brand a while back and it has been the single best bike repair purchase I have made. it is similar to below Edit: noted e cargo bike...as noted make sure you get a stand that can handle that weight
https://www.amazon.com/Park-Tool-Uni...1zcF9hdGY&th=1
other people are sure to pop up with some lower priced options
for books
Likes For squirtdad:
Quoted: 126 Post(s)
Liked 44 Times
Quoted: 126 Post(s)
Liked 44 Times
I'm with Squirtdad on this. In fact I posted what turned into a whole thread on this about how dumb I had been for decades, yes probably your whole life! in not getting one.
On the practical side, if maintenance is easier, maybe it will become more frequent, "Fixing deferred is fixing denied" as they say
Likes For Pratt:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
I have a big $ Feedback pro elite and a cheap ALDI one . Is the Feedback better? Without a doubt. But the cheap one is more than adequate for regular maintenance tasks
Quoted: 126 Post(s)
Liked 44 Times
for books
for books
If you're near a bike co-op, you can probably get hands-on guidance there. I read books on maintenance when I started out, but a guy at the U Michigan bike co-op actually showed me how to rebuild a hub, for example.
Likes For philbob57:
Quoted: 126 Post(s)
Liked 44 Times
There are a couple co-ops near me, but not so close that it won't take some planning. I think a book WITH some hands on help would be best, but for now I probably have to settle for a book.
Quoted: 126 Post(s)
Liked 44 Times
for books
crid=3JU2Q08JNXZQ3&dib=eyJ2IjoiMSJ9.EHUSyO3YnVNf0CnOU5lQTrgX6AoG4Je5tGUzl_9_WFNTBb4U5h6i11vOmdPMBdm9 3xtfwRkQB95RZkQ-BwTsMR8UoUvdYZovX3TK1HwxMSHGP1nljNS1IIAQRaJOwpGXWINKXGr3wrBvX6k3SYqC4PSwahD4E4x6vbWftju48lQte2OYlqM5 dzbFTD8NgJ85GXlFRM6tqehQN1A_DcLEp5pexrbNhBCB8QxtwGu0xsMxYQ27H503AgcbOV0jqGybuVvSRy7ZiK3lGGM4wOIxCu-c-C8bKpJ6t7JO7xUlAc8.p9qetmC3CRiNAK9jwovs3BPraTT4qriFzA8goaiIpVc&dib_tag=se&keywords=bicycle%2Brepair% 2Bstand&qid=1710009897&refinements=p_85%3A2470955011&rnid=119653280011&rps=1&s=sporting-goods&sprefix=bicycle%2Brepair%2Bstand%2Caps%2C147&sr=1-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
for books
Also wondering if a Kindle version would be more or less practical?
Love the idea of a workstand. Have you thought about taking a basic maintenance class?
Sometimes there's no substitute for having someone knowledgeable demonstrate a task in person, and you being able to replicate that task on the spot.
Nothing against internet videos, but there are nuances in personal interactions you just don't get in videos.
Quoted: 126 Post(s)
Liked 44 Times
I literally typed in a search online, "coop bicycle shops near me". I haven't been to them, but I found their sites and locations and all info about them. I live in the DC/Bmore area and I found some... and I know some shops have classes too while not technically being a co-op.
Quoted: 3515 Post(s)
Liked 2,929 Times
SE Wis
Liked 3,401 Times
https://www.bikecollectives.org/wiki..._Organizations
https://www.thebikehouse.org/
https://gearinupbicycles.org/
https://velocitycoop.org/
Velocipede Bike Project
Quoted: 126 Post(s)
Liked 44 Times
Liked 1,737 Times
Last year my son's disc bike started rubbing. And the old bike I was using was also really fiddly to get it to drop out properly. That bike is now on the trainer and a non issue, but it was not simple. Plus, I always felt like the tire was going to fall out by how lose we had to keep it. It never did, but it was super fiddly.
Quoted: 6975 Post(s)
Liked 10,975 Times
Quoted: 2497 Post(s)
Liked 741 Times
I have like the next up from the most basic of Park Tool repair stands. My DW was stuck for a Christmas present for me and it must have slipped her mind that I already had a good repair stand. She got this stand for me. She is a good shopper. Does research. Reads reviews. The proof though, when I put this thing side by side with my big blue tried and true, there isn't much not to like. Since four of my bikes are tandems and I've never found a good way to get a standard repair stand to hold a tandem, I plan to use both of them, one at each end! As for the o.p., I think I've found them a bike stand. FWIW
Quoted: 366 Post(s)
Liked 275 Times
There are tons of bike repair tasks where a repair stand is handy, but putting a wheel on is something you can do on the side of the road pretty easily using gravity. A stand does make chain cleaning a little easier, but not all that much.
I have a cheap-o under $100 bike stand. It works. It folds up. It holds my bike. While it does go to standing height, I am lazy and often work sitting on the floor with my tires only an inch off the ground. Makes it easier to grab tools and parts as well. My bike is not a cargo bike or an e-bike, however.
If I was you, I would have a hard time stomaching the price of the stand you mentioned. You would have to use that stand a lot of times to justify the purchase price. However, that's what they say about e-bikes - everything is more expensive.
Quoted: 626 Post(s)
Liked 401 Times
Koyote Posted: Sure, but it's got to be bolted to the floor.
Quoted: 1944 Post(s)
Liked 2,165 Times
I have a Feedback Ultralight which is not something I’d recommend. I’ve had it for about 10 years and use it constantly. I have built a few bikes on it, as well as maintenance. It has been a great stand for me.
My Ultralight was originally sold as a 75lb stand. It is currently advertised as “optimized” for 35lbs or less, with a max load of 75lbs. I have serious doubts on the 75lbs as I need to brace the stand with the bike wheels when torquing a BB to keep it from tipping.
I have serious concerns about an aluminum repair stand with that much weight. Not so much holding, but having it not tip. It all comes down to the leg length and mass. If the tripod does not form a large enough diameter, or heavy enough base, it might be a difficult balancing act at 60+lbs.
John
John
