Hub went from loud to silent
I have a set of Fulcrum S3 wheels. I got them from someone who had never ridden them. You could look at them and tell they were still brand new.
I put them on the hub was pretty loud. I rode 34 miles yesterday and by the time I got home the hub was almost completely silent.
I don’t really care if they are loud or silent or whatever. My concern is that something is wrong with them. Everything seems to be okay with them. They ride fine. They engage fine. Is this anything to worry about?
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
These use cup and cone bearings, right? Could be that the cones are (were) too tight.
What do I look for to tell what kind of bearings they have?
The dropped
Liked 1,014 Times
From Sheldon Brown's page about cup and cone adjustment.
You can read here about cup and cone, as cartridge bearings are install and forget until replacement.
Likes For Unca_Sam:
Thanks. So would that cause the change in sound? And I guess I should specify the sound I’m talking about is the hub body spinning on the hub when coasting.
The dropped
Liked 1,014 Times
No, it wouldn't cause the change. Thanks for being more specific. If your freehub became quieter, it's probably because you finally distributed all the lubricant along the pawls inside.
SE Wis
Quoted: 2731 Post(s)
Liked 3,361 Times
Old lube got warmed up and moved around, rough edges got worn away. Broke in.
Likes For dedhed:
Ahh. That would make sense. Thanks. So I assume since all is working fine it’s nothing to worry about?
Likes For dsbrantjr:
Dangerous Old Man
Likes For bldegle2:
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
This sounds good but can sometimes be misguided advice.
Besides working on bikes and cars, my responsibility at work is to keep our machines running efficiently. When I know something is wrong and will lead to failure or poor performance, I correct it. I don't wait until it is no longer running.
This is not a comment on the OP's situation, just the quoted advice in general.
Likes For AlmostTrick:
Quoted: 850 Post(s)
Liked 344 Times
If you have this kind of freehub mechanism, 1) it’s incredibly easy to remove, disassemble, inspect, etc.
2) there is very little scope for issues as long as coasting drag is not excessive and you have no skipping under power.
I agree that it is very odd that yours went silent (I assume you mean quieter... this mechanism should not be truly silent). Usually pawl mechanisms get louder as they shake off excess lube.
Bikes: 87 Raleigh 531C Team Replica, 96 Litespeed Classic, 01 Lemond Tete-De-Course, 99 Mongoose RX10.9, 03 Lemond Wayzata, 00 Litespeed Appalachian, 99 Bianchi XL Boron, 98 Litespeed Tuscany
Quoted: 35 Post(s)
Liked 51 Times
My Campagnolo Shamal freehub had a pleasant, but not loud click when coasting. One day after I came back home from my ride, I suddenly noticed that the freehub was eerily and almost completley quiet when I put my bike back into the garage. I pulled the cassette, then removed the freehub to inspect it. I found that my pawl spring was broken, and my freehub was barely working with one pawl hanging onto the last springy bit of the broken pawl spring. If I had ridden much further on it, it probably would have broken completely and left me stranded on the road somewhere. So, please get yours checked out for your own piece of mind.
Quoted: 850 Post(s)
Liked 344 Times
