I'm sorry...some modern drivetrains are stupid
Quoted: 3359 Post(s)
Liked 3,638 Times
Many modern downhill mountain bikes are going to 7 speed rear cassettes but with narrower 11 speed cog spacing. Accomplishing the same thing you are describing. But disc brakes, and not 135mm spacing. But your reasoning is sound, at least according to people wanting to sell new DH bikes
Available up to 150/157mm "OLD"
As far as hub spacing, I believe things are mostly getting wider in the dropouts in order to help the chainstays swallow wider tires. AFAIK there really isn't much difference in freehub width between 8 speed and 12 speed. The trend towards wider tires is also driving the popularity of 1X systems since the wide chainstays and tires limit maximum chainring size. That's also why the a few new freehub standards have been invented, so that you can fit a smaller 9 or 10 tooth cog to make up for the limited chainring size.
Quoted: 1949 Post(s)
Liked 2,010 Times
I don't have any pictures but some folks take beautiful vintage race bikes, spread the rear drop outs to 130, put on a chromium plated 11-34, a derailleur with a 3X long cage, a triple crankset, and then the cockpit is crazy tall like monkey bars.....
At least that bike up there is orange and born that way.
Likes For Classtime:
Quoted: 964 Post(s)
Liked 1,451 Times
That Valentine, BTW, was designed by Ettore Sotsass, and came with a beautiful case as well:
I still have 5 or so typewriters, mainly ones I really like or can't possibly sell.
My very first computer was also an Olivetti. An M15 laptop with a detachable keyboard and two 3.5" floppy disk drives:
OK, back to American bikes.
Quoted: 3241 Post(s)
Liked 2,512 Times
Yeah, derailleurs that work exceptionally well but aren't pretty are stupid. Holds the chain on in rough terrain? Stupid. Allows for the gear range of a traditional triple with just one chainring, shifter and derailleur? Stupid. Automatically swings out of the way instead of breaking when hit? Stupid.
Modern drivetrains aren't fragile. Mine have proven to be more durable than older designs from the 80's and 90's. Stupid, eh? Also, when I'm riding, they look just as good as old-school derailleurs - 'cause I'm not looking at them.
Quoted: 3464 Post(s)
Liked 2,829 Times
Liked 2,829 Times
Quoted: 4806 Post(s)
Liked 3,928 Times
A truss built to the same stiffness and strength as a cantilever (all typical forks) can be built far lighter. I've had a chance to pick up TiCycles bikes built for off road with truss forks. The front ends weigh nothing. Engineers use cantilevers when they are the only feasible choice or weight and materials used isn't an issue. (The fork isn't the only weight savings. The steerer has almost no structural function and needs only be strong enough to handle the torque loads from the handlebars. (TiCycles has taken the design a step further. The front of the truss ties to the stem at the handlebars. Stem now is also no longer a cantilever. Now headtube can also be lighter since the rider load is transferred directly to the axle through the truss.)
Ben
Ben
Liked 3,928 Times
Because of liability issues, they will only do that surgery for the track crowd. Issue is with threaded cranks. As of now, the pin at the "foot" needs to be threaded into the crank. In a crash a rider will NOT release from that crank. Lawsuits will happen. But the track crowd have been doing bolt-in fastening, double toestraps, toestraps over clipless, etc. for years to prevent accidental un-cleats fixed at speed. Locked in for a crash? That's life. They wouldn't even think about suing.
Liked 2,512 Times
Quoted: 1361 Post(s)
Liked 423 Times
Not stupid drivetrain. Rather serves double use as a wood shaper for balsa core, cloth resin wrapped frame- future DIY bike making when the World has its power shut down.
Not that I was advocating for single-ring drivetrains over triples for everyone buuuuut: Put a modern derailleur on that triple and you'd get a quieter drivetrain and eliminate dropped chains.
Liked 2,512 Times
I run friction barcons for the same reason. On an all day ride, it reduces the amount of physical shifting I have to do when I need to change gears. To be fair, I am never in enough of a hurry to worry about missing shifts.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Jones Bikes makes titanium truss forks kind of like that, because titanium is so flexible it needs the extra triangulation. If that Olivetti fork is steel - I can't imagine why they'd make a truss fork out of steel.
I'm not really a mountain biker, though I ride off road. No judgments, just wondering.
Quoted: 529 Post(s)
Liked 255 Times
I'm also wondering about these super low gears. What is a 32/50 useful for? That'd be about an 18.5" gear on a 29er. I haven't ridden a gear that low since tricycles... Seems like that's low enough that staying upright would take some effort. I can only imagine it's for getting traction on very very short very steep little hills and bluffs with lots of mud. Or is it for trials type stuff?
Randomhead
Liked 3,698 Times
1X got popular when there was a trend towards super-short chain stays. That made a front derailleur a pain. Now that there is at least some movement away from super-short chainstays, MTB are still stuck with 1X
Likes For RobbieTunes:
Liked 3,638 Times
Does it help with chain suck?
Likes For abshipp:
Liked 3,638 Times
Aside from what I’ve covered already the Main things are the clutch and the gear range. The chain can’t fall off (mostly) and no chainsuck either, particularly with a narrow wide chainring. Although chainsuck hasn’t hasn’t been a problem for the last ten years plus anyway.
Ditching the front d is a big plus for mountain biking. Fewer gears to keep track of, room for a dropper post lever on the bars and no issues with chain suck and botched front shifts. Less bashing chain rings as well.
The gearing is, well, personal preference. With a wide range 12-speed you can get over a 500% difference which allows for low gears for super steep and tech climbs while leaving good gearing for hauling ass out to the trails on the road. Simple for the manufacturers as well as one setup can accommodate everyone.
Personally, I have an 11-42 10-speed with an oval 32 up front (niner wheels) and it’s excellent for Vancouver Island technical mountain biking, particularly when you’re grinding up a super steep fire road or technical single track or you already have a couple hours of hard riding in your legs. Next cog stack will go to 45, I don’t want a 50. It’s hard to stay up going that slow, but it can save you from walking on super tech, super steep climbs and when you’re blown during long rides and also let you sit and spin so you have something in the tank for later. And a LOT of mountain Bikin is about it being “hard to stay up” for various reasons.
When climbing super-steep gravel roads, if you need to stop, it's often a good idea to shift to a gear a few steps higher than what you were riding at. It means you'll need to push with a lot of torque to get rolling again, but you're less likely to have to fight rear wheel slippage, or running out of downstroke on first pedal stroke.
Like with low gears in general, super-low gears like 32-50 are mostly about not bottoming out your gearing. Sometimes it's also about being able to accelerate: bikes get jostled around more easily at lower speeds, so when you've got a rough patch on a steep climb, sometimes the easiest solution is to power through it with a brief speed burst.
Likes For HTupolev:
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
(Link)
Likes For JaccoW:
Quoted: 3810 Post(s)
Liked 6,699 Times
Yeah, we should all be running Campy NR derailleurs with their cracked pulleys and narrow range, just like Eddie did!
Yeah, 1 x 11 is just stoopid.
Likes For nlerner:
