Removing Powder Coating
Bikes: Indeed!
Quoted: 1507 Post(s)
Liked 3,469 Times
I didn't have much success with paint stripper. I ended up using a 4" angle grinder with a wire wheel. A lot of work and I still had to do a lot of sanding and scraping by hand in those hard-to-reach spots. I too hope someone has a better solution.
Brent
Brent
Likes For Kilroy1988:
Bikes: ‘84 Alan sprint, Rocky Mountain Altitude 799, Trek fuel ex 9.9, Gardin/Battaglin’84, Nishiki international ‘83, ‘86 panasonic dx5000, 93 mongoose amplifier
Quoted: 14 Post(s)
Liked 30 Times
Acetone will remove powder coat, I found this out the hard way. Though you would need a lot to strip an entire frame.
B.
B.
Quoted: 887 Post(s)
Liked 335 Times
Powder coat is really tough stuff. I have no advice, but good luck.
Quoted: 702 Post(s)
Liked 672 Times
Quoted: 887 Post(s)
Liked 335 Times
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
"Just the frame" considering how hard stripping paint can be this may be a lifetime quest.
Sugar "Kane" Kowalczyk
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,795 Times
In a perfect world I'd want a nice catalyzed wet paint job on all my bikes, but you're talking something like 3x the cost. There are enough good powder coaters that know how to do bikes properly nowadays that unless you pick a crappy one, you'll probably be just fine.
Likes For gugie:
Liked 5,795 Times
Back to the OP, I know of 2 powder coaters that can send a frame out for chemical strip. I think cost was around $40
Likes For gugie:
Bikes: I have a few
Quoted: 340 Post(s)
Liked 210 Times
I've heard this arguement before, and it doesn't make much sense to me. Who doesn't want a lifetime paint job? I don't know many people who plan to repaint. Perhaps somebody somewhere wants to repaint every few years as a fashion statement.
Wileyone it can be softened up with a blow torch and scraped off just don't go mental and over heat the pipe.
Quoted: 1858 Post(s)
Liked 606 Times
Liked 5,795 Times
Good point, sometimes I forget that we're in strange times.
Quoted: 1372 Post(s)
Liked 1,751 Times
Never really liked the idea of powder coated bikes, even though I had a drop dead gorgeous orange Marinoni that was done with pc. That said, have a look at this page. It might be a help.
I never finish anyth
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times
I removed powder coating from a steel frame, the only chemical I tried that worked was "aircraft stripper". No other remover even made a dent. It's fairly nasty stuff, and you will definitely want to use gloves and eye protection.
I bought it at ace hardware, and it was a gel so it would work on the round tube shapes. You put it on, and then wait. Add another coat and wait some more. Then you should be able to scrape it off. Once most of it is scraped off you can use a scotchbrite pad to get the nooks and crannies around lugs and where tubes are joined.
Having done it before, I don't envy you this task.
Dale, NL4T
Dale, NL4T
Liked 606 Times
Quoted: 294 Post(s)
Liked 137 Times
IIRC, "aircraft stripper is methyene chloride based.. toxic, corrosive to skin, carcinogen, etc. may not be available where you live depending on the regulations. It is gel based and works well (looking like that orange frame pictured)
