View Poll Results: What should I do?
Upgrade groupset
3
100.00%
Get 2nd hand entry level 29er
0
0%
Put up with the gears
0
0%
Voters: 3. You may not vote on this poll
For bikepacking+commuting, is it worth upgrading my old 26" hardtail to 1x11?
Quoted: 9 Post(s)
Hey all,
I'm posting this in the touring forum as the primary function I want my bike to fulfill is to allow me to tour/bikepack with it. Please let me know if there's a more suitable location for it.
I'll try to be concise. I have an aluminum frame 26" Giant Rainier (an old entry level mtb with a frame known to be solid for its spec) that I currently use for everything - mainly urban commuting several days a week, but also backpacking into national parks on sandy and rocky fire trails (hence why I need a mountain bike). I can't afford anything but "budget" bikes. My Rainier has been great - the upgraded fork makes every bump easier and with a frame bag, top tube bag and front and rear racks it has handled the load of my camping gear adequately.
The main weakness has been the gears. Despite repeated trips to my local mechanic, adjustments and replacements, it's still pretty crummy at shifting into the correct gear when I need it to, and staying there (deore 3x9 for what it's worth). For me at least, this is a very frustrating experience. So I want to eliminate that problem.
I've found that you can get a nice shiny 1x11 groupset for around $400 (AUD), and seeing as this could be transferred to another bike if I get one down the line, I've got it in my mind that this is my best bet.
At first, my thought was to spend ~$600 on a second hand Talon or the like. But the forks would be a downgrade and I'm not actually sure the groupset would be any better (but happy to be proven wrong).
My budget is extremely limited (young casual paying exorbitant rent). Something like $600 would be the absolute maximum, and this would be my Christmas present to myself.
Hoping for some advice/affirmation
Cheers!
Cheers!
Quoted: 2604 Post(s)
Liked 1,931 Times
"Worth" is subjective. So I don't know the answer to your real question -- how bad do you want it?
I'd start by asking your shop mechanic to check the derailer hanger adjustment. If that doesn't fix your problems, perhaps find another shop with a different mechanic.
If that doesn't work, it's possible that there's something wrong with your system. But people have been riding Deore without problems for years and many, many miles.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 321 Times
A 1x is NOT a tour bike by any stretch of imagination. I have seen these with low 30s teeth on MUPs. They are using the highest gear on the flat. LOL. $400 is insane anyway.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Hey all,
Cheers!
Cheers!
The cable has to be tight enough but not too tight. Shift into the highest gear (usually the lowest cable tension) and see how much slack the cable has. It should have a little bit of “twang” to it but not guitar string tight. You shouldn’t be able to pull the cable away for the frame without applying some force to it. If the cable is too loose, it will take a double shift to make the derailer move and the derailer may not hold the gear.
Next, shift to the lowest gear (highest tension) then upshift without pedaling. This will relax tension on the cable and allow you to pull the housing out of the frame stops. The series of pictures below illustrate what I mean
Library - 3391 by Stuart Black, on Flickr
Library - 3392 by Stuart Black, on Flickr
Library - 3393 by Stuart Black, on Flickr
Library - 3394 by Stuart Black, on Flickr
Library - 3395 by Stuart Black, on Flickr
Once you have the cable out of the stops, grease the inner cable under the housing and inspect the ends for any displace rods in the housing. You may need to pull off the caps but sometimes you see rods poking out like this
IMG_1361 by Stuart Black, on Flickr
IMG_1362 by Stuart Black, on Flickr
If the cable housing looks like this, replace it.
You should also check the derailer hanger. The hanger should be straight so that the cogs on the cassette and the jockey wheels are in a straight line. You can just stand behind the bike and see if the jockey wheels line up. If they don’t, the hanger needs to be aligned.
And, finally, after you’ve checked for extraterrestrial influence, look at the limit screws. Hint: shifting problems are never ever limit screw problems. In fact, I’d say that extraterrestrial influence...both aliens and the astrological... is more likely to cause shifting problems than the limit screws. Put down that screw driver!
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 598 Post(s)
Liked 283 Times
Get a new mechanic or better yet, learn to make the repairs yourself. This would likely be your cheapest and imo, your best option.
No, I would not want a 1 chainring system for touring, for most riders, not enough of a gear range and/or further compromised by too large of steps in between.
Likes For robow:
what sort of replacements?
how old are the cables and housing?
are they quality, or cheapo generic stuff?
Quoted: 1034 Post(s)
Liked 1,290 Times
Hey all,
Cheers!
Cheers!
I sometimes think of converting my Long Haul Trucker to a 1x, then I come back to my senses after reliving past tours in my head.
Bikes: 2019 Trek Stash 7, 1994 Specialized Epic 1986 Diamondback Ascent 1996 Klein Pulse Comp, 2006 Specialized Sequoia Elite
Quoted: 418 Post(s)
Liked 523 Times
If you want to save money and simplify things, consider replacing your shifters with some quality vintage friction thumbshifters. (Some index thumbshifters also have the ability to switch to friction mode.)
They are super simple and are easy to adjust. They're also very easy to work on. Make sure the shifters can handle the spacing on your rear cassttte. (Most 8 speed friction thumbshifters will handle a 9 speed cassette.) You will have to replace your brake handles if you have the integrated type.
{Did your mechanic make sure your chain hasn't stretched too much? When your chain has stretched enough, it will slip on the cogs. Additionally, the teeth on you cogs may have worn to the point of needing replacement especially if you let your chain go too long...}
Quoted: 3459 Post(s)
Liked 1,465 Times
What is the shifting problem, front or rear or both?
If it is the front, try a friction shifer.
Several years ago I had some problems shifting and found that I had a lot of dust that had gotten inside my shifter cable housing. I do not recall if I managed to clean it out or if I replaced the cable housing, but that fixed that problem.
I have three bikes with a 3X8 drivetrain, there is no way you could talk me into a 1X system for touring, in touring you need a very wide range of gears. A 1X system does not have that wide a range.
All of my 3X8 bikes have a friction front shifter.
And the 1X11 components that will need replacement later cost a LOT of money when you wear them out. Your 3X9 system is much better for touring.
Likes For Tourist in MSN:
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
3x9 Deore is a very solid drive train. I don't know why you're having troubles with it, but if you can get it working correctly, I think it's a much better system for touring and commuting than 1x11. Make sure you can live with the reduced gear range before you switch to 1x11.
Likes For tyrion:
there is no reason why after checking the forementioned things, and replacing the housings and cables on your own, that things shouldnt be working perfectly.
and no reason to upgrade to a new 1x system, but you will have to learn some mechanic skills to do this on your own, and to buy some tools.
If you never clean your bike, the rd could be all gummed up, totally classic. Trigger shifters could also do with a spraying of internals to degunk.
you're not talking about a million year old 6 spd bike, this is 9 spd and you should be able to get this working properly--or a diff mechanic. But save the bucks and learn how to do it on your own is my suggestion.
Or dont, up to you.
It aint rocket science though.
Or dont, up to you.
Quoted: 9 Post(s)
Thanks for the feedback all! My idea of getting a new groupset has been ditched as it definitely doesn't sound like it's worth it - now to work on fixing my current one up.
Likes For Snufkin:
Hey all,
Cheers!
Cheers!
