Friction Shifting Brifters - Modify STI Brifter?
Bikes: Columbine, Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Quoted: 222 Post(s)
Liked 134 Times
Does (did) anyone make brifters with friction shifters? I'm restoring a vintage bike, and I'd like to avoid downtube shifters due to arthritis. I really want to avoid the hassle of finding a combination of STI brifters and derailleurs not that most new stuff is hydraulic discs.
I have other options for friction shifters, but a friction brifter would be best.
I'm open to modifying a standard brifter if this would work.
Cheers, Mike
Cheers, Mike
Quoted: 3323 Post(s)
Liked 2,164 Times
Why run as friction ?. Just find some e-bay 8-9 spd or something and use indexed with brifters ?
And to answer, I am pretty sure all brake shifter units were indexed. Shimano STI is plus 30 years old now as indexed, Campy was close behind.
Would bar-cons be better than downtube ?, you can run them friction.
I am potato.
Quoted: 1818 Post(s)
Liked 1,688 Times
Car dependency is a tax.
Likes For base2:
Quoted: 222 Post(s)
Liked 134 Times
Yeah, I could use bar end shifters. My prior tandem had them. I didn't like them on the tandem, so I'm looking for something else.
Cheers, Mike
Cheers, Mike
Quoted: 222 Post(s)
Liked 134 Times
Cheers, Mike
Cheers, Mike
Likes For PromptCritical:
Quoted: 1005 Post(s)
Liked 1,684 Times
What type bicycle?
What type bars?
Oh... And dont forget there is such a thing as Stem Shifters too.
For some people it can be hard to understand the things us arthritic riders have to adapt to...
What type bars?
Likes For zandoval:
Quoted: 222 Post(s)
Liked 134 Times
I thought about stem shifters, but they bring back bad memories about junior high school and Schwinn (lead pipe) Varsitys.
Cheers, Mike
Cheers, Mike
Quoted: 222 Post(s)
Liked 134 Times
That's a good point. I just ordered a pair of Gevenalle levers, so we'll see how they work.
Cheers, Mike
Cheers, Mike
Quoted: 1110 Post(s)
Liked 1,050 Times
A good modern choice. The old school levers you were looking for were called Modolo Morphos, they shifted everything from 5sp-9sp, shimano or campagnolo. Little chunky but they worked really well and I liked them at the time because the chunky meant you could really hand onto them.
Liked 2,164 Times
My question was if OP wanted something like brake/shifters, why not just run indexed brake shifters ?. Why use friction at all. Get a matchup set of F and R derailers and just use an indexed system.
Quoted: 4581 Post(s)
Liked 1,729 Times
Kelly Take Offs also allow the use of any downtube shifter:
I have a pair - they work well.
Then there's the ratchet shifting Ene Wing:
And then there are flat bar type shifter mounts that are the right size to work on drop bar tops.
Likes For Kontact:
For someone who has finger mobility issues, brifters or rapid fire type shifter would seem to be the best option since the lever 'returns' to the same position. Assuming a suitable position can be found which would work, it would limit the mobility needed. Friction shifters would seem to need more mobility range to work on most none downtube mounts.
Shimano's modern rapid fire shifters allow some adjustments on placement on the brake lever/mount.
Shimano shifters have quite a few option but the compatibility must be understood, something that the OP doesn't seem to be willing to learn.
Liked 1,729 Times
Likes For Kontact:
Quoted: 222 Post(s)
Liked 134 Times
I have a Campy rear derailleur on it, and am hoping it works. The frame is a little unusual. The B-screw doesn't line up well with the dropout, so I'm not sure what to do about that (I really don't want to weld on the frame). It has the shortest chain stays imaginable and really narrow. I put a 700c x 32 tire on my wheel and I couldn't get the wheel on. I deflated the tire and it went on, but when I re-inflated it, the tire hit both sides of the chainstays. Fortunately, I had a 700c x 25 tire lying around and it went back together.
I've thought about doing this again (picture of a Paul thumbie with a Campy lever I cobbled up on our tandem).
Cheers, Mike
Cheers, Mike
Quoted: 222 Post(s)
Liked 134 Times
Quoted: 222 Post(s)
Liked 134 Times
Those are cool! Unfortunately the Kelly Takeoffs are out of stock and the Ene Wings are a bit pricey, but I may go for them.
Cheers, Mike
Cheers, Mike
Quoted: 418 Post(s)
Liked 981 Times
Right now, the plan is a Shimano HG freehub wheel (Which I have. No idea how I got it). I'd prefer a 9-speed cassette as I have a bunch of those. I just installed a set of Shimano Ultegra STI shifters from a tandem (what I had while I wait for the Gevenalle levers to arrive), but they are seriously worn out. The previous owner of the tandem must have really enjoyed riding it!
Also a picture of the dropout may help folks help you figure out the b stop issue.
Liked 1,729 Times
I looked into the Gevenalle a couple of years ago to convert an MTB with 10sp Dynasys derailleurs to a drop bar to do a tour with it. They supposedly made them but were out of stock, and they were going to be expensive, more than the original setup. I ultimately bought SQ Labs bar inners, which give me a drop bar thumb hook position on the otherwise flat bar setup. I can shift and brake without moving my hands. This won't help the OP though since he already has drop bars.
Quoted: 1633 Post(s)
Liked 1,829 Times
The B screw notch has to be sorted out or else nothing will work. Is this a French frame with Simplex or Huret drop-outs?
Quoted: 1172 Post(s)
Liked 449 Times
PromptCritical - you say you have the Gevenalle integrated shifters on order. Just curious: did you order the "Audax" version that comes without the shift levers? If so, which friction levers were you thinking of using? Or did you get the ones that come complete with the Microshift levers re-branded as Gevenalle? Also, how many front chainrings and rear cogs are you running?
Quoted: 222 Post(s)
Liked 134 Times
Quoted: 222 Post(s)
Liked 134 Times
Cheers, Mike
Cheers, Mike
