Fender clearance question - SKS longboard 45
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
Last year I bought Schwalbe Marathon 32 tires, knowing they may be a tight fit underneath my velo-orange fenders with the shaped edges. It turned out to be to tight and I removed the fenders completely. Now i'm wondering if the plastic SKS longboard fenders are thin enough to free up enough room to squeeze everything in. It's a King of Mercia frame, so I was surprised that I had trouble installing these tires in the first place.
Quoted: 804 Post(s)
Liked 1,835 Times
Chances are you can squezz everything just barely with occational chater. SKS low profile fenderss are made for 28-30 max if the specs are correct on the tires. I have found some tires that are 30 run OK with the fenders while a lot of 28's are no gos.
Bikes: I hate bikes!
Quoted: 432 Post(s)
Liked 732 Times
I have founf the SKS Longboards fenders, in 45mm, fit where the VO fenders of the same width do not. The rolled edges of the VO fenders make them closer to 40mm inside to inside vs a true 45mm for the SKS. On the Ritchey touring bike I have ,I could not fit the VO fenders and a 30mm tire. The SKS Longboards fit fine.
Another thing to keep in mind is that while bit heavier, the SKS fender has the quick release front clip. I recently picked up a tree branch while riding one of my SKS fendered bikes on a trail. The fender popped loose and I was able to stop without incident. Popped the fender clips back in, no problems. Had it been a metal fender that was permanately attached, I think I might have crashed. YMMV.
Extraordinary Magnitude
Quoted: 2611 Post(s)
Liked 1,731 Times
I'm running 27 x 1 1/4 and the P45 SKS fenders. My only problem is fork crown and brake bridge clearance.
Commence to jigglin’ huh?!?!
Bikes: 1966 Carlton, 197X MKM, 1983 Trek 620, 1988 Schwinn High Sierra, 1995 DBR Axis Ti, 1999 Waterford, 2016 DBR Release, 2017 Surly Travelers Check
Quoted: 65 Post(s)
Liked 8 Times
I'm not sure how true-to-size the Schwalbe's run, but I've had no problems running 700cc Pasela 32mms under 45mm SKS longboards. The frame was built for 27" wheels, so YMMV.
