Question of mass & physics
Old 03-15-19, 06:14 PM
thehammerdog
thehammerdog's Avatar
Quoted: 722 Post(s)
Liked 353 Times in 226 Posts
Can using a larger volume tire like a 28 in anyway help with weight distribution on a wheelset with a rider weight limit?
can chubby use bigger tires inorder to ride his lightweight wheels ?
or is fat just fat and im to fat
thehammerdog is offline
Old 03-15-19, 06:19 PM
KLiNCK
Optically Corrected
KLiNCK's Avatar
Bikes: 2012 Specialized Sirrus , 2012 Specialized Roubaix Comp
Quoted: 106 Post(s)
Liked 67 Times in 30 Posts
Need more information...
What is the recommended maximum weight for the wheelset?
What is your weight?
What style/conditions do you ride in?
KLiNCK is offline
Old 03-15-19, 07:06 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4199 Post(s)
Liked 3,851 Times in 2,301 Posts
Wider tires generally weigh more then narrower ones (all other things the same) so, yes, "weight distribution" does change. It moves more to the outer part of the wheel where the wider tire is. But I don't think that is really what you ask about.
Wider tires will better protect any rim from impacts. They tend to smoothen out the ride by better absorbing shock. But the load the rim sees is still the same, so to for the spokes.
In my ideal world riders use tires that are size/grade/design agreeable with the rider's needs/expectations, independent of the rim/wheel . Of course both have to be compatible with each other.
Don't expect wider tires to extend wheel life of make a too fragile wheel survive an overloaded situation. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 03-15-19, 07:09 PM
thehammerdog
Quoted: 722 Post(s)
i go about 215 lbs got old school rolph wheels siestre 1600gms i think 200lb limit ride style smoove only paved roads no drama on the bike in question just had them trued steel frame bike
Old 03-15-19, 07:34 PM
Cyclist0108
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times in 1,164 Posts
I'd be worried about spoke count. Fatter tires will protect the rims more.
Cyclist0108 is offline
Old 03-15-19, 07:46 PM
davidad
Quoted: 582 Post(s)
Liked 171 Times in 138 Posts
No. For most of us light weight components are a waste of money. When we get down to 6% body fat then we can worry about component weight.
davidad is offline
Old 03-15-19, 08:29 PM
TimothyH
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times in 469 Posts
Having a wider tire or larger air volume will not increase maximum weight limit of the wheels.
-Tim-
TimothyH is offline
Old 03-15-19, 09:14 PM
AnkleWork
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times in 83 Posts
Answer of engineering
Free body analysis: The distance between axles will not change, thus the weight distribution will not change.
Force path analysis: The rider's weight must be borne by the axles, bearings, hub shells, spokes, and rims regardless of tires.
AnkleWork is offline
Old 03-15-19, 09:50 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1791 Post(s)
Liked 1,267 Times in 874 Posts
A fatter tire will reduce peak impacts when hitting curbs, pot holes etc.
IF you rims are rated for a 200 lb. rider, a 215 lb. rider on SMOOTH pavement shouldn't be an issue.
Bill Kapaun is offline
Old 03-16-19, 12:42 AM
CliffordK
CliffordK's Avatar
Quoted: 18372 Post(s)
Liked 4,507 Times in 3,350 Posts
A wider tire at lower pressure may well reduce shock (dynamic load/impact acceleration) on the components, which would be greater than the static load on the components.
Thus, there would be reason to believe that if one is very borderline, that it may tip one over the edge towards potentially being OK.
Also be careful with your riding. Watch the bumps.
But, as above, there might be benefits of building slightly stronger wheels.
CliffordK is online now
Old 03-16-19, 04:45 AM
thehammerdog
Quoted: 722 Post(s)
I am very impressed with the technical answers and as usual we have many others that vary. I think I will just diet some more as weight is weight and I do not want to die on the road as I squeeze into my lycra just to have wheel failure...
The uber lightness is alluring when compared to the Mavic Askiums
Old 03-16-19, 05:57 AM
Lemond1985
Sophomore Member
Lemond1985's Avatar
Quoted: 1628 Post(s)
Liked 1,057 Times in 631 Posts
No diet needed. Just go on long rides, and eat what you would normally eat, had you not ridden that day. This will create a caloric deficit, and the weight will drop off slowly and naturally.
That's how I did it anyway, your health situation and mileage may vary.
Lemond1985 is offline
Old 03-16-19, 08:58 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
23 to 28 is insignificant to this scheme of yours..
buy wheels with a greater spoke count... for a better sense of security..
fietsbob is offline
Old 03-16-19, 04:20 PM
ramzilla
ramzilla's Avatar
Quoted: 700 Post(s)
Liked 322 Times in 252 Posts
I'm a heavier 200+ lb rider myself. For reasons of safety I prefer larger tires. Larger tires = more rubber and, are generally more resistant to flats. It's one thing to get a flat tire when you're a 150 lb teenage boy. It's quite a different matter when you're a 220lb 63 year old man. One of my current favorite tires is the Michelin Pro-Tek series. They're a littler bigger than other bike tires. And, so far so good. No bad flats yet.
ramzilla is offline
Old 03-16-19, 09:23 PM
TimothyH
- Soli Deo Gloria -
Having gone from 200 lb to 165 lb last year, I would like to encourage you. The first 10 lb was noticeable when climbing.
Don't listen to too many people. You know what to do. Good luck and please post your progress.
-Tim-
TimothyH is offline
Old 03-17-19, 09:14 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6218 Post(s)
Liked 4,214 Times in 2,362 Posts
While there may be more rubber because of increased surface area of the tires, that doesn’t translate into more rubber to prevent flats. If you make an apples to apples comparison of tires (same brand and construction), a 23mm tire has the same thickness of rubber at the tread as a 35mm tire.
Additionally, a flat tire is just a flat tire. Weight of the rider makes no difference and age of the rider certainly doesn’t make any difference.
Stuart Black
cyccommute is offline
Old 03-17-19, 09:22 AM
cyccommute
cyccommute's Avatar
Your idea is a bit too simplistic. If you ride heavy in the saddle, a wider tire might help a little but only a little. If you ride light in the saddle, it won’t make a difference. It’s known as “ballerinas who ride like gorillas and gorillas who ride like ballerinas.” In other words, even a light rider who slams in potholes and road debris will damage wheels and bikes no matter how large the tires are. A heavy rider who unloads the bike by using their legs and arms as suspension can ride thin tires without worrying about damaging the bike or wheels.
Stuart Black
Old 03-17-19, 09:41 AM
wphamilton
wphamilton's Avatar
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times in 228 Posts
Looking at it purely from a "mass and physics" point of view for your specific question, as mentioned it's more mass at the circumference so yes the "distribution" changes in that regard. That will add some small amount of stress on the rear spokes and rim as you accelerate (I'd say insignificant compared to extant stresses). On the front wheel, a lesser effect on the wheel itself.
Regarding the increased tire volume, not mass. It will increase the duration of time where peak forces are applied to the wheel (decreasing impulse) so I believe that it DOES help the wheel withstand a greater rider weight. It that's enough to give the lightweight wheels greater longevity, that remains to be seen.
wphamilton is offline
Old 03-17-19, 12:23 PM
WizardOfBoz
Generally bewildered
WizardOfBoz's Avatar
Quoted: 1152 Post(s)
Liked 341 Times in 251 Posts
This. A heavier rider will put more stress on the rims and spokes than a light rider and a tire won't change that significantly. Fatter tires will reduce the effect of strong bumps, preventing the tire from bottoming out and damaging the rime (also, the impulse force wphamilton mentions could collapse the rim I think) in the road for any size rider but the stress of the bump will be added to the stress caused by weight. Further, we don't know the tire size used by the mfr in setting the weight limit. That limit may actually account for a wider tire for a heavier ride. So I fear you'll still exceed the wheels intended design limit. While there will be some safety factor in a manufacturer's stated limit, that limit does balance safety and likelihood of failure with the limiting sales by constraining the possible population of buyers. They don't put those limits on arbitrarily as a low limit also limits sales to some degree.
There's another issue. I weight 245#. I had a pair of Bontrager Race RLs on my bike. A good solid, strong, dependable pair of wheels with a good balance of stiffness and weight. I wanted to upgrade (lighter is better, right?) though, so I got a pair of Paradigm Elites off eBay. They were rated for my weight, but were lighter (and had lighter construction and fewer spokes). I went into my local Trek store, and Bill, a really experienced guy who was the mgr/head mechanic, told me "Given that you're a pretty big guy, I don't think you'll like the ride on those Elites as well as you like the RLs". Bill's usually right on bike issues (to a shocking degree*), and he was here. The Elites are great wheels, but for me the RLs work better. They're heavier with thicker spokes, so they tend not to flex as much. If only I could lose 40 lbs, those Elites would be sweet!
Upshot is that if a mfr suggests a weight limit, and you exceed it, there are two reasons you probably want to find a wheel that's a bit stouter: safety and performance. Your ride will be nicer and more efficient using wheels that match your avoirdupois. I found this to be true, anyway.
*I started working with bikes 45 years ago, and have a PhD in Engineering. So I think I know everything. Until I talk with Bill, who invariably throws out observations that indicate really deep knowledge, or a wrinkle I hadn't thought of. Humbling, but very helpful.
WizardOfBoz is offline
armybikerider
Road Cycling
10
05-17-19 10:31 AM
FattyBike...er
Bicycle Mechanics
18
03-21-19 02:53 PM
reissue59
Classic & Vintage
10
02-08-19 08:56 AM
mine57even
Bicycle Mechanics
2
07-14-15 07:56 PM
fiveredapples
Road Cycling
2
01-01-12 09:24 PM
