Ultimate Cargo Bike
#77
Bikes: This list got too long: several ‘bents, an urban utility e-bike, and a dahon D7 that my daughter has absconded with.
Quoted: 363 Post(s)
Liked 66 Times
I wonder if you could camp in this?
#78
Oh, hang on, I just read he has chainsaws, maybe not such a good idea.
Seriously, would love to see pics when you get it.
#79
CRIKEY!!!!!!!
Bikes: several
Quoted: 1589 Post(s)
Liked 687 Times
The ultimate cargo bike? we have it right here in Australia.
Everything was built by the owner in CrMo, right down to the forks. The bike is called "one less ute". 'Ute' is short for utility vehichle, what Americans call pickup trucks. You can see how the load bearing platform folds up when not in use.
"Surely one can love his own country without becoming hopelessly lost in an all-consuming flame of narrow-minded nationalism" - Fred Birchmore
#80
Sister Annie
Bikes: Retro Hercules adult tricycle, 1953 Hercules ladies roadster, 1950s Wearwell fixed gear 'Club' pathracer, 1980s Malvern Star 'Super Star', 1980s Healing GTX-105 Arabesque, 1980's Morrison Concorde & etc & etc.......
Wow that is amazing! What a completely practical vehicle
My one worry would be that with the rider so far back from the front wheel an unobservant car driver might run over the cargo platform.
OMNIPOTENS aeterne Deus, qui nos secundum imaginem Tuam plasmasti, et omnia bona, vera, pulchra, praesertim in divina persona Unigeniti Filii Tui Domini nostri Iesu Christi, quaerere iussisti, praesta quaesumus ut, per intercessionem Sancti Isidori, Episcopi et Doctoris, in peregrinationibus per interrete factis et manus oculosque ad quae Tibi sunt placita intendamus et omnes quos convenimus cum caritate ac patientia accipiamus. Per Christum Dominum nostrum. Amen.
#82
Bye Bye
i really like that home built cargo bike. the chain drive steering is interesting!
here's a pic of my bak: (anxiously awaiting a traditional kid cover for wet and rainy grocery and tool hauling!)
So long. Been nice knowing you BF.... to all the friends I've made here and in real life... its been great. But this place needs an enema.
#83
Bye Bye
#84
Bikes: Trek Mountaineer modified with a NuVinci; Montegue Paratrooper folding mountain bike; Greenspeed recumbent; Surly Big Dummy with Stokemonkey
#85
Bye Bye
#86
Sister Annie
What a terrific rig Would you have a clear photo of the rear axle setup on the trike?
I love my own tricycle and consider it to be a perfect car replacement.
#87
Grumbly Goat
Bikes: bicycles with round wheels
I'm looking at late sept next year to finalize this...i need to raise about $7000 to cover the cost of the bike and duties.
#88
Sister Annie
Thank you very much for going to the trouble of taking that photo for me. You sir are a gentleman
#89
CRIKEY!!!!!!!
Bikes: several
Liked 687 Times
It was a one-of custom built by my friend Moz. He's a prolific tinkerer, check out more of his creations here... https://www.mozbike.com/
#90
I wouldn't really call that a differential since the wheel that's turning faster (the one on the outside of the turn) isn't receiving any torque. But at least it has a form of limited slip- you're only driving the slowest turning wheel, so if you lose traction on one wheel (say it lifts in a corner) you're still driving the one with traction.
#91
Smiling and Waving
Bikes: -
No, that's the beauty of this set up. Both wheels get torque all the time.I had it out last winter and I could spin both wheels turning or straight.In a corner it's the inside freewheel that spins but the power is still transmitted to it even though the freewheel is turning slightly.Like I said, a brilliant design.
#92
nice!
that trike transmission is the best ive seen yet! ive ridden a bunch of trikes and until now the best one had a differential on it like a car, but sadly the thing got skidded on so much that the teeth sheered off gears inside the differential. that trike looks great! looks like you can pedal even with one wheel off the ground, which is great when just fooling around on the things!
as for cargo bikes, i built a long john style bike a few years back out of a bmx and a step through, ill see if i can dig up some pics of it, as its currently in the possession of my buddy...
#94
Sister Annie
Ok, that's really great, but now you've got to tell us how you built it
#95
Uber Goober
If it has freewheel on both wheels, then you never get power to the outside wheel until the inside one slips. That's different from a car differential, which can deliver power to both wheels while turning (but when one wheel slips, no power goes to the remaining one).
That's not a criticism of the set-up- just an observation. Seems like I saw an OLD pedicab a while back, and it actually had a differential in it. But on a typical three-wheeler, I would expect either a set-up like yours or else just one wheel would be powered.
#96
that carbo bike there is a mix of a a few doner frames. the step through is left as is, the bmx had its stays cut off, and the third bike was used for its tubes only, but was trashed and couldnt have been used for riding anyway. with a little time and a cheep mig welder, the whole thing got stuck together. it was tricky getting the welds to work though, as the tubing is thin and the only adjustments on the welder were on/off, fast/slow and high/low. as they were simplly switches we only had 4 on settings to choose from and found that blowing holes in bike tubes is easy. the thing is strong though and has carried people, buss parts, groceries, and much more!
as for the trike above, im not sure if that last post is aimed at me, but if it is, i was saying that the method used to get the power to wheels on that trike is probably the best ive seen, as power would still go to the wheel on the ground if the other came up, i know its not a differential, but i did have a trike that actually had a differentail, and it didnt work out that well, in fact all the skidding it got put through sheard the teeth off of the cogs inside the unit!
#97
Infidel
Bikes: 1976 step thru Schwin 10 speed with fenders, home made20" long bike, '73 Puegeot P-15, several beaters, kids bikes and projects
Here is a little something different and totally practical for pedal powered utility. I have been aware of this concept for some time but I keep going in several directions at once (senior moments) and losing the link. Being a front wheel drive bicycle/tricycle builder at one time is what lead me to it. At one time I had an image of one of these carrying a refrigerator and another of a bunch of drunks being ferried home after a night out but I have lost those. I don't need one but if there was ever a reason to learn to weld this is it.
image is not me
https://drumbent.com/trike.html
https://organicengines.com/lazy-index.php
https://drumbent.com/trikedetails6.html
https://drumbent.com/trike/trikeload.AVI
image is not me
#98
Bikes: GT3 trike,Viper chopper, electric assist Viper chopper,Electric moped(Vespa style)
I assume you guys and gals are aware of the SUV trike at Organic engines?
https://organicengines.com/products/t...e-aka-the-suv/
#99
Bikes: Fixie conversion, a few 10 speeds, a trailer, I GT Transeo for utilitarian riding
cool he is pulling trailers that you pull with a car, nice
#100
Quoted: 14 Post(s)
I sell all kinds of Cargo utility bikes for a living in the Netherlands'. Our shops strives and succeeds at having the widest range of manufacturers and models in the NL (which probably implies the world). We sold the TrioBike twice... never again! It stinks! Badly! A great piece of design that looks flash but functions very poorly... To wit: The disk brakes barely brake no matter how much you adjust them. The steering is very very dodgy, costs tons of effort and is very akward. Very easy to oversteer yet hard to compensate. The stability of the bike is okay at best.
Additionally the concept of a MTB style bike with a real aero position combined with a bike specifically meant to haul kids is flawed. I am sure there are 1 or 2 moms who want to cycle fast when they haul their kids and then spend 5 minutes getting grease on their hands and doing (dis)assembly so they can convert their Triobike into an MTB and then bomb down some moderate hills,.. but i have yet to meet them. Pass on this bike.
By contrast the Cargobike Long by Bakfiets.nl that pictures were posted off is the very best Cargobike out there (though that SUV recumbent might be a challenger to the throne).
It rides faster and easier (amazing handling) than any other cargobike (especially three wheelers), excellent parts and durability, low center of gravity. The biggest selling new Cargobike in the NL (world?) for a few years running. And, on top of that it has been tested as being the best Cargobike by the independent and authoritieve Cyclist Union (Fietsersbond) and it is the cheapest new cargobike bike we sell! We sell it at 1505 Euros and with the 7 Speed Shimano hub. By contrast the Triobike is almost a cool E 1000 more expensive!!
As you can tell i love this bike and that it has my vote despite selling and riding more than 8 other major brands and models 3 days a week.
