Inexpensive headset for mid 80s Miyata?
Quoted: 236 Post(s)
Liked 171 Times
Got a '86 Miyata that I'm building up and need a new headset. Any recommendations for a decent inexpensive (less than $50) unit?
Catching Smallmouth
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 88 Post(s)
Liked 134 Times
A Tange Levin CDS is pretty tough to beat. I think you can get them in both ISO and JIS sizes so measure. They also have a low stack height.
Likes For BradH:
Velo-Orange has a few of their sealed bearing ISO headsets with damaged boxes in their Specials section for $40. That's a great deal on a great headest. I ordered one already, so have at it.
https://velo-orange.com/collections/...eid=ae9e02ecff
Likes For mattface:
Quoted: 236 Post(s)
Liked 171 Times
I don't know. Being Japanese it could well be JIS. I'm not sure if mid-80s constitutes an "older" Japanese bike. I'd put a caliper on the fork crown to verify if it's 26.4 or 27.0mm.
Likes For mattface:
Quoted: 2339 Post(s)
Liked 2,831 Times
+1 on this
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
I would assume so too, but don't. Instead, use a digital caliper on the head tube ID and the fork crown OD. if you don't have a caliper, pick up a really cheap one off eBay. Mine cost like $4, and it works great.
Likes For SurferRosa:
Bikes: 1984 Miyata 710 resto-modded to 1x11 townie, 1987 Bianchi Brava resto-modded to 1x11 fitness/events
Quoted: 15 Post(s)
Liked 48 Times
edit: actually, I needed about a 1 mm spacer to take the place of the old reflector hanger.
If you're interested, the resto-mod information is here:
https://www.bikeforums.net/22391912-post8077.html
Likes For Prunesquallor:
Quoted: 1562 Post(s)
Liked 1,736 Times
I don't know how much of a weight weenie you are, but I would stay away from steel headsets like the Tange Levin CDS. Get an aluminum headset instead. Tange makes some aluminum ones.
Likewise steel bottom brackets. These classic mid-range japanese bikes tend to come with steel headsets and steel BB's. I take them out and toss them the first chance I get.
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 387 Post(s)
Liked 693 Times
The CDS is a fine choice, and if one desires to go slightly higher in quality and finish, the NJS is my personal favourite (and still within budget). The aluminum version LV-1500 tends to hover just around $55, slightly above the stated budget.
señor miembro
Liked 6,491 Times
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 175 Times
Bianchi Goddess
Quoted: 2937 Post(s)
Liked 2,934 Times
I don’t know if they are still made but I like the Ritchey Logic headsets.
Sugar "Kane" Kowalczyk
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
The various Tange Levin models are hard to beat for value. Whatever you decide, make sure the new headset has a stack height the same or shorter than the current headset. You can always make up for a shorter stack by adding spacers, but you can't stretch the steer tube to fit a larger stack. Some stack heights courtesy of Barnett's:
Likes For JohnDThompson:
Quoted: 15 Post(s)
Liked 48 Times
señor miembro
Liked 6,491 Times
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
Or did you mean it was too tall for the steerer? Not all steerers are cut equal although we'd love to assume so.
Bianchigirll I like the Ritcheys at the pricepoint too but JIS might be harder to find.
Quoted: 15 Post(s)
Liked 48 Times
And that's what spacers are for.
señor miembro
Liked 6,491 Times
You're also referring to cartridge bottom brackets where the steel spindle is sealed within a body of two bearing cartridges which are also made of steel. (Or they use other steel parts like cones and lock nuts.) These aluminum (or plastic) "cups" you're referring to simply hold that cartridge in the frame. They don't actually serve the same purpose of c&v steel cups which secure/adjust the ball bearings.
I don't know of any vintage steel or ti spindle that actually fits into aluminum cups. How would that last?
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
Likes For Hudson308:
Liked 1,736 Times
I believe you're referring to Octalink. This is the c&v subforum. I'm referring to a DA cup & cone bb from the early '80s, not a cartridge unit from 2000.
señor miembro
Liked 6,491 Times
First, op, sorry for the bb threadjack.
I'm down with that ... on a not so special bike. But if this Miyata were an upper-mid-level 912 with an original bb hollow spindle, those 50 grams aren't that big of a deal. I much prefer the unit actually engineered for that particular crankset. I know the spindle is the correct taper standard, perfect length on both sides, I trust it, and I'm usually confident it won't be a problem to overhaul, maybe several times during the bike's life.
Sometimes, originality is important. When it's a keeper, period correctness is almost always important. I chose a new $35 Taiwanese bb for my Miyata with its first gen Chorus crank. But if I could have easily found a Chorus loose ball bb -- even if it's another 50 more grams -- I would have grabbed it in a heartbeat ... just for the perfectly measured offset spindle. Plus, you can see the cup from the nds, and the original vintage one always looks better.
Yeah, if I can have my choice between Super Record and Record, I'll probably take SR every time. I like that the upper race is drilled and the threaded pieces are aluminum. But at the same time, it's not that big of a deal, and steel units tend to keep their appearance longer.
... an easy place to save weight without ruining the looks of the bike.
Same with the steel headsets.
Quoted: 236 Post(s)
Liked 171 Times
Likes For tendency:
