Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
SRM data sample rate with Wahoo units
Old 11-06-18, 10:41 AM
bartek.
Quoted: 63 Post(s)
Hi,
I can't find any information regarding data sample rate for Wahoo head units. AFAIR the SRM PM has 1sec data sample rate for Garmin units via Ant+ and 0.1sec for PC8 (ANT+? BT Smart?).
Anyone could give some reliable information about the sampling? I can be wrong here (correct me please) but SRM Science Track PowerMeter supports both ANT+ and BT, right? So how does it go with Wahoo head units which supports both protocols? What sampling rate can be achieved with using which protocol here?
Looking for a replacement for my Garmin Edge 810 and my 2 current options are Wahoo Elemnt Bolt or Edge 520 plus (PC8 is a way too expensive). Which one would be better for track purposes (I have enough information for other disciplines but don't want to be disappointed on track after buying a new unit)?
bartek. is offline
Old 11-06-18, 12:52 PM
colnago62
Quoted: 741 Post(s)
Liked 412 Times in 230 Posts
Originally Posted by bartek.
Hi,
I do not have a track SRM, I have the Origin on two road bikes. There is an issue with cadence reporting with the Wahoo and my SRM. The numbers for cadence and average cadence are way off. I know it is a Wahoo issue because the SRM works flawlessly with my Garmin. The Wahoo also has an issue with pc6 board from SRM.
colnago62 is offline
Old 11-06-18, 01:49 PM
carleton
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
I would consider the SRM PC 7. It samples every 0.5” (PC8 is 1”, if I remember correctly). PC7 is moderately priced and even cheaper if you buy refurbished from SRM. It is ANT+ as well. No SRM cranks required.
carleton is offline
Old 11-07-18, 07:46 AM
topflightpro
topflightpro's Avatar
Quoted: 1851 Post(s)
Liked 679 Times in 430 Posts
Yeah, you should be able to find a PC7 used for about $150. But it does not have GPS - not really an issue for the track but could be if you plan to use it elsewhere.
topflightpro is offline
Old 11-10-18, 01:48 PM
bartek.
Quoted: 63 Post(s)
It's pretty strange. Maybe I will arrange the wahoo unit first for checking if the cadence in my case is correct. I assume the difference is noticeable quickly?
Could please verify the data sample rate for me? Simple read FIT file with a record with your SRM power meter. In my case, it's every 1 second but I use Garmin.
This could be an option too. Unfortunately, I can't find anything cheap. Maybe looking in a wrong place but I see prices above $1000 For a good price I could go with wahoo/garmin on my road/cx bikes and keep PC7 for track only. As I would need recollect all mounts for wahoo anyway (integra stem, oval pro missile tt, saddle rail) I could go with SRM versions. But it's definitely not worth $1000.
bartek. is offline
Old 11-10-18, 01:58 PM
bartek.
Quoted: 63 Post(s)
EDIT. OK. Got a wrong example at first. Prices are a way below $1000. I can see some units for circa $120 used on eBay. This is definitely something to consider. However I still need to know if I should switch my Garmin Edge 820 to Edge 520 or Wahoo Elemnt Bolt ;-)
bartek. is offline
Old 11-10-18, 09:30 PM
colnago62
Quoted: 741 Post(s)
Do I find the file on the Wahoo unit?
Old 11-11-18, 10:36 AM
bartek.
Quoted: 63 Post(s)
Sure thing, simple connect wahoo to your laptop: https://support.wahoofitness.com/hc/...ptop-Computers
bartek. is offline
Old 01-11-19, 09:13 AM
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
Liked 50 Times in 37 Posts
random necro, I see @carleton and @topflightpro suggest the PC7 does pair with non-srm power meters, but google fu seems to suggest it does not. (only reads ant+ ctf protocol) Any clarification? I might pick one up if it works with other stuff.
Morelock is offline
Old 01-11-19, 10:21 AM
carleton
Elitist
carleton's Avatar
The PC7 is an ANT+ head unit. If the power meter works with ANT+ head units, it will work.
ANT+ is a standard (created by Garmin, I believe) that many manufacturers use.
carleton is offline
Old 01-11-19, 10:23 AM
carleton
Elitist
carleton's Avatar
https://en.m.wikipedia.org/wiki/ANT%2B
ANT+[1] (pronounced ant plus) is a wireless protocol for monitoring sensor data such as a person's heart rate or a bicycle's tyre/tire pressure, as well as the control of systems like indoor lighting or a television set. ANT+ is designed and maintained by the ANT+ Alliance which is managed by ANT Wireless, a division of Dynatream Innovations owned by Garmin.[2] It is based on the ANT protocol.[3]
carleton is offline
Old 01-11-19, 11:26 AM
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
@carleton
Yeah, it would seem that way from a quick glance, but deeper looking on the web suggests otherwise. The SRM PC7 uses ANT+, but something is different than what's transmitted by non-srm units (quarq's can be modified to work in "srm emulation" mode and will work)
That's what I found from the internet anyways.
Morelock is offline
Old 01-11-19, 11:33 AM
carleton
Elitist
carleton's Avatar
@carleton
Will you cite exactly what they are saying?
carleton is offline
Old 01-11-19, 11:41 AM
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
Sorry on mobile for a while, here is a post
weightweenies.starbike.com/forum/viewtopic.php?t=134939
Searching slowtwitch forums seems to confirm in multiple threads as well. In dcrainmakers stages review comments someone asks about stages /pc7 compatibility and a stages rep says no it won't work.
Hmm
Morelock is offline
Old 01-11-19, 11:53 AM
topflightpro
My comment was directed to the OP, who was using the most recent version SRM Track, which should work with the PC7.
The PC8 should work with non-SRM PMs. I cannot speak to whether the PC7 does.
carleton
Elitist
carleton's Avatar
Hmm
I read the first post and immediately know the issue. The user has to configure the head unit to either receive cadence as a separate signal than power or on the same signal (I can’t recall which one). The fact that cadence is missing is the key clue. Cadence is required to calculate power.
It’s a configuration error.
I dealt with this when I had a PC7 head unit paired with an ANT+ cadence sensor then switched to using SRM PM cranks. I had to go into the software (or menus on the head unit) and reconfigure it.
carleton is offline
Old 01-11-19, 01:01 PM
carleton
Elitist
carleton's Avatar
Basically, I recall the menu being something like:
Option 1:
- Speed + Cadence Sensor signal
​​​​​​- Power Meter signal
Option 2:
- Speed Sensor signal
- Power Meter + Cadence Sensor signal
Option 3:
- Cadence Sensor signal
Each sensor has a unique ANT+ ID that is stored in the head unit and when stored, the head unit listens for those particular signals and records the data they transmit.
Cool fact: Speed sensors can be used as Cadence sensors and vice-versa. They are basic reed switches and don’t carry any extra data like Power Meter sensors.
carleton is offline
Old 01-11-19, 02:47 PM
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
Back to a real comp
I follow what you're saying @carleton, mainly because it just makes sense that it should work with ANT units... but I don't find anyone online that has successfully done it with anything except a Quarq.
(fwiw, if seller accepts my offer I'll just buy the thing and test it myself... I'm sure I'll end up with another SRM unit sooner or later)
https://forum.slowtwitch.com/forum/S...20pc7#p6587167
https://forum.slowtwitch.com/forum/S...20pc7#p6408374
highlight
PC7s speak a non-ant standard, and so they dont work with a generic powermeter. That said, Quarq has implemented the specific PC7 protocol (it used to be name German Achievement Mode, or GAM)
Morelock is offline
Old 01-11-19, 04:04 PM
Morelock
Morelock's Avatar
Quoted: 282 Post(s)
@carleton
I'm with you, that's how Ant(+) should work. I've found nothing online indicating it DOES work that way with the pc7, and a lot that say's it doesn't work at all with any other PM besides the SRM (and some quarqs)
basically here
here
and
here
Morelock is offline
TopEnd Rider
5
01-15-19 12:10 PM
koolerb
General Cycling Discussion
25
07-04-18 09:11 PM
metalheart44
4
07-13-16 09:34 AM
LGHT
3
02-03-15 04:33 PM
Andyz
Road Cycling
51
09-10-13 05:06 PM
