No spoke wrench required!
Likes For big chainring:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Randomhead
Liked 3,698 Times
That's an unusual method, most people use a more percussive technique. Looked like he did a decent job of it
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
Quoted: 4560 Post(s)
Liked 2,802 Times
Heh. I did something like that on a ride. Skidded sideways on some loose gravel and sand on freshly chipsealed pavement, warping the single wall rear rim. Spokes were probably too loose as well.
I braced the wheel against a utility pole and pushed from one side, pulled from the other, until it was straight enough to ride to the LBS.
At the shop the tech whanged the entire wheel against a heavy duty wooden bench. Tweaked a couple of spokes. Straightened it perfectly. And it held for two years before I was hit by a car on that bike, finally wrecking both wheels.
I knew some gunsmiths who used a similar technique to straighten rifle barrels, particularly with spring piston air rifles that use the barrel as a cocking lever. They'd detach the barrel (and any iron sights, etc.) and whap it like a whip against the wooden work bench until it was straight. The trick was to whap it flat against the bench. Worked remarkably well. But that probably wouldn't work with thin shotgun barrels.
Likes For canklecat:
If that had been one of those GCN videos, it would have taken them 25 minutes to explain that.
Likes For texaspandj:
Quoted: 1627 Post(s)
Liked 630 Times
Sometimes a bicycle just needs a hug.
Likes For Lascauxcaveman:
Quoted: 896 Post(s)
Liked 2,065 Times
One of my first days volunteering at the bike co-op, just Jay-Boy and me, a drunk showed up with a wheel that looked like a potato chip. He wanted us to fix it, but we figured it was toast. He could barely walk straight, but he lay the wheel on the ground, stomped on it a few times, picked it up, and it spun true. Damn. Jay-Boy and I looked at each-other with our mouths agape while the dude staggered away, happy.
The best **** happens at the bike co-op!
Likes For downtube42:
