Any practical reviews or testing of Muc-Off Inner Tube Sealant?
Quoted: 350 Post(s)
Liked 122 Times
Does anyone know of practical reviews or tests of Muc-Off No Puncture Hassle Inner Tube Sealant?
It seems to beglycol based going by the MSDS, similar to Slime. (Edit: I thought there was an MSDS For the Muc-off inner tube sealant that indicated glycol base, but I could be mistaken. The MSDS that I saw might have been for their tubeless sealant, but I can't find it anymore. Some websites claim the Muc-off inner tube sealant is water based, but what the manufacturer's website says is "water soluble". But their tubeless sealant says the same thing too.) The only practical test of similar sealants I know of is this website:
https://www.slowtwitch.com/Products/...rt_1_4147.html
It seems to indicate glycol sealants being less effective than latex sealants for larger punctures on butyl tubes.
I currently have Stan's/Schwalbe Doc Blue (latex based) in my lightweight Butyl inner tubes. But I have Big Ben Plus tires with greenguard strip, and haven't experienced any punctures, so It's unknown to me whether the Doc Blue is effective. I was thinking of switching to lighter weight tires without a plastic protection strip. But the Latex based sealants dry up over time and require a refill every 3 months or so. The Glycol based sealantslike and the Muc-Off inner tube sealant claim not to dry up and don't need a refill, although requires an initial fill which is equivalent to approximately 3 times the refill of a latex based sealant.
I've also read recommendations to use normal thickness butyl instead of the thinner lightweight versions, for sealants to be more effective. Is this true? I would prefer to save a little bit of weight with the lightweight tubes.
It seems to be
Quoted: 2338 Post(s)
Liked 2,822 Times
no experience, sounds interesting, so far of the sealants I have tried with tubes and tubular caffelatex has worked the best (but have way fewer flats since i went from vittora corsa clinchers to conti gp5000 clinchers and/or vitorria corsa control tubular)
Quoted: 381 Post(s)
Liked 145 Times
https://road.cc/content/review/muc-i...sealant-277333
Verdict: 7/10
Impressive sealing capabilities and long lasting, but a bit more Presta-specific compatibility would be nice
Pros
Seals small holes quickly
Remains liquid for a long time
Cons
Installation tube and valve core key are Schrader specific
Weight: 347g
Verdict: 7/10
Pros
Cons
Weight: 347g
Quoted: 350 Post(s)
Liked 122 Times
Yes I saw that webpage already on the top of the Google search results but the content of the review wasn't very metrics based or comparative with other existing sealants on the market.
I understand from the review that this sealant can be effective under certain conditions. But I would like to know more. Like what kind of inner tube was used for the test, what is the base for the sealant to estimate how closely it may perform to other brands of similar composition, or to guess how realistic their claim of no refills is compared to how long other similar sealants have lasted. And most useful would be a test like the slowtwitch test with multiple brands with almost identical and repeatable conditions.
