Bike rear tire bulge/tear - replace or fix?
Bikes: 1999 Peugeot Competition Cyclocross
Hi Everyone,
I just got home from riding and found this bulge/tear in the rear tire of my city bicycle. I bought it a bit over a week ago at a flea market, and though everything seemed fine I had it checked out the LBS across the street 2/3 days later. They charged me 25 euros for an inspection, said everything was fine, and now I've got the following issue.
Is there any chance that I can fix or patch the tire, or should I just get a new one? Can I try to reuse the same tube? It's still got plenty of pressure, regardless.
I'm a bit worried about changing it myself because I've got a internal 7-speed shimano hub with a coaster brake on the rear wheel, and I'm sure that I'll have to remove the gear change cable if I need to change the rear tire. I looked up some information on the hubs, but there wasn't a guide to removing the gear shift cable.
Any help would be appreciated!
See the attached picture!
Chris
Chris
Quoted: 453 Post(s)
Liked 104 Times
That tire needs to be replaced, no chance any repair could save it; would be looking for a new LBS, as they should have picked up that the tire was worn out, as seen by the cracks in the rubber, which would have been there long before the tear.
Not sure what the pictures of the Peugot are for, as we can't see any details of the hub you have, if it's Shimano, it will have a name / number printed on it, google this, and you will find instructions on-line for it.
Thanks for the reply, I will probably look for another place. This one's convenient because it's just across the street from my house. I wanted to upload pictures of the peugeot for another thread, and I couldn't figure out how to get the off of my initial post.
Quoted: 5772 Post(s)
Liked 2,563 Times
I wouldn't automatically blame the shop. This kind of damage can often appear very suddenly in an old tire. The tire might have been old and dried but necessarily to where it was obvious, and the tearing happening only after hitting a sharp bump like a pot hole.
Also, put yourself in the shop's position. If during the inspection they suspected that the tire was near the end of it's service life, and told you you needed a new tire, or maybe two - since odds are the other is similarly brittle - you might felt they were hijacking you for more dough on an unnecessary repair. Since it wasn't a safety issue, they might have felt the best thing is to take a wait and see approach.
It would be different if you had the inspection done before buying, or as a prelude to a long tour, but as it is, I'd give the shop credit or at least the benefit of the doubt for erring on the side of trying to save you money. As it is you're now no worse off than if they told you you needed tires 3 days ago.
FB
Chain-L site
FB
Chain-L site
bike whisperer
Quoted: 1526 Post(s)
Liked 718 Times
To be fair to the shop, that failure isn't something that can easily be predicted.
Plenty of tyres with such perished rubber are perfectly okay to use; to say you definitely needed new ones would've been verging on a hard sell, IMO. I'd actually consider that a definite plus for the shop, if they turn out to be competent.
If it was me, I'd have said the tyres might be alright, but possibly not. I guess this failure is a result of the bike sitting on a flat for long enough to permanently crease the plies.
The condition of the rubber doesn't say much about the important part of the tyre - the carcass.
Edit: Hah - FB beat me to it. Great minds ; )
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Ok, that's a very good point, I wasn't sure how obvious that kind of old tire damage would have been a few days ago, and I did put in a lot of riding the last few days (about 50 km) while I'm waiting for delivery of an adjustable stem for the peugeot above.
The bike was pretty cheap (for German standards, certainly). It's about 10 years old, an "Alu-Steel" frame city bike from Hercules, called "Airliner". The tires are certainly on the older side, though the front looks better than the rear. I guess I'll just change out the rear and keep an eye on the front tire as well.
Thanks for the advice!
bike whisperer
Liked 718 Times
What's with the Peugot?
I, for one, am glad you posted the Peugeot pics. That is one sweet looking Peugeot!! Do you know the year it was made?
Definitely replace the tire. Its gonna blow-out any moment now, and you don't wana be on the bike when she blows.
The peugeot is a 98 or 99 Cyclocross Competition . . . Columbus thron tubes and shimano rsx 14 speed components. The cantilevers aren't that great, so I might replace them with standard road bike brakes at some point. I'll add a few more pictures of it here. It rides really nicely :-)
Looks great. Thanks for the pics!! I saw a white Peugeot last year and ever since, I have been into their looks. For some reason they look better to me than the usual traditional style road bikes.
Desert Rat
Bikes: GT Timberline (1990?), Trek 1100 (199?), Giant OCR3 (2007)
If I were you I'd put the new tire on the front and the current front tire move it to the back. I want my best tire on the front.
bike whisperer
Liked 718 Times
Good call.
Bikes: '74 Schwinn Le Tour (x2), '83 Bianchi, '96 Trek 820, '96 Trek 470, '99 Xmart Squishy Bike, '03 Giant Cypress
If you can, replace both tires and be done with it. No sense in waiting/wondering when that front tire is going to follow the rear.
Liked 6 Times
I wouldn't automatically blame the shop. This kind of damage can often appear very suddenly in an old tire. The tire might have been old and dried but necessarily to where it was obvious, and the tearing happening only after hitting a sharp bump like a pot hole.3 days ago.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
If you decide to replace the front tire, and it still seems fine, you could keep it for a spare in case you need a tire and all the shops are closed
