3D Printed Accessories / Mounts
#76
This is a just so cool. Is the software to create these parts included with the printer. I see maker bot and
dremel for 1,000. Again so cool science tec bike hacks.
#77
Ride it like you stole it
I love this thread! I have not had need for anything you guys are making yet, but I am getting some ideas of my own. I have made several of my own parts in the past as I have access to lathes and mills at a machine shop, but this idea of additive custom manufacture is going to open a lot of new possibilities in biking! This is just the beginning and I bet this will eventually become its own forum as it starts to really take off!
The most common Slicer/Print software used in consumer 3D printing is Repetier-Host, Cura and Slic3r. There are a slew of free and paid 3D modeling software. Here is an incomplete list of free and commercial software: https://www.3ders.org/3d-software/3d-software-list.html
"Never use your face as a brake pad" - Jake Watson
The Reloutionaries @ Shapeways
#78
3D Print Files for Virb to GoPro Adapter
If you have the need for a Virb to GoPro adapter and don't want to buy a whole set of mounts. You have or have access to a 3D printer. I have posted the print files for a version of the same. It uses the Virb thumbscrew and an M4 acorn nut or M4 nylon insert lock nut on the Garmin side and the standard GoPro style thumbscrew on the other.
Virb to GoPro Mount Adapter on YouMagine
Virb to GoPro Mount Adapter on Thingiverse
Just my way of saying thanks.
#79
Custom 3D printed GoPro seat post mounts (free download)
Anyone who has a 3D printer or has access to a 3D printer and wants a size specific seat post mount for their GoPro style action camera. I have posted 2 simplified designs on YouMagine. They both look essentially the same, one is size specific to 27.2 mm round seat posts the other to 31.6 mm.
To print have your slicer program re-position the two halves and add support material. Cut away the support material after printing. The mounts use two M3 x 15 mm socket head cap screws and matching M3 nylon insert lock nuts to secure it to the seat post. A standard GoPro style thumbscrew and acorn nut (M5) attaches the camera.
31.6 GoPro Seat Post Mount
27.2 GoPro Seat Post Mount
My way of saying thanks to this community. If you do not want to print your own I have more streamlined versions of these in many more sizes on my Shapeways page (see link in signature), plus stuff for Garmin and Sony too!
#80
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
You must ride on very smooth roads. If I mounted a camera on that the footage would be unusable. Way too springy. I have to keep my designs extremely thick and rigid.
Work: the 8 hours that separates bike rides.
#81
I don't use a GoPro, I use a much lighter camera the Sony HDR-AZ1. If I wanted it for a GoPro, I would make the arm shorter by about 1". I have no problem with chip seal roads and camera shake. There are SHORT ARM versions included with the YouMagine files. The short arm version places the mount just over 1" away from the seat post when the camera is mounted in the upright orientation.
From the year and a half that I lived in Saint Claire Shores, I don't remember ever driving on a single smooth road in the entire state of Michigan.
#82
Señior Member
Quoted: 446 Post(s)
Liked 8 Times
Yeah, if I don't mount my camera either on my helmet so my neck takes up the shock, or as rigidly as possible to my frame, the video looks like it was shot in a paint shaker.
#83
Señior Member
Quoted: 446 Post(s)
Liked 8 Times
Here's my VIRB to bar adapter. It's done in OpenSCAD so it's fully parametric if you need to tweak it. Also the VIRB mount is a separate module so if you need to print a VIRB mount on top of a lego brick or a Yoda head, knock yourself out.
https://www.youmagine.com/designs/ga...unt-parametric
As always, my stuff is CC0 public domain licensed.
#84
Señior Member
Quoted: 446 Post(s)
Liked 8 Times
There's a TON of free/open source modelling software. Unless you're doing professional work for pay, there's really no need to pay for it.
I am a programmer and mostly I make mechanical parts which are mostly geometric shapes, and I like to make my stuff parametric so that I can easily change sizes of screws, mounts, etc, so I use OpenSCAD.
There's Google Sketchup, and Autocad's 123D Design and 123D Sculpt, there's Tinkercad, Blender, several other popular free tools.
Heck, Blender is free but it's also what's used by many movie houses doing 100 million dollar big budget films to do their 3D rendering.
#85
Well, there's no one "software" that's right for everything. There are probably at least a couple dozen pieces of software commonly used for 3D modelling. Some are great for some things and lousy for others.
#86
New stuff and software comments.
Been working on a different version of the Garmin Edge mount. The current one works fine but it only works in one orientation. So Edge 1000 users would be stuck in portrait mode. The new one is an eighth-turn and allows both portrait and landscape modes with just one mount. I should have this printed and tested in about a week.
I also am trying a mash-up type of Edge mount. I am personally invested in GoPro style mounts. I needed to focus on one mounting system as I have working Contour, Sony and GoPro action cams. While not my favorite, there are just more options in the GoPro mounting system. What I do love is the fact that both Garmin and Contour have rotating mounts. The Contour is just too limited as it rotates only and fixes the tilt of the camera to one angle. The Garmin Flat mount has a lot of flexibility. Off to REI to pick up the Virb mounting kit on clearance, design and print a flat mount insert that works with the GoPro and swap it for the Virb insert. Now I have a fully functional GarGoPromin flat mount. I can rotate and tilt and stick it on the bottom of my Edge mount. Unfortunately because of the placement of the mounting screws on the K-Edge combo mount this is nearly impossible to print (some walls are too thin or missing completely), so no chance I will make this a K-Edge combo mount interface.
@long john, I am not a programmer so I don't particularly care for the steeper learning curve associated with applications like OpenSCAD. I started out with 123D Design, but quickly outgrew its capabilities. It is more focused on what the finished product will look like rather than the steps it took to get there. I now mostly use FreeCAD. It is much less programmatic than OpenSCAD but still allows me to go back in the timeline to adjust whatever parameters I need.
@ItsJustMe, I have looked at some of your designs and I see that yours have a lot of more traditional parts associated with them like using conduit for you mount then making your Virb mount a direct bar mount. I tend to be a more 'form is as important as function' kind of guy. Yours are easier to print for the home maker and very utilitarian and I need mine to look more aesthetic with curves and smooth transitions. That is just one of the many differences that make this 3D printing thing so special, I love to see the way others tackle these issues and come up with individual solutions.
With regard to CC licensing, I am all for open source and creative freedom, but don't believe everything needs to be open or free (these are different) in the 3D print community. I use open source software and hardware nearly every day, I use Ubuntu for my media server, Debian for my print server, Arducopter for the OS of my multi-rotor flight controller (Pixhawk, also open hardware). So with that said, I have some designs that are open, posted mostly on Thingiverse but slowly transitioning to YouMagine, and a lot of designs that I keep to myself. I tend to design something simple first and easier to home print, then refine and sculpt after I know it works. The simple design goes up in a public file repository the 'sculpted' version I keep.
I am happy to see that others are interested in doing this for themselves and hope we can keep this discussion going.
#87
Special offer from Shapeways 15% off anything in Nederlandse Oranje
In honor of Their Dutch heritage, Shapeways is offering 15% off all Orange Strong & Flexible this week to celebrate King's Day. Use code KINGSDAY15 to save on anything from the marketplace through Friday May 1*.
#88
#89
New Item: Di2 Junction 'A' Clip / 5 mm Headset Spacer Combo
This is for those of us that do not want to use any straps, ties or tape to hold on their Di2 Junction 'A' box. It is a combination of a 5 mm headset spacer and the slide on clip. This differs from other clips as it is angled 17° so the junction is mounted parallel to the ground. If you are willing to give up 5 mm of saddle to handlebar drop, this is for you. Designed to fit 1.125" (28.6 mm) fork steerer tubes.
#90
Señior Member
Quoted: 446 Post(s)
Liked 8 Times
I've updated my bar mount for the VIRB and printed one last night. I think it's a vast improvement, but I haven't ridden with it yet:
https://www.youmagine.com/designs/ga...ount-version-2
I dare that thing to move now. I've used a nylock nut, I have a backing piece under the screw, and a block to prevent the camera from rotating.
#91
Presta Valve Cap Extension / Core Tool Combo
Okay so I was fooling around a bit tonight and had to put some sealant in my tires, after spending 10 minutes looking for that little plastic valve core tool I decided to finally release this idea. The image shows one, but they come as a pair. It is a combo Presta valve cap and extenstion tool and core remover!
Presta Valve Cap Extension / Core Tool Combo on Shapeways
#92
How to Mount a GoPro on a Garmin Virb Rotating Mount
A custom GoPro mount that uses a Virb Flat or Curved Rotating mount. Here is how I mounted My GoPro on the Garmin mount. First you need these two items from the Garmin Virb mount.
Then I had this GoPro/Garmin Mount Insert 3D printed.
Once inserted in the mount and the Garmin Lock ring screwed on and hand tightened you have this.
Now the rest of the hardware is standard GoPro stuff, you can attach the camera directly here or any of the myriad of GoPro extensions or attachments.
I really like the fact that this arrangement allows the GoPro to be tilted and rotated in as small and secure mount as possible, it is easy to loosen the lock ring just enough to rotate the mount to get the angle you need.
#93
(Edge|Forerunner|Fenix)/Virb TT Extension Combo Mount
Don't know if there would be any interest in this type of mount. I redesigned the Garmin Edge mount I was using so that it is only an eighth-turn instead of quarter-turn. As a result I ended up being able to put two sets of stops 90° offset. This allows an Edge as well as a Forerunner or Fenix to use the exact same mount without moving and/or unscrewing anything. Then I put it in a Time Trial Bar Extension type of mount. The Garmin will sit even with the extension. As an added feature I put a Virb mount under it. You can have both a Garmin cyclo-computer or sportwatch as well as a Garmin Virb action cam all on the same mount. The Virb will sit below the extensions. It should fit any alloy/carbon extensions that are in the range of 20-22 mm in diameter.
Only a couple of items are required. An M4 x 15 mm socket head cap screw, an M4 nylon insert lock nut, a genuine Garmin Virb mount insert and locking ring.
Here is a render of the mount.
This same mount could be made with a built in GoPro mount also.
#94
Don't know how I forgot about all the Deda M35 stuff. I now have a full set of Edge combo mounts for 35 mm handlebars. Fits both road and 35 mm MTB. They all now have the Eighth-Turn mount to work both portrait or landscape as well as working great on Forerunner watches with the bicycle clip attached.
Also the TT mount is live for both GoPro and Virb mounts, fits industry standard 22.2 mm extension arms.
#95
Randomhead
Liked 3,687 Times
I need an edge mount with a lipstick battery holder built in
#96
Send me a PM and I might be able to make something up for you. I'll need additional info such as which Garmin and what lipstick battery holder, etc.
#97
Bikes: Baum Romano, Brompton S2, Homemade Bamboo!
Quoted: 474 Post(s)
Liked 204 Times
Custom AyUp mount
There aren't many options for mounting AyUp lights:
Handlebar mount is a bit clumsy and taks up a lot of room.
Helmet mounts work well.
I had the idea to create a part using the helmet mount concept and making it compatible with a K-Edge.
Using some experimentation to get the C-clip shape right and also using some ideas on a couple of WheresWaldo's designs, I came up with this.
It needs a couple of minor modifications (fixing holes are not the correct distance apart) and some testing, but the idea works.
I'll do another in ABS (this is PLA) and ride with it a bit. Not 100% sure if the C-clip is strong enough to prevent the light popping out if I hit some rough road.
#98
Quoted: 474 Post(s)
Liked 204 Times
Well, that design didn't work too well!
Over a heavy bump at speed it was possible to unclip the light (luckily I'd arranged cable to not let it fall far) and it is also possible for the light to rotate. Either the grip needs to be improved to solve both issues or the cable plug area needs to be trapped somehow to stop rotation.
So...a much simpler idea came out of another thing I saw.
I tried it out in a couple of sizes and also with a 'double adaptor' concept (for two lights or a light and a GoPro).
Fits neatly to the standard GoPro mount. Light seems fairly secure. Time for some more riding...
#99
Your design skills are looking better. It's good to see others embracing 3D printing for bicycle accessories. I have done well with Di2 compatible mounts as well as some of the rear mounted GoPro/Virb/Sony camera mounts.
If you want something that is as easy to extrude as PLA but with the strength of ABS, try using PETG. It is made from recycled water bottles and is usually transparent, although eSUN has come out with solid black and white PETG.
#100
If so, I have three ideas:
1. Angle the mounting surface back 30 degrees?. The Virb can still be aimed at the horizon using the thumb-screw. Since the Edge computer now sits further forward, it should point towards the rider's head instead of straight up.
2. Instead of using M4 bolts, what do you think about using zip-ties? I have some standard 75lbs ones and some beefy 150lbs ones at home, I will measure the cross-sections later. I got the idea for this from the Racebone on Shapeways: https://www.shapeways.com/product/C84MQ54UB/racebone-garmin-handlebar-mount?li=related-items-solr&optionId=42451391
3. For some extra stability, what about mounting to both aerobars? If Shapeways allows, this could be a parameter (I will have to measure the distance between my bars inside-to-inside). I got the idea from the 3T computer bridge: COMPUTER MOUNT BRIDGE - Accessories - 3T Cycling Road
