Hybrid vs. Mountain Bike for Clyde
Hi all...
Clydesdale here...6'3, 280.
I have an older, incorrectly sized (too small) Giant Ranier and am looking for a new ride. Budget is $1500 or less...
I'm primarily interested in riding with my wife and child around the neighborhood but also want to hit the beach trails around the house (Miami, FL).
I've been to a few LBS in the area thinking I wanted a hybrid (Trek DS, for instance) but all of them advised I go the front suspension mountain bike route instead. Perhaps swap the tires out for something a bit less mountain-bikey.
The last place I stopped suggested a Cannondale Trail 2 so that's sort of the starting point. Have Trek, Giant and Specialized in the area as well. Got to googling and was checking out the Surly Krampus and Kona Honzo (or some variation of it), as well.
Certainly open to other options but wanted to see what the collective wisdom of the forum had to say.
Thanks in advance!
Thanks in advance!
hybrid is a modest width tired 29er, or a 29er, is a wide tired 700c road/touring bike wheel.
buying a 29er you can fit a narrower tire that will be almost too wide for a hybrid... about 42mm wide.
rather than 50 or 60 ..
Quoted: 76 Post(s)
Liked 19 Times
I'm a little smaller than you and I ended up with a Surly Ogre for a versatile flat bar bike. I built mine from the frame up though and have no idea whether you could ride out the door on one and stay within your stated budget.
From what you listed, the Ogre would be my pick for the riding you say you’ll be doing.
If you go the suspended mountain bike route, I would sway towards Trek/Giant/Merida and definitely go for a fork with a lockout. But really, suspension sounds like overkill for what you’re doing. But those 3 brands offer some of the best bang for buck on the market so check out what they have to offer.
The Troll I would flat out ditch because it’s a 26er. The Krampus is a more serious MTB than you need. The Honzo is definitely out as it’s one of a newer breed of more serious MTB designed for riding where a full suspension bike could easily be used
The Ogre looks fantastic...may be a bit over budget, and no option for front suspension down the road, however.
Came across the Salsa Timberjack, too...in the "compete with Giant/Trek/Cannondale" group.
Any thoughts on Scott?
dollar-store reject
ever think of Cragslisting something used?
These are by me, and 1200 miles from you, but it's an example of what's out there..
https://kalamazoo.craigslist.org/bik...651504036.html
https://kalamazoo.craigslist.org/bik...650118849.html
https://kalamazoo.craigslist.org/bik...631099510.html
https://grandrapids.craigslist.org/b...651435955.html
Yes...I've been keeping my eye out for XL frames on CL...not too many right now, other than a Specialized Crosstrail that may be promising. I'll keep looking...
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1916 Post(s)
Liked 310 Times
The Ogre sounds like it would be a great bike for you and for something that would give off a totally different vibe to the Ogre, is the 2019 Giant Roam 1.
Quoted: 76 Post(s)
Liked 19 Times
I'm an inch shorter than you and it took forever to find a frameset, complete bikes were a little more common.
Quoted: 590 Post(s)
Liked 445 Times
Suspension is for absorbing bumps, for the purpose of keeping your tires on the ground and increasing traction, typically while cornering at higher speeds. If you aren't riding bumpy stuff fast, forget the suspension, and use that money to buy a rigid frame with better components.
Great advice...and thanks for bringing the suspension decision into an easily understood description! I don't foresee riding bumpy stuff fast anytime soon.
Leaning toward the Ogre...it feels like the best mix of features and functions for what I'm looking to do.
Thanks all!
Thanks all!
Likes For GrumpyBear27:
For your riding a hybrid would be suitable. Get the widest tire clearance as possible (regardless of your weight). Very few can use wider tires (my Toughroad can take 2.25" and is an absolute exception in that regard).
A cheap suspension fork is not useful, and for your style of riding not needed. Especially not with larger tires.
Obviously you have to buy what the market provides and often that meas they only give you wide tire clearance with a suspension fork. but there is no engineering reason for those two to be together.
Likes For HerrKaLeun:
Quoted: 42 Post(s)
Liked 7 Times
I have the the DS and I regret getting a bike with a suspension although I love almost everything else about it. I keep it locked out all the time now and would rather have saved the weight with a rigid fork. I’ll probably be upgrading to gravel before next season.
Well...I picked up the XL Bruised Ego Purple Surly Krampus last week and so far it's been awesome! Took her out for some trail rides over the weekend, and am cruising around the neighborhood with my family.
The bike fits me so much better than my previous L Giant Rainier from 2006...much more comfortable and I am really liking the SRAM components. Riding is fun again!
Thanks to everyone for their advice and input. I'll post a picture once I get a few more posts under my belt!
Hybrid
I bought a Trek Verve 2 last year at 270 lbs. The stock tires were 700x45 and has worked well for me. I've even taken it on some mild single tracks with the grandkids. I'm down to to 220 and replaced the tires with something more towards road tires they are 700x35. The bike gets close to 100 miles a week put on it and I believe that it was a great purchase.
I've ridden both the Ogre and and Krampus multiple times..you can't go wrong. You might be surprised how little you need suspension with large volume tires and reasonable pressure.
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
I don't know why they would be suggesting suspension forks for the type of riding your are planning. Are these beach trails terribly bumpy?
Being a heavier rider does not necessarily mean you are better off with a suspension fork... in fact I find the opposite to be true. My experience is that for rider weights above ~250 lbs, most OEM forks are pretty overwhelmed. .
Likes For Wilfred Laurier:
Bikes: 1986 KHS Fiero, 1989 Trek 950, 1990 Trek 7000, 1991 Gary Fisher Hoo Koo E Koo, 1992 Trek 1400, 1997 Cannondale CAD2 R300, 1998 Cannondale CAD2 R200, 2002 Marin San Rafael, 2006 Cannondale CAAD8 R1000, 2010 Performance Access XCL9R
Quoted: 284 Post(s)
Liked 385 Times
I ride a 29er now and again. It's a Perforance Access XCL 9r, and it is a fun ride on road, and nice on the mild trails I ride. I could likely swap in a rigid fork, honestly, and keep it locked out when on pavement. I'm 6'1", formerly 378 pounds. Currently 263. I guess I use this bike more as a hybrid, than MTB. And I do have a couple road bikes.
I will say, at my heaviest, I quit riding. I felt so top heavy I was afraid I'd fall over no matter what bike I was on. I've been riding again from 320 down...
