Good housing length
Passista
Quoted: 868 Post(s)
Liked 721 Times
Looks OK. It could be even a little bit shorter to avoid that downward curve near the frame stop.
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
It looks like the right length, but is that shift cable housing? If you use brake cable housing there is often too much slop inside to reliably get accurate indexing, esp. on a rear derailleur.
Quoted: 18 Post(s)
Oh totally forgot to specify, this is a shifter. With that in mind, everyone who said it was ok, do you still hold that opinion?
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Yes, it is fine. You could even make it just a tad shorter if you want. But you don’t have to.
Quoted: 569 Post(s)
Liked 583 Times
Too long, especially with compressionless housing it should make a smooth transition from parallel with the top tube to parallel with the seat stay. Especially with your situation where the cable fixed at both ends it can be shorter, if either end moves (brakes, FD, RD) it is good to check at the point the cable is tightest.
Quoted: 169 Post(s)
Liked 84 Times
It will work fine.
Myself, I would shorten it just a bit so that it flows with the cable lines.
jdefran
Classic & Vintage
14
09-29-13 02:31 PM
Gee3
Bicycle Mechanics
14
03-24-11 09:19 AM
