Rear Free Wheel with Quick Release Safe?
Quoted: 7 Post(s)
A bike shop I used in the past recently me told me this, "Having a rear free wheel set on a quick release is sketchy, un-safe practice and is something we wouldn't risk our reputation on." What do you guys think?
Quoted: 4805 Post(s)
Liked 3,927 Times
With rim brakes and horizontal dropouts and a poor quality or design quick-release or poor attention to detail, yes. Following basic good practice and using a reputable quick-release with an internal cam and steel skewer, not an issue. Been done for 90 years and millions of miles.
Ben
Ben
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
As above, BITD when bikes had horizontal rear dropouts to account for poor alignment, QRs could allow the wheel to slip if something went wrong. Almost all modern bikes have vertical dropouts and the force from the chain pushes the wheel's axle into a solid part of the frame.
There are a few cases I can think of where the rear wheel slipped during riding. It is much more likely on cheap bikes that have been converted to QR as the dropouot thickness is too little for the QR to squeeze on before it bottoms out against the end of the axle. If doing this conversion you must cut the NDS of the axle down by a few mms. It generally slows or stops the bike, but is not a catastrophic failure.
If the QR on the front wheel lets go, the results are generally much more severe.
So what bikes does this shop sell that have no QRs on their rear wheels? Do they disassemble the hub on every bike and install a nutted axle? Because every adult bike from almost every bike brand comes from the factory with F&R QRs. Only bikes with internally geared hubs, and single speeds, come with nutted axles.
Perhaps you or they meant "fixed gear" instead?
If so, I've ridden for years on a FG/QR set-up with zero problems.
That being said, get a proper track style hub for FG riding w/ track nuts and have at it.
Choosing and properly operating a QR as @79pmooney notes is SOP.
edit: Is this some shop shilling the "danger" of QR to sell a bike w/ disc brakes and through axles as the "safe" alternative?
If so, don't go back there.
-Bandera
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,434 Times
IMO, sounds like they are trying to sell you a more expensive bike. I have been road biking for 45+ years. All of it with quick release skewers. Never had a problem not due to my not tightening the skewer enough. Look at some video to get the correct way to use the QRs.
52psi
Quoted: 790 Post(s)
Liked 802 Times
I ride older bikes and expect a certain level of knowledge to have slipped through the cracks over the years.
But that? I'd be looking for another bike shop. If that's not an option I'd seek out a better-informed person within the shop at the very least.
Quick releases require a certain minimal level of mechanical competence. More and more products are being designed on principle that entire population of users are complete morons. Designing for the dimwitted prevents legal problems. Also limits choices and degrades performance.
Most common error with quick releases is using them as wingnuts. Any who would even attempt doing that fail the test and should not do anything mechanical to a bike ever. That is probably a third or a quarter of all quick releases ever made. Past 30 years there has been an endless stream of external cam quick releases. Basically not safe, sell like hotcakes. Used on majority? of higher priced QR-equipped bikes for years now. So the pendulum swings and we go from dismal performing external cams to through axles.
One of my bikes in regular rotation is equipped with pre-war FB/Campagnolo QRs. Over 80 years old. Probably among the first few thousand ever made. No problems.
Bikes: 1970's Piasentin Super Vitus 971, 1979 Carlton Professional, 2005 Trek 5000, 2011 Niner EMD, 2018 Argon 18 XRoad, 1990 Diamondback Master TG Centurion
Quoted: 56 Post(s)
Liked 73 Times
The only kind of bike I would not use a rear quick release on would be one with fixed gear (track or fixie).
Quoted: 741 Post(s)
Liked 818 Times
In 55 years of racing, commuting, touring and just cruising around with QR freewheel bikes, I can count on one hand how many times the wheel has slipped in the dropouts. The momentum of the bike will carry you along if the tire tire contacts the frame. Usually you hear it, and have time to stop and reset the wheel in the frame and adjust the QR. The most recent instance of this happening was on a friend's carbon bike with QR and modern cassette. He stood up to finish a hill, the wheel shifted, locked up, and he went over the bars cracking his helmet and his one piece carbon bar/stem combo. Stuff happens. You could also get struck by lightning. Find another shop.
Quoted: 645 Post(s)
Liked 797 Times
How not safe? External cam QRs are fine in the right application ie. when used with vertical dropouts, which are found on the vast majority of modern bicycles. The only place I would require an internal-cam QR or a solid axle with nuts would be with horizontal dropouts
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
What sort of bike were you looking at? Because the statement is an odd one, and doesn't really make sense to me in isolation.
Le savonnier
Bikes: I can count 'em on one hand
Quoted: 729 Post(s)
Liked 602 Times
I remember a discussion at work a few years ago that went something like this:
Co-worker: "Make it idiot-proof so anyone can do it."
Boss: "Oh, you don't want to do that, they'll just make a better idiot."
Anyway, as others have said, it's time to find a different bike shop. I've been riding QR rear wheels for decades without issues.
Likes For johnnyace:
QR lever has to be really tight* and the axle rnd has to bite into the metal ..
* internal cam type can exert more force ..
as you close the lever, the resistant force, it should leave a mark on the palm of your hand with the lever.. 'that' tight..
Likes For fietsbob:
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
The correct amount of force/clamping power can be achieved with either an external or internal-cam design QR. The internal cam design just allows you to get that same force more easily. IOW they're probably better suited to the frail and weak.
OP, if you haven't gone missing in your own thread, read this:
https://www.sheldonbrown.com/skewers.html
Quoted: 604 Post(s)
Liked 1,063 Times
I guess 6 of my 7 bikes are unsafe, better update my will. What a hack!
Tim
Tim
Quoted: 7 Post(s)
Thank you all for your input. To give you more context, I visited this bike shop about 3 years ago to get a new rear wheel for my 1994 Trek 800. Without my permission, they installed a solid axle wheel instead of quick release one that came with my bike. Although the new wheel has performed well, recently, I have needed to remove the wheel, and I greatly miss the convenience of the quick release system. So I posted a negative Google review for that bike shop, and part of the owner's reply to my review was the warning of the safety issues of using quick release on a rear free wheel.
Quoted: 604 Post(s)
Liked 1,063 Times
Tim
Quoted: 1221 Post(s)
Liked 629 Times
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
In fact, up until the 1970s, Campagnolo offered quick releases as an option on their track hubs:
Likes For JohnDThompson:
Quoted: 56 Post(s)
Liked 73 Times
The only reason you don't see quick releases on track wheels is because track regulations often forbid them out of concern that a closely-following rider's front wheel could disengage the lead rider's quick release. Unless you're riding on a track in a pursuit event, a quick release track wheel is not a concern.
But your explanation makes far more sense.
One issue common, multi-speed freewheel rear axles had*, was metal fatigue breakage..
a solid axle stronger than a hollow QR type .. But the QR still held the 2 parts together
after the axle broke..
* because the right axle bearings were closer to the bike center line than the axle end
so axle flexed a little, often.. as you rode..
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
Generally, I'd expect a shop (of any kind) to ask permission before doing work I did not ask for or substituting a different product. This at least gives the customer the option of going elsewhere. I understand that bike shops may refuse to perform some services due to liability issues, but it's not a good excuse for substituting something different without consulting the customer.
As you can see from this thread, most riders have no issues with QR rear wheels. Same here: the only time I ever had an issue was with a very cheap MTB single speed wheel with equally cheap QR skewers, in a very beat up MTB with horizontal dropouts (it was a low-budget winter build). On one occasion, the wheel slipped, causing me to stop and get grease on my hands on the way to work. After replacing the cheap QR skewer with a better one, no issues.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Maybe you misunderstood the shop person. Their statement as you have relayed it is strange. The only time in 40 years I've had a properly mounted QR wheel slip in horizontal dropouts is ... never.
And the only time I've had a properly mounted QR front wheel fall out of non-lawyer-lip fork ends is again ... never.
Cycleway town
