Freaking tires
Quoted: 130 Post(s)
Liked 24 Times
Freaking tires
What's the deal with modern tires and rims? I'm talking regular clinchers not tubs, or tubless. I've been fighting with a tire for over an hour, hard to remove hard to remount, seemingly impossible to mount straight. I've been riding for 40 years and remember when tires where easy peasy to get off and put back on again. What if anything are we gaining from modern tires being such a pain in the arse? currently arguing with Panaracer GravelKing Tire Slick 650 x 42 on mavic rims.
Quoted: 1872 Post(s)
Liked 692 Times
I'm currently struggling with a 25mm Conti GP4000 on a Vittoria wheelset. Sooo tight. Never had a problem with these tires before but I think there are just some tire/wheel combos that don't work well together. I've never had a problem with a Panaracer tire before, on several different wheelsets.
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 130 Post(s)
Liked 24 Times
What do you mean by "mount straight"?
Liked 692 Times
Tires are either on or they aren't. If they're on and they are wobbly then it's a manufacturing defect. Clement had this problem a couple years back. If it's wobbly and it's not a manufacturing defect then it's the bead that isn't set in place yet.
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 1217 Post(s)
Liked 187 Times
Panaracer has an issue with out of round/true tires. Of the 12 tires I've purchased from them since 2015, 3 have been severely out of round to the point that it could be seen and also felt while riding. If you've got an even bead line all the way around and it's still wobbly, the tire was made wrong.
Quoted: 130 Post(s)
Liked 24 Times
Life Feeds On Life
Bikes: Too many Motobecanes
Quoted: 4426 Post(s)
Liked 4,528 Times
My thumbs are always bloody I finally bought a Kool Stop tire bead jack. But I remember the days where changing tires was easy. I had a few cussing episodes with modern rims and tires.
Quoted: 1218 Post(s)
Liked 298 Times
IMO panaracer/mavic is a bad combo.
I've always struggled to get the bead set with it. inflate, deflate, pry, inflate, pry some more. add soap to bead, over inflate....
^ it really makes a guy think about changing a flat along side the road with that kind of a headache.
then again my WTB mtb tires don't like mavic wheels either. However, a wrap of gorilla tape and going tubeless helped heaps. I can actually get both beads down in the valley. it mounts by hand and pops right into place with a floor pump now.
Bikes: TCX & CAAD3 SAECO
Quoted: 147 Post(s)
Liked 118 Times
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Liked 415 Times
It is because of tubless. There are no "standards" so to keep from getting sued or reviews of blowoffs, wheels tend to be made with a larger diameter, and tires with a smaller diameter, sometimes with a stiffer bead.
make sure you get the bead in the center channel.
Also, I've just given up after mounting tires by hand for decades, and I bought kookstop tire bead jack. It helps.
https://www.amazon.com/Kool-Stop-Tire-Bead-Jack/dp/B001AYML7K
Liked 298 Times
I just installed gp5000 regulars on my Caonnondale stans hollowgram wheels with no levers. I almost was ready to go tubeless, but I wasn't going to wait on the 28c tubeless tires. ( side note: the 28c gp5000 are a dream ride on the supersix!!!)
Liked 692 Times
I always needed levers for my 4000sii on my Mavic wheels.
2019 Salsa Warbird
2019 Salsa Warbird
Liked 298 Times
the 25C stock schwalbe 1 one were 215g with a kendra 23/25 tube 330g measured 27
the 28c gp5000 336g with a conti race light tube 77g for 313. measuring 28.ish
was it worth the money for 1.5 mm? Absolutely!!!!!!! the ride quality and RR difference is black/white
Liked 692 Times
disc brake helps. as does the GP5000 being truer to size. Fresh install was measuring 28.2 - 28.5 I didn't recheck after a ride.
2019 Salsa Warbird
2019 Salsa Warbird
Liked 298 Times
LOL love,
.....but I'm down a gravel bike. I sold the Trek crossrip, and was ready to pull the trigger on a Revolt advanced. I did not though.
so now I just browse "Cyclocross and Gravelbiking (Recreational" enviously. the 28c purchase was just to tide me over until I get something that fits bigger tires again.
Liked 692 Times
LOL love,
2019 Salsa Warbird
2019 Salsa Warbird
