Is this FSR worth $700
2001-2002, I think it's a 2002 has all stock components of the 2002, Rockhopper FSRxc, no dents or scratches.
here are the specs:
FRAME Specialized FSR A1 Premium Aluminum frame, butted, 76mm rear wheel travel, disc compatible
FRONT FORK Rock Shox Judy Special, 1-1/8" threadless
REAR SHOCK Fox Vanilla FLOAT
HEADSET Tange Seiki AheadSet, 1-1/8" threadless
STEM Specialized alloy, 10 degree rise, 1-1/8" threadless
HANDLEBARS Specialized alloy, flat, 600mm width
GRIPS Specialized Double Density Kraton
FRONT BRAKE Forged alloy, linear pull, black anodized
REAR BRAKE Forged alloy, linear pull, black anodized
BRAKE LEVERS Shimano ST-M510 , Deore (also available with Magura Julie, hydraulic levers)
FRONT DERAILLEUR Shimano Deore LX, e-type, top pull
REAR DERAILLEUR Shimano Deore LX
SHIFT LEVERS Shimano Deore
CASSETTE Shimano HG, 11x32, 9-speed
CHAIN Shimano, 9-speed
CRANKSET Specialized Forearm II Sport
CHAINRINGS 44T alloy x 32T steel x 22T steel, Super Shifter III
BOTTOM BRACKET Shimano BB-LP-28, square taper, e-type , 113 x 68mm
PEDALS Specialized, alloy cage, w/toe-clips, straps, reflector
RIMS Weinmann ZAC-19 double wall alloy, machined sidewalls, 32-hole
FRONT HUB Specialized alloy, 32-hole, with ground bearing surfaces, quick release
REAR HUB Specialized Megaphone with ground bearing surfaces, 32-hole, quick release
SPOKES 15GA, stainless, with brass nipples
FRONT TIRE Specialized Team Control SL Sport, 26 x 1.9", blackwall
REAR TIRE Specialized Team Master SL Sport, 26 x 1.9", blackwall
TUBES Specialized, presta valve
SADDLE Specialized Sport MTB with Body Geometry Technology (OEM)
here are the specs:
Alright, for one this bike new would cost around like 1000, right? And its now a year old, and they are still charging more than its worth. The stock components on the bike really, well aren't decent quality. While the suspension design is good, the bike itself isn't. Personally I am not a fan of any f/s bike with a price tag under 1,250, because at that point you start getting quaility stuff for the money.
So, if i got this brand new from a bike shop, with full waranty and everything. I can get it for a deal for $900. Would that be worth it? It would be with the specs above, but the 2002 version.
Josh
Josh
Wood Licker
Bikes: Trek Fuel EX 8 27.5 +, 2002 Transition Dirtbag, Kona Roast 2002
Quoted: 23 Post(s)
1 year old a ridden with no warranty. They should start at 50% and you should haggle. Their starting price is too high. This bike isn't high end enough to maintain a decent price. If it were a high end bike it could retain some value due to the quality of parts.
thanks again. Yet another save from getting ripped. Don't know what I do w/o you. Do you think it's worth to get it brand new? With the whole lifetime warranty? I can get it for $900 at my LBS + infinite tuneups for a year..?
Thanks for ur help
Josh
Thanks for ur help
Josh
Wood Licker
Quoted: 23 Post(s)
Lifetime warranty. Ask one question. If I go a little extreme (say a 5ft drop) and I break the frame is it covered? This is a trick question but seriously 900$ new is a good bike. That works out to hmmm 1400 canadian. That gives you a lot of choices in a bike.
Jubalayo Unogwaja!
WallaWalla!
Do give you some comparison, I saw a new 2001 Specialized Enduro for $1000.00 US at a LBS this spring. A bike far superior to the one you were looking at. Try E-bay, you can get some killer deals for $750.00.
Jeff
Jeff
Well, those bikes were on e-bay. LoL. Anyways found another one for $575. Mavic X-221 rims,Ritchey post and spec evolution seat,Speed Dial Avid 1.9L levers,Shimano Deore XT rear and LX front,Stronge Arm 2 Cranks and Demension pedals,Fox racing shock rear and Manitou front shocks.
Highly thinking of getting this.......
Josh
Josh
