I don' want to start a fight: clipless or toe clips: PART 2
Bikes: I hate bikes!
Quoted: 431 Post(s)
Liked 710 Times
So I posted here about going clipless and got a lot of feedback(Thanks!) and took the plunge! I bought a pair of Shimano/SPD platform pedals and a pair of Shimano shoes. Not really road or mountain shoe, all lace up, no velcro and I can walk in them.
I really like using them and have found them not that difficult to use. My question pertains to my feet & the shoes. I normally wear an 11 shoe/sneaker and bought a 45 which is supposed to be 10.5-11. But now by the end of my commute (16mi each way) my feet are falling asleep! Off the bike the shoes feel snug I can walk and they feel ok, on the bike they feel to small, like my toes are getting scrunched.
I have the cleats all the way forward, closest to the toe. Anyone else experinece this? Is this a breaking in thing,an adustment thing or the shoes are to small? Any help would be appreciated. BTW, I rode in a couple of rainstorms, sweated a bunch and threw the box away so returning them to the LBS is probably not an option. My thought initially was that the shoes that were a wee bit smaller would keep your feet from sliding around (inside the shoe). Am I off base ?
LF for the accentdeprived
Probably too small. I gather that it's not unusual for clipless shoes to seem comfortable when you try them on but prove too small when you're actually riding.
BTW, pushing the cleat all the way forward doesn't soud like a good idea. Normally, the pedal spindle should be right under the balls of your feet, so probably further back.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,219 Times
Stuart Black
Stuart Black
Easily distracted...
Bikes: Surley Cross Check
The do seem to run a bit small.
I usually wear 10.5-11. The shimano spd MTB shoe I have equates to a 11.5
I do appreciate the extra space when my feet start to swell on long rides.
XL commuter
I have a pair of walkable, lace up Shimano's also. I initially had foot discomfort because I was lacing them too tightly. Your feet will swell up a little as you ride. As long as you have a little room in the toe area, just try lacing them up a little more loosely. If your toes feel crammed in them, you'll need to go up a size. I wear a size 12 shoe, my Shimanos are size 47. Also, as mentioned before, adjust the cleats to get the ball of your foot over the pedal spindle.
Oh, one last thing, tuck in those laces.
Life is good
Bikes: 2018 Lynskey Helix Pro
Quoted: 522 Post(s)
Liked 10 Times
I usually wear a 10.5 and my shoes are all size 45. https://www.nashbar.com/sizesearch.cfm
Looks to me like you need a size 45.5 or 46, and if your feet are wide like mine (10.5 EEE) you may need wider shoes.
My commuter shoes are wider than many other mtn shoes I've tried. I have Exustar SM600 and Shimano M120G.
Ain't skeered!
Shoes could be too small, but try moving the cleats to where they are positioned right under the ball of your feet. If the cleats are moved all the way forward you are putting too much stress on your toes.
34x25 FTW!
Bikes: Kona Jake, Scott CR1, Dahon SpeedPro
SERENITY NOW!!!
Bikes: Haro Vector, IRO Rob Roy, Bianchi Veloce
And make sure your cleats are adjusted properly. Sit on a ledge and let your feet dangle taking notice of whether they point straight ahead, or to the side and adjust your cleat accordingly so you don't mess up you knees.
HHCMF - Take pride in your ability to amaze lesser mortals! - MikeR
We demand rigidly defined areas of doubt and uncertainty!
Commuter First
Also, if you are going to use these shoes through the winter, you might want them a bit large to accomodate bigger socks.
One additional note to cleat position.
The smallest change can make the biggest difference. I have tweaked one cleat a few degrees in one direction and that helped a heck of a lot. An even bigger change occured when I moved a cleat forward about an 1/8th of an inch.
Tweak...ride...tweak...ride...etc
Muscle bike design spec
Bikes: 70 Atala Record Proffesional, 00 Lemond, 08 Kestrel Evoke, 96 Colnago Master Olympic, 01 Colnago Ovalmaster, 76 Raleigh Gran Sport, 03 Fuji World, 86 Paramount, 90 Miyata CF, 09 Ritchey Breakaway CX, Bianchi Trofeo, 12 OutRiderUSA HyperLite
Shimano size 47 for 10.5/11 shoe
Korval is Ships
See my Hyperlite 411 it's the photo model on OutRiderUSA web page
Bikes: Serotta road, Ellsworth Truth mtn, Lightspeed tandem, Kona Smoke
I use a custom footbed in my road shoes that made a huge difference in comfort on 4+ hour rides. When I got my shimano lace-ups I took the inner footbed out and I put my custom footbed in it's place.
You might find a low cost replacement footbed at a local drug store that may help free up a little volume in your existing shoes and maybe even improve comfort. Just a thought.
Bikes: 700c commuter
I've got the same exact set-up. My shoe size is a twelve though. I've got the cleats pushed all the way back. The ball of my foot is slightly past the spindle, but works for me.
ya, mine seem slightly too big when I am walking and then just perfect on the bike (I have Specialized, MTB Sport shoes) It also depends on the socks. I have some specialized coolmax socks which work very well but with thicker socks (ie normal sports socks) it can be slightly less comfy. Fortunately I bought my shoes slightly big as I am still growing
cut my gas use in half
Bikes: walmart beater, Dahon boardwalk, A bike, schwinn tandem
The smallest change can make the biggest difference. >>>snip>>>Tweak...ride...tweak...ride...etc
but, really, thanks for the info, I am considering clipless, and i know NOTHING.....
