bearing size for campy hubs
just ride
Bikes: specialized roubaix, dawes sst ( steel single speed)
Quoted: 5 Post(s)
A lot of folks recommend changing the bearings when you grease/service the hubs and I want to get on board. I use mirage/veloce level hubs from the mid 90's but haven't been able to find any literature or specs identifing the precise bearing sizes. They appear to measure 3/16 inch for the front hub; and 7/32 and 1/4 for the rear. Does anyone know if this is correct ? Is there some more precise metric size I should be looking for ?
Also does anyone know what grade I should buy ?
that sounds right to me. grade 25 is good .
Last edited by bikeman715; 05-22-08 at 12:00 PM. Reason: forgot the grade of bearings
Bikes: Trek 7500 FX (2005)
Check out:
https://www.branfordbike.com/hub/hub03.html
and/or https://www.bikecircle.com/forums/tec...ing-sizes.html
Might help.
Bill
Might help.
Bill
His: Trek 7500FX
Specialized Roubaix
Spouse: Trek 7.5FX
His: Trek 7500FX
Specialized Roubaix
Spouse: Trek 7.5FX
