Thoughts on the current crop of pedals, best choices for sprinting?
I've been running Speedplay Zeros on all of my bikes for years, now considering a pedal/strap setup for sprint practice and events (after hearing about friends crashing out from clipping out).
Is there a secure way to combine the Speedplays with straps?
If not, which pedals do you recommend for using with straps, what is best and why? And which method do you prefer to secure your straps?
Thank you.
Thank you.
Bikes: Serotta steel track bike, Specialized MTB
Quoted: 99 Post(s)
Thank you.
Thank you.
Quoted: 1851 Post(s)
Liked 678 Times
I have Speedplay track pedals and have used BLS spindle straps. The straps are fine, though I don’t use them much. They are kind of a hassle. To keep them in place, I used larger rare earth magnets, held to the straps with Gorilla tape.
Although not everything the pros do is something that should be copied or repeated by us mere mortals, the large majority of elite sprinters use Shimano SPD-SL or Look Keo pedals/cleats. Plenty of elite enduros and pursuiters use Speedplays, though.
Having myself pulled out of Keos whilst using straps (worn cleat) on a start, I think it might be worth considering a separate pedal/cleat system for the track, even if you still like to ride Speedplays on the road.
Anyone have a preference of BLS straps compared to G-Race?
NJS straps seem to be making a minor comeback in the pro ranks. I think a couple of the Dutch sprinters are on them.
Liked 678 Times
I've not been terribly impressed with my BLS straps. The quality doesn't seem great - they are showing a lot of wear after one season. The material also is incredibly soft, so they don't sit up on their own well, meaning I have to completely unloop them, clip in, then loop the strap and velcro it. It's not just a matter of tightening them. (This is one of the main reasons I kind of stopped using them.)
Can't speak to G-Race.
Also, I'm currently out of town, but if you want to see picks of my magnet set up, I'll get some this weekend. It's a cheaper solution than the Cruz option, and it doesn't require tools to remove, so if you aren't running straps, you still have both sides of the pedal.
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
LOOK KEO (spring and blade) max release tension is maybe half of what you can dial in on SPD-SL. I can pull up (good pedal form) and out of LOOK pedals. If you are strong and use them, use straps.
NJS straps are the best engineered product for the job. The clasp is a modern marvel. The fact that they stay open as you try to get into them on the boards is awesome. NJS straps don't stretch or disintegrate. BLS (and the like) aren't "more aero". That's just marketing.
Elitist
Liked 92 Times
The ones that I've used in the past are Toshi and Kashimax.
Hard to find now a days, but the Shimano Dura Ace SPD-R (7700) pedals are worth their weight in gold for track cycling.
Lapped 3x
BrainInAJar
Track Cycling: Velodrome Racing and Training Area
7
01-08-12 08:16 PM
time bandit
Singlespeed & Fixed Gear
19
02-04-11 11:10 PM
