Gearing
Gearing
Hi, I have an old adventure/gravel touring bike where the mechanicals are well past their use-by-date and I'm thinking of replacing them and correcting a couple of issues at the same time. I am looking for as wide a range of gearing as I can get - so looking at my needs I considered
Now with a 30T small front chainwheel I need a 42T rear cog to get the 20 gear inches lowest speed. In fact it would be 19.5 gear inches. A 11/42 cassette is readily available. Is there a rear derailleur that will handle this? A search gives me the Shimano XT RD-M8000 Shadow+ 11Sp long cage rear derailleur. According to the specs this has a low sprocket_Max.42T(2x11-speed)[TICK], max. front difference 18T[TICK], Total capacity 47T[TICK]. So this looks like a goer.
So to summarise:-
- what top speed do I need - using my road, MTB and gravel bikes as examples I plonked for a minimum of 110 gear inches
- what bottom speed - after experiencing many hills with loaded panniers I decided a maximum of 20 gear inches
So to summarise:-
- GRX FD-RX810 11 Speed Front Derailleur
- GRX FC-RX600-11 46-30T 2x11 Speed CrankSet
- XT RD-M8000 11Sp Long Cage Rear Derailleur
- SLX CS-M7000 11-Speed 11-42 MTB Cassette
- Jtek Shiftmate to adapt MTB derailleur to Road shifters
- 105 RS-505/BR-RS785 Road 2x11 Lever/Caliper Set
Quoted: 3460 Post(s)
Liked 1,466 Times
I have a 700c touring bike with a road triple crankset where I swapped out the 30T granny gear for a 24t. 11/32 cassette. My lowest gear (24/32) is 20.7 gear inches. I also swapped out the 52T big chainring for a 46T, that has a highest gear (46/11) of 115.5 gear inches.
A lot of people use triples that have stock gearing that is lower than what I used that might meet your criteria even better.
Any reason you are not considering a triple? They are getting a bit harder to find but they are still readily available if you look for them.
check out pathlesspedaled for the fellows vids on mixing and matching stuff that goes to 42t that works but officially shouldnt.
a 20-100+ gear inch range is smart, although I wouldnt go past 110. One of my bikes has a 104 top gear and while I spin out at about 50-55kph, I prefer to have the lower low gear for the weight I carry on that bike, and its very rare that I need to pedal past that 50k 30mph speed , but am fine going along at 40-45kph the few times I have long downhills.
Quoted: 598 Post(s)
Liked 283 Times
I run a couple of 46x30 cranks with 11-34 cassettes but I personally don't care for those large last few steps at the low end of that 11-42. An 11-40 gets you down to 20" with smaller steps. Let us know how it works out as I would be very interested.
Macro Geek
For my first 10 or 15 years of touring, my bikes always had doubles, and although I didn't realize it at the time, the gearing was never low enough for significant hills.
When I finally upgraded to a triple, I couldn't believe the difference those extra low-end gears made. During the following twenty years, I have replaced drive trains three or four times as they wore out, and I each time, I reduced the low gears a bit more, even when it meant sacrificing the top-end gears.
I would rather spin-out at the high-end once in a while rather than struggle while climbing for even a minute. I figure I spend much more time climbing hills than bombing down them, so I choose my gearing with that in mind.
Likes For acantor:
Low Gear Range: Road Shifters & Gears For Easier Hill Climbing - CyclingAbout.com
Thought this was interesting take on multiple options. Might be something there you have not thought of.
Seems like your on the right track.
I'm going from 11-32 to 12-36 on my old 9 speed triple, 48-36-26 because it's easy and cheap.
I have recently renewed the drive train on my gravel/touring bike. I use a Sora triple in front, but only use the small and middle chain ring. Previous to the recent change, I had a 26/38 tooth combo in front, and a SRAM 10-42 cassette. I only used the 26 tooth in Alaska on some very steep climbs, with luggage. Skip ahead a few years, I have worn out the 38T chainring, using it like it was a 1x11 drive. I really enjoyed the 38T, it was everything I needed, anywhere, on training rides. But it wore down to shark's teeth. Having recently discovered the Path Less Pedaled channel and researched gravel bike gearing, I went with a 30/46 front and kept (replaced with identical) the 10-42. Practically speaking, it's all I should need, if I pack light enough. Oh yeah, I run 700x40c tires. I can always put a bigger chain ring on the outside spot of the crank, but I have never felt the need, even when I ran the 38. With the 46, I'm sure that I have plenty of top end.
Likes For DeadGrandpa:
Miles to Go
I agree with Robow's statement... I would rather give up some top speed for better stepped gearing.
Likes For timdow:
Likes For hilltowner:
Useless Member
Quoted: 380 Post(s)
Liked 181 Times
20 gear inches?
The hell with that.
Quite happy with my 15.3 GI for my aged worn knees and Ogres 700x 2.3' tires.
YMMV
The hell with that.
YMMV
The other day with my bike that has a 16.7 gear inch low, I rode it up a short steep section unloaded beside my wife pushing her bike up the hill, so that we could talk and I hate pushing bikes.
3.5kph and easy to ride, this was the slowest I've ridden this bike, but waa able to hold this speed because it was so light. I've been riding all winter on snow so my balance is pretty good, so I'm sure this helped.
but all that to say that lower than 20 g.i. is always a plus on a touring bike.
Liked 1,466 Times
I sized the chainring that I use for touring on my Rohloff bike to give me 3.5 mph at a cadence of 72. That is a low gear of 16.2 gear inches. Sometimes if the wind is not blowing and the conditions are good, I might find myself pedaling up a hill in a cadence in the 60s, but I am not much below that 3.5 mph that I consider a minimuim.
That said, my derailleur touring bikes have a lowest gear of 19.3 or 20.7 gear inches and I manage to live with those bikes too.
Thanks, it was actually fun, we were chatting and I looked down at computer and saw the 3.4,5,6 just as muy wife said, yup we're going 3.5....
I had hundreds of snowy slippy front wheel understeer moments this winter, and like I wrote in my thread about winter riding, it became a game for me to not put a foot down, so keeping the power on and using body language to push through the understeer, so going up this hill with one light pannier on pavement was easy more or less.
but as for the lowest gear inch, like you say, the old adage of 20 to 100 is still pretty valid, although for unloaded riding I do prefer a taller high gear. I like the 112 g.i. on my lighter bike to be able to spin up to close to 70kph.45mph, so if this fellow rides a lot unloaded and is comfortable going fast, he very well may like a taller top gear.
I have a friend who never goes past 40kph and she really doesn't need a 50t , especially given that her knees and low gearing that isn't low enough kill her on climbs.... but she has been ignoring my loud comments for years and won't change her bike....
Vaya 3x9
Ended up going 3X9, Mix of parts that were (covid) available.
Crankset Alivio 22/32/44
RD Acera
FD microshift
Cassette 36-12
Shifters retroshift friction, learning curve going back to friction but getting better at it and like the sense of satisfaction............
Another vote for a lower range.
Bumpy dirt roads make 20 MPH feel more like 40. The uneven, unpredictable nature of unpaved surfaces makes the higher speeds more exciting, to say the least.
Palmer
Quoted: 1668 Post(s)
Liked 1,821 Times
Some 46 years ago the late Ron Shepherd formed the 'Low Gear Fellowship' and promoted what he called Bulldog gears* for cycletourists.
For easy peddling he proposed 'Ron's Rule': climb no more than 6 inches (15 cm) for every turn of the cranks. For a steep '1 in 10' hill this would suggest no higher than a 19 inch gear.
*Sometimes derisively styled 'granny gears'.
Liked 1,466 Times
I was glad I was going downhill on this 14 percent grade hill. Loose gravel like that can easily cause you to lose traction when going up a hill that steep because you are in such a low gear that you have a lot of torque on the wheel.
OP Gravel / Touring Bike finished
Well as the OP, I figure I owe all contributors a vote of thanks. Taking advice received from this and a couple of other forums I have finalised my gravel / touring bike.
This is what I have:
an original base level aluminium frame Giant Revolt - stolen, damaged, recovered, and sold cheap to me.
almost all components removed by me, and frame resprayed a very crappy black
built up with a lot of old stuff I had on hand, plus some second-hand stuff off the Net - including
Cheers
Adrian
- suspension seat post (Satori Animaris) and old Brooks leather seat
- Deore T6000 trekking 3x10 rear and front derailleurs
- Deore T6000 crankset (48-36-29T)
- Cassette (10 speed) of indeterminate origin (11-36T)
- Ultegra 10-speed levers mechanical (ST6500 series)
- JTEK Shiftmate 6 to accommodate different cable pull - levers vs rear derailleur
- TRP cable-operated hydraulic disc brake calipers
- the Deore Trekking groupset seems much more solid and reliable than the equivalent mtb and road groupsets
- love the disk calipers - great stopping power, but with the better modulation of cable operation, and compatible with the road levers
- the rear derailleur needs very careful adjustment with the Shiftmate adapter in place - so I fitted an in-line cable adjuster to fine-tune the rear derailleur on the fly.
- way more gear range than I need for no-load rides, but expect that to change once I can go load touring again when these lock-downs go away
Cheers
Adrian
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
You have made your decision, but allow me to show my 48/28T x 11-32 11-speed (24.5 - 122 gear inches). It should work with an 11-42 (18.6 - 122 gear inches) as well for those superlow gears. The next iteration will probably use an 11-36 or 11-40.
Likes For JaccoW:
I hope that all works out well for you. You should have a nice coverage of gears in the range and the 22 to 119.2 gear inch range should be more than adequate on both ends in my opinion. How well the low gear will work out depends on a few things including your pedaling style and how much you will carry.
Personally I'd have probably have gone with a two ring setup and might have even considered a single ring (39 and 11-42 for a 25.4-96.9 gear inch range). I know that most here wouldn;t approve of the 25 gear inch low, but I did a coast to coast trip with a 25.1 to 87.8 range and found it fine with ultralight camping gear (14# base). Sure, with a very heavy load a little lower gearing would be nice. Just me, but if I needed lower than 20 gear inches I'd reconsider what I was carrying.
I don't think it's necessary to have anything over 100" on a touring bike and if you give up that top end you make your life a little easier. Also if you pack sensibly you don't need super low gears either. I find something around 25"-100" range is fine.
To me having a closer cassette is nicer, you'll gain loads of time over the day and happier knees with better cadence control, especially with a lighter load.
my only personal preference is to have a low more closer to 20 g.i. partly because of a sometimes dodgey knee and being more of a skinny leg guy, ie not tractor engine torque legs.
