Tubular? rim
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Tubular? rim
I'm putting together a bike for a friend. I have a 27" front wheel here, with deep, straight sides. As I was cleaning up what appeared to be glue, I began to wonder. Could it be a tubular rim. Unmarked. Old. Concentric grooves in the rim wall. And upon close inspection, unhooked. But much deeper profile than your standard tubular rim. Can I trust a clincher on it?
Quoted: 4722 Post(s)
Liked 3,036 Times
13,516 posts, including 173 photos but no photos now?
Quoted: 1372 Post(s)
Liked 1,751 Times
The "glue" is, possibly, rotted gum wall rubber.I have seen it many, many times.
Likes For randyjawa:
Quoted: 964 Post(s)
Liked 1,451 Times
Could also be adhesive from old and long-gone rim tape, if no rim tape is present currently.
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,830 Times
Someone please correct me if I’m wrong!
There are no (production) tubular tires larger than 700c (622). We are talking modern era - post-WWII.
edit: or tubular rims
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4337 Post(s)
Liked 2,979 Times
That is definitely not a tubular rim.
That fact does not mean that no one ever tried to glue a tubular tire on to it.
I might try a low-pressure wire bead clincher on it if I were emotionally attached to the wheel for some reason - maybe ride it in a parade or something; nothing more than that. For that matter you could put on an unglued tubular and ride in the the parade too. So many options!
That is a clincher rim through and through. Looks like an old gum wall tire got melted to it from sitting forever.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
smelling the roses
Liked 901 Times
Thanks all. I just haven't been in the field long enough to be familiar with hookless rims. I jettisoned it shortly after the initial post, and replaced it with a 622 wheel I had around. Whatever got cleaned out was probably as mentioned--and old rim strip or melted down sidewalls. It came off strikingly easily with a rotating wire brush. What is history of hookless rims? Makes sense that wire bead would be the answer.
Liked 3,036 Times
At this point the story diverges, depending on the market. In Canada and most of Europe, the wired-on tyre was the preferred choice for the non-competitive cyclist. However, in the USA, there was no clear winner until the bicycle industry crashed in 1899 as result of market saturation due to increased competition. With the tyre companies suffering cash flow issues, the Rubber Goods Manufacturing Company took the opportunity to acquire the American patent rights for three of the four major players in the tyre industry, including Dunlop's wired-on. They effectively killed the wired-on, instead promoting the single tube tyre, which was cheaper and provided better long term profits. The single tube tyre used an inner tube that was vulcanized to the casing, which was then cemented to the rim, There was no method to remove the inner tube for repair, instead relying on plugs, glue injection or returning the tyre to the bicycle shop for vulcanization. The wired-on would not regain significant market share until the maverick Schwinn company re-introduced them in 1933, in balloon tyre form.
Hooked, wired-on rims started appearing in the 1970s with the introduction of high pressure tyres. However, a definite trend started with the 1976 Mavic-Michelin collaboration to introduce high performance 700C as a sports bicycle alternative to tubular rims and tyres. Hookless, wired-on slowly lost market share from that point onward but can still be found on some entry level and children's bicycles with medium pressure applications.
