Upgrading a used Rockhopper
Quoted: 20 Post(s)
I bought a used 2017 Rockhopper on craigslist for $300. The bike is very lightly used having spent most of the last three years in a garage. Now I want to go about upgrading the bike hopefully ending up with something pretty nice for less than $1k. I need some help deciding how I should spend the ~$700 upgrading the bike. This is what I'm thinking right now,
Highest priority, upgrade ASAP.
- Pedals. They're the stock plastic pedals. I want something thinner, wider and with metal pegs. It's a cheapish upgrade too.
- Drivetrain, shifters, etc. I want a 1x drivetrain, and I want higher quality shifters/derailers than the bike currently has. The 3x9 or whatever it is right now is annoying although it shifts OK for the time being.
- Fork. People will probably **** on the Suntour XCM on this bike, but I want to try riding it for a while before I change it. I ought to know was a budget coil for feels like before I start dropping money on fancier forks. It's definitely really sticky right now, but I think that's just because it needs to be serviced.
- Brakes. The brakes seem fine right now, maybe the rear needs servicing or new pads. The front brake feels fine. I think I'll eventually want nicer brakes, but they'll work for now.
- Wheels. I would only upgrade these if I want something lighter or if I have problems with the current wheels.
- Seatpost. Maybe I'll invest in something lighter if I have the cash, or maybe I'll get a dropper post. Honestly a dropper post seems more important on a hardtail because your rear suspension is your legs and not having a dropper post effectively limits your rear suspension travel.
- Seat. Just need to see if the current seat will work for me or not.
- Grips. Same as for the seat.
- Stem and Handlebars. I'll upgrade if I feel like I want to change the handling of the bike. Otherwise I think they'll work fine.
- Headset. I'll probably only upgrade if the old headset breaks or if I upgrade the fork and I need to buy a new headset for it.
Quoted: 1944 Post(s)
Liked 2,164 Times
You can convert your 3x to a 2x to start. You just have to figure out what you need for a middle chainring. You might be able to swap the small (22t?) for a 24t or ??? if you don’t need that low of a chainring.
I run a 24/34 and run the 24t where there is more climbing or I’m not familiar with the trail. On more level or rollers I run the 34t. I don’t shift a lot between the 2 chainrings.
I never liked a 3x since I’m only riding trails.
John
John
Quoted: 8281 Post(s)
Liked 9,048 Times
What kind of terrain are you riding? If you're on smooth trails the fork may be fine.
Nothing wrong with running a triple if it shifts fine and has the gearing you want. The worst thing about triples to me was mud. Mud is a good reason for a one by set-up.
I definitely recommend a dropper. It will make descending nicer. I also lower it a bit when on a steep technical climb. That could be a priority.
Good shoes and pedals for sure.
Wheels can come later after you thrash the ones you have.
Quoted: 20 Post(s)
I bought the Kona Wah Wah II small pedals. Next I'm going to clean the lowers on the fork and take it for a ride to see how it feels. I may service the uppers of the fork if it still feels sticky, and I think it would be an instructive thing to do anyway. Depending on how I feel about the fork after a few rides I may upgrade the fork before the drivetrain or brakes. I think I'd also get a dropper post quite soon, but that depends on how the bike rides and what I end up riding. The drivetrain will probably be upgraded before the brakes.
I think I'll be riding blue and maybe black trails. I live in Colorado, so the trails are often pretty rocky.
Liked 9,048 Times
I don't know about the fork you have but I have a low-end Fox 36 and it's pretty great for rocks and bigger hits. It doesn't deflect and remains stiff when turning. It's 160mm but they can be set up shorter.
Bikes: State 4130 Custom, Giant Trance 29
Quoted: 422 Post(s)
Liked 182 Times
Rockhoppers to my understanding have straight steerer tubes and headset. Might be limited to what you can get when you eventually want to replace.
Few that I hear are good though:
Suntour Epixon
Manitou
Rockshox Judy
Suntour Epixon
Manitou
Rockshox Judy
Quoted: 20 Post(s)
Suntour Epixon
Manitou
Rockshox Judy
Suntour Epixon
Manitou
Rockshox Judy
Quoted: 422 Post(s)
Liked 182 Times
What really amazes me, is the 2021 Rockhoppers appear to have already sold out of the large sizes.
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
Change the pedals, saddle and spend the rest on weekend riding trips.
