The Arithmetic of Hydroplaning a Bicycle ( per NASA )
#51
Quoted: 5849 Post(s)
Liked 2,683 Times
Folks debating here would do well to heed Mark Twain's very sound advice about these situations.
This is a perfect example of a straw man argument. The OP posits a claim that nobody made, namely that it's impossible to hydroplane on a bicycle, while omitting the legitimately assumed "as a practical matter".
He supports his argument but using motorcycle data points and extrapolating them down to bikes. Then uses videos of bicycles slipping in the rain, and claims them as proof without considering the more obvious reduction of friction.
Even after using his own math with actual tire widths and pressures to show that, bicycles cannot hydroplane within the speed range bicycles actually attain, he simply won't let go.
For my part, it ended yesterday when the OP twice used the phrase "all known laws of physics" which I always take as a cue.
Let's spare ourselves the time and grief and not argue a straw man theoretical position as if it were meaningful in the real world.
Likes For FBinNY:
#52
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 346 Post(s)
Liked 178 Times
This is a perfect example of a straw dog argument. The OP posits a claim that nobody made, namely that it's impossible to hydroplane on a bicycle, while omitting the legitimately assumed "as a practical matter".
Let's spare ourselves the time and grief and not argue a straw dog theoretical position as if it were meaningful in the real world.
#53
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
Oh, I don’t…it could have something to do with the giant hydroplane under the motor case. It first appears around 2:00 minutes in the video. You can see it easily at around 2:30 as he does his run towards the water. At about 3:30 you can see the hydroplane skip off the water. The best view of it, however occurs at around 7:20 minutes where you can see it under the motor case from above…it’s about 2’ wide…and just a little further on there is a wide shot where you can see that the hydroplane from the side. It’s about 3’ long and extends to the rear axle. He’s got a great big ski attached to the bike and most definitely is not hydroplaning on the tires.
Here’s a quote from Solid solutions.
You can clearly see the hydroplane “hull” under the motor case. There are other videos and pictures around of a crossing of Lake Como where they put a ski on the front wheel to keep it from diving into the water. In essence, the motorcycle isn’t so much as hydroplaning across the water as boating across the water.
If you look at other videos of people crossing water on motorcycles, they are all using some kind of skid plate under the motor case to do it. Their tires are buried in the water up to the depth of the motor case.
The bicycles in your videos aren’t going anywhere close to the speed you, yourself, calculated. Your assumptions are also wrong. No one doing time trials is riding on 30 psi tires. Using the formula you put out there, at 60 psi, the speed increases to 80 mph. From this article, that is way too low. Time trials use 130 to 135 psi on dry conditions and drop 10 to 15 psi for wet days. Let’s assume, 125 psi. Hydroplaning doesn’t occur then until the speed is 115 mph. Odd how both of those values are just about what Sheldon Brown posted so very long ago.
You’ve provided no “proof”.
I’ve hydroplaned across short bodies of water on a YZ250 with no “boat” under my motorcycle. Just start out in 5th topped out at around 70mph and losing speed until you get to the other side.
Where I’m from crop dusters will mess around and hydroplane on canals. Around 120mph they say the water under the tires just feels like concrete.
Water likes to stick to water. It’s one of those “life on earth is possible because of…” qualities.
#54
Live not by lies.
Quoted: 860 Post(s)
Liked 784 Times
That said.
I think a skinny tired road bike would need to go insanely fast to hydroplane.
Possible? Yes. Probable? No.
This comes up frequently with my kids. They ask if something is possible. I answer almost anything is possible, but the specific thing they’re asking is highly improbable.
#55
aged to perfection
Quoted: 851 Post(s)
Liked 1,278 Times
in real world wet weather riding there are other factors contributing to loss of traction.
namely any presence of dirt, oil, or other contaminants on the pavement surface. Or brand new tires that still have mold release coating on them. Or the paint used for traffic markings - treacherous in wet weather
the point is correctly made that a bike tire's contact patch has a much greater loading in psi than does a car tire. But the other calculations cited are made under very narrow test conditions and not applicable to real world conditions.
but what do I know ?
/markp
/markp
#56
Expired Member
Quoted: 3711 Post(s)
Liked 5,551 Times
but but but Motorcycles! Lakes!! NASA!!!
#57
Quoted: 1593 Post(s)
Liked 1,026 Times
The point of such exercise eludes me.
Likes For jon c.:
#58
Quoted: 1148 Post(s)
Liked 1,773 Times
But we haven't talked about air friction yet and the varying melting points from that friction. That information is as important to bicycle maintenance as well. I know my bike will melt if I go fast enough.
Omg this is a worthless read, entertaining though worthless.
#59
Quoted: 346 Post(s)
Liked 178 Times
From the study:
"The hazards of tire hydroplaning to vehicle operation are greatly increased stopping distances, and potential loss of ground directional stability. In order to minimize these hazards, it is most important for the vehicle operator to be aware of the existence of tire hydroplaning and to understand how and when it may occur. Such knowledge being assumed, certain procedures then suggest themselves to minimize hazards of tire hydroplaning where conditions are such that it may be encountered."
I experienced loss of ground directional stability. I am aware of hydroplaning and certain procedures do suggest themselves to minimize the hazards where conditions are such that I have encountered them. I think I am safer in having that awareness rather than dismissing it out of hand based upon formulas applied to landing gear. That is the point of such exercise.
Likes For L134:
#60
Mad bike riding scientist
Quoted: 6238 Post(s)
Liked 4,246 Times
The point being I READ the study to find out what it really said rather than accept what somebody who hadn't read it said it said just because somebody else told them NASA said something they didn't actually say. Why did I take the trouble to read it when somebody else already told me what it said? Because my own actual experience made me suspicious that the study didn't actually reach the conclusions stated or that the calculations etc could reasonably be extrapolated out from aircraft landing gear to bicycle tires. Bicycles are not once mentioned in the study. I think it very unlikely the authors would extrapolate their own data and research of aircraft tires to all circumstances without expanding the scope of their research. Presumably they are scientists after all. Therefore, because my own experience makes me question the appropriateness of such extrapolation, I parse the words to better understand the purpose of the study in question and its applicability to my experience.
From the study:
From the study:
I’m going to quote extensively from NASA bulletin and, for that I am sorry, but it can’t be avoided. You are correct that there is a “partial hydroplaning” as the water layer builds under the tires. Most people experience aren’t really paying attention and only notice the full hydroplaning part when their car goes spinning off the road. It is a continuum but looking at the figures, the partial part doesn’t occur until a substantial proportion speed needed for full hydroplaning has been reached. He also has this to say about speed and inflation
Most automobiles in use in the United States at this time require tire inflation pressures ranging from about 16 to 30 pounds per square inch. On the other hand, large trucks and buses in current use generally require tire inflation pressures considerably higher in magnitude, that is, from 50 to 90 pounds per square inch. These two inflation pressure bands for automobiles and buses are indicated in figure 26 along with the predicted tire hydroplaning speed of equation (5) in miles per hour. It can be seen from this figure that automobiles can encounter total hydroplaning at ground speeds considerably below the higher legal speed limits, say 60 to 70 miles per hour. Contrary to this, the higher inflation pressures used on trucks and buses yield hydroplaning speeds that are above legal speed limits and thus trucks and buses are not as susceptible to hydroplaning as are automobiles for normal operating speeds on highways.
It is of interest to note that the portion of the footprint under the side walls of the automobile tire (photograph (c) of fig. 6) is the last portion of the footprint to become detached as ground speed increases. This result indicates that higher tire-ground bearing pressures exist under the tire side walls than in other locations of the automobile tire footprint. The aircraft tire which was more circular in cross section and stiffer than the automobile tire did not show this sidewall effect…
The mistake that you and others are making is that you assume hydroplaning where it isn’t present and neglect lubrication where that is predominate. Horne and Dreher address that situation as well (emphasis added)
Low Friction Coefficients Not Associated With Tire Hydroplaning
The large mass of data just described suggests that tire hydroplaning can be reasonably explained in terms of fluid density effects alone and equation (4), derived on this basis 3 is seen to give good estimates of tire hydroplaning speed values. (See fig. 4.) Some data exist, however, that show a complete loss of tire braking traction (one manifestation of hydroplaning) occurring at ground speeds considerably less than the tire hydroplaning speed.
Such a loss at these lower speeds cannot be ascribed to hydroplaning from fluid density effects since the fluid dynamic pressures developed at these lower speeds is insufficient to lift the tire off the pavement surface. Since this type of braking traction loss occurs only when smooth tires are used on smooth wet pavement surfaces or when rib tread tires are used on very smooth wet pavement surfaces, it probably arises from thin-film lubrication effects on the tire-ground surfaces in which fluid viscous properties, previously ignored, tend to predominate…
I will add that the bulletin does point out that smooth tires have more of a problem on wet pavement than ribbed tires. I read something a while back that said that while pavement is smooth, it isn’t consistent. Having a small amount of tread will help break up the boundary layer that causes lubrication. It has nothing to do with preventing hydroplaning and the direction of tread on a smooth tire for smooth pavement doesn’t matter. As to that point the authors say
It is apparent from these data that the extreme pavement slipperiness demonstrated for thin-film lubrication conditions is the direct result of the inability of tires to penetrate a very thin but tenacious fluid film that coats smooth pave- ment surfaces when wet. As might be expected from the preceding discussion, the loss in tire-braking traction due to thin-film lubrication can be greatly reduced by the addition of a thin nonskid coating to the existing smooth pavement surface. This effect is shown in figure 33 which presents frlction-coefflclent data obtained on a wet but not puddled with water, enameled steel aircraft landing mat before and after being coated with a nonskid compound that the U.S. Navy uses on flight decks of its current aircraft carriers. The fine sand-like grit particles embedded in this compound provide thousands of sharp asperities in the surface which break through the pavement fluid film and sharply reduce the braking traction loss due to thin-film lubrication effects.
As mentioned, there are two separate effects for which there is separation or loss in adhesion between tire and wet pavement surfaces with resulting large increases in pavement slipperiness, namely, hydroplaning (where inertia and den- sity properties of the fluid predominate) and thin-film lubrication (where viscous properties of the fluid predominate). Hydroplaning requires a critical minimum fluid depth to be present on pave-ment surfaces. This critical depth can range from approximately 0.1 to 0.4 inch depending upon the character of tire-pavement surfaces. Smooth tread tires operating on the smoother pavement surfaces require the least fluid depth, whereas rib tread tires operating on open-textured and transverse-grooved pavement sur- faces require the greatest fluid depths. When this critical fluid depth is exceeded for any tlre-pavement surface combination, the critical ground speed (hydroplaning speed) required for total hydroplaning to occur was found to be almost entirely dependent upon tire inflation pressure. This result led to the derivation of a simple relation for estimating tire hydroplaning speed which shows good correlation with available experimental values of hydroplaning speed.
Thin-film lubrication is not important at normal vehicle operating speeds when rib tread tires are used on wet rough-textured pavement surfaces. It becomes important and increases slipperiness when smooth tread tires are used on smooth pavement surfaces or when rib tread tires are used on very smooth pavement surfaces. Thin-film lubrication does not require the presence of large fluid depths on pavements. (The film thickness required is estimated to be less than 0.01 in.) The limited data available suggest that complete separation of tire and pavement surface from this fluid property can occur at ground speeds at least 35 percent less than the speeds required for hydroplaning to occur from fluid density effects. Fortunately, thin-film-lubrication effects are easily avoided or minimized by roughening or texturizlng the pavement surfaces and by not using smooth tread or excessively worn patterned tread tires on air and ground vehicles.
Stuart Black
Stuart Black
Likes For cyccommute:
#61
Quoted: 2345 Post(s)
Liked 2,859 Times
this study is from 1963, tire technology has changed hugely for cars and bikes since then, from design to tread compounds
While I am sure a lot of the basics apply, this is far from the holy grail that the OP suggests it is, talk about confirmation bias
#62
Quoted: 2516 Post(s)
Liked 2,996 Times
Thanks, cyccommute, for doing the work most of us were too lazy to undertake. If I know my fellow Bike Forums habitues as well as I think I do, the formerly earnest "but my bike did hydroplane!" claimants will gracefully acquiesce.
#63
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4342 Post(s)
Liked 2,996 Times
Exactly -- lubrication is not hydroplaning, even if some of the same principles are involved.
Likes For DiabloScott:
#64
This has been one of the most entertaining threads I've seen on here. Mostly pointless as several pointed out most of us are unlikely to experience this. But the back and forth, witty repartee, and mighty indignation well worth the price of admission. Thanks to all who contributed.
Likes For oldukbkr:
Likes For mpetry912:
#66
Droid on a mission
Quoted: 319 Post(s)
Liked 281 Times
Stop feeding the troll
#67
Liked 2,683 Times
For those who are curious, one may consider the difference in planing and displacement hull design in boats, then compare bike to auto tires.
As one who has ridden in miserable conditions, I can add one other factor.
Hitting deep water (4" or more) at high speed is very similar to hitting deep sand. You get immediate braking and a sudden over steer as the side forces want to swing the front wheel. So there doesn't need to be slippage, it's just that you're normal steering reflexes no longer work.
I feel somewhat guilty because it was my statement in another thread about road tire tread not mattering that set the OP off.
Likes For FBinNY:
#68
Quoted: 3560 Post(s)
Liked 2,977 Times
#69
Expired Member
Liked 5,551 Times
#70
Liked 4,246 Times
Hitting deep water (4" or more) at high speed is very similar to hitting deep sand. You get immediate braking and a sudden over steer as the side forces want to swing the front wheel. So there doesn't need to be slippage, it's just that your normal steering reflexes no longer work.
I was astonished by how little water is needed for hydroplaning to occur. “Hydroplaning requires a critical minimum fluid depth to be present on pave- ment surfaces. This critical depth can range from approximately 0.1 to 0.4 inch depending upon the character of tire-pavement surfaces.”
Stuart Black
Stuart Black
#71
Quoted: 982 Post(s)
Liked 587 Times
Was this "hydroplaning"? Even if so, it was so remote from "normal" riding that it is only academic.
#72
FWIW: here are a pair of links to what the late Jobst Brandt had to say about the subject:
https://www.sheldonbrown.com/brandt/slicks.html
https://yarchive.net/bike/slicks.html
This photo of a Goodyear aircraft tire would seem to back his opinion.
https://www.chiefaircraft.com/media/.../gy-tire_4.jpg
FWIW: Brandt worked for many years in the automotive and bicycle industries as a mechanical engineer (for Porsche and Avocet, if I recall correctly - and with Avocet, was as I recall directly involved in tire design). Best I can tell he virtually always knew precisely what he was talking about and was correct when it came to cycling technology and the engineering aspects of same.
Likes For Hondo6:
#73
Quoted: 346 Post(s)
Liked 178 Times
Okay. You forced me to read through the whole NASA bulletin…thanks a lot
To extrapolate a bit, thin film lubrication is a much more important phenomena to bicyclist than hydroplaning is. If control is lost on a bicycle in wet conditions, it’s because the surface is slippery. It’s not because there is a build up of a bow wave that is lifting the bicycle off the ground. The light weight of the bicycle/rider (compared to cars and airplanes), the high pressure of our tires, and the very small contact patch give much more weight to lubrication rather than hydroplaning.
"Fortunately, most runway and road pavements in use today are provided with textured surfaces so that thin-film lubrication is probably seldom encountered when vehicles are equipped with tires having adequate tread pattern designs."
So, we can quibble about whether or not my tread pattern was adequate and whether or not I experienced thin-film lubrication or hydroplaning or nothing at all but my take was there is a fine line between all the various things that might be going on and the resultant effects that for purposes of discussion between lay people about practical considerations are largely irrelevant hair splitting. The study in question was conducted and data gathered for the purposes of addressing hydroplaning of aircraft. I don't believe the researches gave any thought whatsoever to bicycles. If my decision process were to lead me to extrapolate their research to a scenario whereby I might dramatically increase the risks of my activity, I might ask the authors if their opinion was that such extrapolation was prudent. My guess is that were they to realize I would be increasing my risks that they would probably say their study was not designed for such a scenario and that they would therefore be reluctant to endorse such an extrapolation. I choose not to assume that their study can be extrapolated to bicycles. Perhaps I am the one nitpicking and the one dismissing scientific research for the sake of being "right," but as it presumably leads me to a more conservative and safer course of action and harms nobody else, it is reasonable rather than a reckless denial of "science."
My question to you then, if asked by a lay, beginning cyclist "do I need to worry about hydroplaning?" are you going to say "no, not at all" and then go into some technical discussion about thin-film lubrication or are you going to say "yeah, you need to be cautious on wet roads"?
If nothing else, I got somebody to actually read the study. I do find it somewhat troubling though that it was an eye rolling exercise to you.
#74
Liked 2,683 Times
The former is probably smarter, but I end up letting nature call it.
FB
Chain-L site
FB
Chain-L site
#75
Liked 2,996 Times
No, you do not need to worry about hydroplaning with a bike. Yes, you need to be cautious on wet roads. The two statements are not exclusive.
Likes For Trakhak:
