Narrow Rear carrier options
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
I've been racking my brain (get it?) about a rack that can fit a bike I am considering using for a commute. It's 5.5 miles one way with a few overpasses, so moderately easy. The outside faces of the dropout and eyelets are 130mm (is a 120mm old 5 speed frame). Upper mount would have to be seatpost clamp or brake bridge, there are no eyelets on the seatstays. I'm going to use a centerpull brake, which could complicate the mounting. Many, many racks are simply too wide and would require some bending to fit, or the use of spacers between the frame and the rack. I'm particularly fond of the Tubus Fly evo rack in silver, but the installation instructions specify 140-170mm lower attachment spacing, and not to exceed those values.
Tubus fly Evo in silver
I like the minimalist design and clean lines. I'd prefer to leave the rack on the bike full time, and I already own a pair of Ortlieb panniers that should clip on to any Tubus rack. I also like this unknown rack posted by randyjawa a couple of years ago, though I'm concerned about capacity (estimated about 20lbs of clothes, food, and tools & Lock max).
There's a rack like this locally, but I'd have to buy the whole bike to get it. That means I could have it essentially for free, if I sell the bike on, but I don't want to go to the trouble if the rack can't support the expected weight.
I've also seen the modified Wald 215 rack posted in the forums, which I liked because of how narrow it ended up, though I'd prefer to avoid chopping up a rack.
Pletscher is not favored by some on the forum, and I'm not sure I like the aesthetics of a Blackburn rack. What options are out there for silver racks under $70? Has anyone exceeded the specified spacing for Tubus racks?
Likes For Unca_Sam:
Quoted: 2363 Post(s)
Liked 1,749 Times
https://www.axiomgear.com/products/r...iner-road-dlx/ , maybe? I have something similar (seat stay / cheerio version) on one of my hybrids, and the way it's set back helps a lot with heel clearance.
Plenty of love for the Pletschers over in the C&V section, and it would be at home on your frame.
The dropped
Liked 1,014 Times
As for the Streamliner Rack, I'm considering it! It only comes in black though, so the consideration includes a chemical strip or a blasting to get the (assumed to be) powdercoat off of the aluminum. I'm estimating anywhere from $50 (sand and paint 'silver') to $85 (blasting) all in to get it where I want it. The only benefit I see to this rack is that the lower attachment spacing was specified as 124mm, which seems narrow, but probably works well with road bike 136-140mm outside spacing. A Pletscher is likely to be the cheapest option, and would probably play the nicest with the brakes. I can't say I'm in love with the 'shelf' on the back though. Randy's rack soothes the tiny OCD voice in my head with it's symmetry to the rear triangle. It's really little things, I should just build the bike and wheels up and ride...
Liked 1,749 Times
Okay, the silver/chrome spec is new intel, and definitely limits your options (or, as you say, adds a step/expense). As for the 124mm spacing, since the vast majority of bikes that rack is destined for are spaced even wider than yours, I think it's safe to say it's intended to be spread to fit.
The dropped
Liked 1,014 Times
I'm happy about the spread to fit. Most of the cheaper racks don't even list the spacing. I noticed a tubus fly evo for $70 something. That's a minimum of 140, which isn't too bad to space out.
The dropped
Liked 1,014 Times
Liked 1,749 Times
madpogue
You'd use this cheap Sunlite Pletscher copy?
It all depends on how rare/common the real thing is where you are, and how much of a purist you are. 'Course, an original is likely to be a lot less shiny than that copy. Again, depends on whether that's a priority.
Quoted: 95 Post(s)
Liked 50 Times
I have Tortec velocity racks on three of my bikes. You probably won't find a thinner rear rack, Also very light - 391g. I use them on road bikes without eyelets, mounted with P clamps. Despite being very narrow, I have not encountered issues with fender clearance. Silver or black. 55lb capacity. $22. I use the rack just as you have shown above, with one bag, for commuting.
https://www.bikeforums.net/classic-v...nko-storm.html
https://www.jejamescycles.com/tortec...SABEgJgzfD_BwE
1977 Zebrakenko Wind
Likes For Trueblood:
The dropped
Liked 1,014 Times
I have Tortec velocity racks on three of my bikes. You probably won't find a thinner rear rack, Also very light - 391g. I use them on road bikes without eyelets, mounted with P clamps. Despite being very narrow, I have not encountered issues with fender clearance. Silver or black. 55lb capacity. $22. I use the rack just as you describe with one bag for commuting.
I have a pair of original Pletscher model C racks on the way for about the same cost. I don't need two, but sometimes these ebay sellers surprise me with accepting my low offers...
The dropped
Liked 1,014 Times
I hate to get defeated this way, though it seems like the best option at this moment in time is a vintage rack for a vintage bike. I'm confident that the Pletscher rack will fit without issue, and with the brake brace plate hardware, I should be able to get a solid connection for commuting. Since I'm not buying a tubular frame rack, I'm concerned that my ortlieb shopper panniers and their QL 2.1 connections simply won't be secure with it, and I'll be investing in new waterproof panniers or a trunk bag to haul my junk to and from the office.
Liked 1,749 Times
^^^^^ Your Ortlieb/Pletscher question might be worth asking over in the C&V section.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I think the chopped Wald rack is your best option. I have a black one, which is what I'd recommend because the cuts are easy to touch up with black paint. With a chromed one you'll have to use silver paint and it won't be perfect. Nonetheless I think that's the one to beat. And it's cheap.
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 95 Post(s)
Liked 50 Times
The dropped
Liked 1,014 Times
Ortlieb's QL 2.1 system works with the Pletscher modell C I bought. The rack rails are 12.75 mm tall, according top my calipers. It's a snug fit with the 12mm diameter shim tubus provides.
GATC
Centerpull brakes on the other hand, no experience w/ that combination.
