Cleaning With Power Washer
I know there are some who do this on a Regular basis and Some who think it's the worst Idea in the world. The Videos I watched with Professionals Cleaning,They all Used Power Washers and Compressed Air to dry the Bikes off . .
I have 4 Bikes to Wash : With Grand kids 2 of them get dirty pretty fast > None are Cheapo Bikes 3 Treks and 1 Specialized : The Most Expensive of The 4 is a Dual Sport 4 . The Least Expensive was a Woman's 2019 Trek Verve 2.
3 weeks ago I spent all of 5 Hours carefully cleaning theses Bikes : I used Brushes , Pipe Cleaners ,Rags Etc . Used My Park Tool Chain Cleaner on all 4.
TODAY they were all fairly dirty again: Oily dirt all over the Drive Train : The Bike Trails have water in Several Spots due to the excessive rain this Season. There's no way to avoid going thru the Mud at least Once a Ride. Regardless of the Trails used
I mixed some 8 Ball Siding and Auto Cleaner in a spray bottle : I also used Kerosene in a Spray Mixture on the chains and areas where oily dirt was packed . I used Wesley's on the Tires> Let them set about 15 minutes: Then Power Washed ,Compressor Dried and Re-lubed the Chains. Took me Exactly 85 minutes :
The only places I used a brush were on dried mud on the tires sidewalls :
They came out Cleaner then Normal with 1/10 of the Elbow Grease normally use :
Nothing wrong with power washing a bike. Even at 3500 psi I don't think that it will remove the paint. I would just be cautious with the amount of pressure.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
All you need is a standard hose with VERY little pressure. Using a "power" washer is a good was to get water into the bearings and washing the grease away.
Just yesterday I came home from a ride on damp roads and path and my bike was covered with sand, dirt and grit. I "gently" washed the bike with a hose set at a very light setting and it removed all the dirt. I then cleaned the chain and drivetrain.
I quick wipe down with a microfiber cloth and it's perfectly clean.
Likes For GlennR:
Mad bike riding scientist
Quoted: 6214 Post(s)
Liked 4,212 Times
I’ve been using car washes for ages when I get around to washing my bikes (which is seldom). All my bearings are sealed unit now but they haven’t always been. It’s never been an issue. Just don’t use the most powerful part of the stream near the bearings.
Stuart Black
Stuart Black
Quoted: 18409 Post(s)
Liked 15,520 Times
I’ve had to do it on tour. Once when I rode through some camouflaged mud and sunk down a good 4”. Spokes splattered mud everywhere before I came to a dead stop. Took care not to spray directly into areas with bearings.
Likes For indyfabz:
On Your Left
Liked 2,433 Times
Quoted: 1324 Post(s)
Liked 927 Times
Professional mechanics know what areas to not aim the high pressure water stream at. Plus they have to clean a lot of bikes and often have to do it quickly. hterefore for them a power washer makes sense.
Cheers
Cheers
Quoted: 671 Post(s)
Liked 49 Times
What is the actual advantage of using the pressure washer? Regular hose can wash off loose dirt & the greasy parts need extra care anyway. Chain cleaning is the only part where I use reg hose & jet nozzle setting to blast off grit/grime after scrubbing with degreaser.
Liked 15,520 Times
Another time I got caught in a massive downpour on a long dirt road. Made it to camp and didn’t hit civilization until the following day after riding more wet dirt in the morning. Bike was covered in this sandy grit that again baked on. I tried a regular hose at Adventure Cycling’s headquarters, but it wasn’t up to the task. Was returning the bike to a shop that day for shipping home. Couldn’t give it to them like that. Had to spend serious time at a car wash with a power sprayer.
Liked 927 Times
Cakeg on and/or sun-baked clay-based crap is really hard to rinse off.
Cheers
Quoted: 1364 Post(s)
Liked 1,677 Times
Liked 4,212 Times
Convenience. I don't have one at home but there are car washes all over the place. The car wash has soap and degreasers as part of the system.
There are also times where you can't get to a hose. Like Indyfabz, I've used car washes on tour. I rode from Toledo, OH to Philadelphi, a distance of about 950 miles. About 700 miles of it was dirt roads (Ontario) and tow paths (Niagara Falls to Philadelphia). I was going to stay in a hotel in Philadelphia but didn't want to present a filthy bike at check in. A quick power wash made it all nice and shiny and, more importantly, presentable.
Stuart Black
Stuart Black
Quoted: 174 Post(s)
Liked 177 Times
YES, we've all seen team mechanics pressure washing bikes with ZERO ***** given about bearing and such.
Here's the thing, though, first off, those bikes get rebuilt and re-greased fairly often, so it's not a huge deal to be a little reckless. Plus, it's not like they keep bikes for very long anyways, so longevity isn't much of a concern.
Another thing to consider is the rider of bikes we are watching being sprayed down like they're on fire. These are usually support riders, and team mechanics don't care as much about their bikes. You can bet that Chris Froome's bike doesn't get that sort of treatment.
SE Wis
Quoted: 2743 Post(s)
Liked 3,390 Times
Sounds like the kids need to help and learn. Would probably think the power washer was "cool"
Liked 4,212 Times
I think something went wrong with your language integrity modulator. We might be able to fit you in next Tuesday for a diagnostic.
Stuart Black
Stuart Black
If you have sealed wheel bearings. If not sealed, like a boat trailer, they need to be opened, cleaned with solvent and repacked.
Quoted: 174 Post(s)
Liked 177 Times
No, we haven't all seen team mechanics washing bicycles. Frankly, I don't watch bicycle racing nor do I watch what team mechanics do. I have other things to do than watch bicycle racing and watching them mechanics work on bikes ranks even further down on the list.
Has anyone here said to just blast away at the bearings with a power washer? I think you'll find that the advice has been to avoid the bearings, although GCN did a video where they blasted the bearings at close range for 2 minutes without any water infiltration. If you have a problem with water getting into the bearings, there are 2 solutions. One, don't use a power washer right next to the bearings. Or, two, get better bearings with better seals.
Firstly, I can't fathom why a someone would get upset because I said we've all seen professional bikes being washed. I mean, A, I think a reasonable individual would understand that "all" isn't to be taken literally. And, B, if that was my intention, why has that upset you so much? God-forbid somebody think you've seen a team mechanic washing a bike... The horror!
Secondly, NEVER claimed anyone on here suggested pressure washing like pro mechanics, that deduction should elementary on your part. It sounded like the OP thought it was a good idea because the pros do it, and I just wanted to explain why they do, and he or she shouldn't.
And lastly, what? It's the truth. That's how the world works, you think everything is even-steven in professional sports? Talent takes priority, that's just a fact.
And by the way, I would STRONGLY suggest getting up on a different side of the bed tomorrow.
Liked 4,212 Times
On the other hand, even a poor quality sealed cartridge bearing is sealed well enough that the nozzle could be used directly on them. If something goes south on those bearings, they are simply replaced. If the bearing is a poor quality bearing, replace it with a better one.
And, frankly, “boat trailer” bearings are fairly well sealed against water. They are meant to go into the water with a boat on them, aren’t they? I don’t know many boat owners but I don’t think they spend all their time with the boat out of the water rebuilding bearings.
Stuart Black
Stuart Black
Liked 4,212 Times
What the heck are you even talking about?
Bicycles are durable machines and can take a lot more abuse then people think. They aren’t make of sugar that melts if shown the slightest amount of moisture.
I’ll pass on the sleeping arrangement advice. Thanks anyway
Stuart Black
Stuart Black
Quoted: 174 Post(s)
Liked 177 Times
You sure sounded like you were speaking for all of us.
You implied that it. Power washing isn’t going to melt the bike nor is it going to contaminate the bearings. If you have a bike that was built before about 1995, some care should be used around the bearings. After that...to the present day...it’s not going to matter that much. Mountain biking did in open grease systems long ago. GCN’s video even showed that directly spraying the bearings for minutes at a time doesn’t lead to water infiltration.
What’s the truth? Your last paragraph makes zero sense. Are the riders the ones that are being sprayed down like they are on fire or their bikes the object of the fire hose? If the former, I really doubt they are using actual fire hoses, so it wouldn’t matter. If the latter, again, it doesn’t really make that much of a difference.
I did not read a SINGLE reply because responding. I just started typing.
There's no way I could have addressed posts I didn't read until AFTER I posted.
All I was doing was trying to persuaded the OP not to pressure spray the crap out of his poor bike. Nothing more, nothing less.
Now about sounding like I was "speaking for all of us", get over it. I wasn't. And it's a dumb thing to care about even if I was. Oh no! Someone thinks all cyclists have watched a video of team mechanics washing a bike! What ignorance! Shame!
Please add me to ignore.
-Cheers
Quoted: 2602 Post(s)
Liked 1,925 Times
I'm not a moderator (and don't particularly want to be one), but still...
CHILDREN!! BEHAVE!!!
Jedi Master
I washed my bike yesterday with a bucket, some dish soap, a couple of brushes and sponge. Rinsed the soap off with a garden sprayer. The whole process took maybe 15 minutes. I have a power washer and an air compressor at home, but it's lot more hassle for one bike. For four, maybe the power washer is easier. Only way to know for sure is to do it both ways and see which is easier for you.
I bought a used wheel-set with campy chorus hubs a few years ago that was filthy from sitting in a garage for years and years. I was going to repack the bearings anyway so I decided to clean the wheels with a power washer. I wasn't careful at all and sprayed the heck out of the hubs because they were so filthy with decades of grime and dust. When i took the hubs apart they looked like they had just been serviced, so I would have no problem using a power washer on my bikes if it were easier. I have been powerwashing my off-road motorcycles for decades and the bearings are pretty much the same thing as on a bicycle.
On Your Left
Liked 2,433 Times
