Chain length choices...
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times
Small (triple) ring, small cog.
Would you use Pic A, Pic B, or something else?
PICTURE A
PICTURE B
PICTURE A
PICTURE B
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 159 Post(s)
Liked 133 Times
I may be misunderstanding you, but usually one starts with big to big, not small to small. See Park Tools method for a conservative approach, or look at Sheldon Brown's method.
Quoted: 1627 Post(s)
Liked 630 Times
I'd go with pic A.
From personal experience I know that RD will stretch a helluva long ways and wouldn't worry about it, but I always look at big/big too before making the final cut. I still end up with some setups that really stretch the hell out of short cage RD, but I'm always determined to cram a 32T cog under them.
The BIG/big method gives the shortest possible chain, but it isn't always optimal for shifting, IME. I prefer the Shimano method, especially for GT cage derailleurs. To do this, when you put the chain into BIG/small (highest gear), the jockey wheels of the rear derailleur should be in a vertical line. Always double check both BIG/big and SMALL/small to make sure the chain is long enough, and not so long that it can rattle against itself. (the latter state can be fudged if necessary with triples.)
I'd take a wild guess and say that 'A' is closest to this method.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Note that Shimano's/Campag's methods are only really applicable to gearing choices actually specified with the original complete groupsets.
For anything outside their ranges, you are on your own.
I always check the big/big chain length for general information, as well as the small/small. Longer chain often shifts best as mentioned by Salamandrine.
Likes For dddd:
Quoted: 159 Post(s)
Liked 133 Times
Quoted: 1372 Post(s)
Liked 1,752 Times
I only have Campagnolo, and they recommend small- small.
I almost always go big-big, ensuring that I will not stretch-load the chain. This has worked OK for me for many years, however...
More recently, I have found that my interest in vintage road bicycles trends towards pre-1970 offerings. This means that I will be using old school transmissions, such as a Campy Gran Sport chain jumper. Going big-big is safe but the shifting and chain tension/slack is not working well at all.
Likes For plonz:
I've apparently been sizing my chains wrong this whole time.
I always did small small and as long as there was tension in the RD and the chain didnt rub on itself then that was that. I figured having the longest possible chain made cog adjustments easier in the future. I will go make penance now.
Not lost wanderer.
Quoted: 886 Post(s)
Liked 998 Times
Why are we talking Campagnolo when this is a Shimano derailleur. Go big-big +2
Works with my triple and a 105 gs long cage 49x46x30 and a 11-36 cassette
Both methods work. The SRAM/Shimano method is sizing for just one cassette in the rear. The Campagnolo method works with any size in the rear, so more useful if you swap wheels. The Campagnolo method gives you the longest possible chain, which, as mentioned above, gives the best shifting.
Likes For jiangshi:
Quoted: 1608 Post(s)
Liked 2,216 Times
Learn something every day! I like that "staple" fixture!
Quoted: 209 Post(s)
Liked 175 Times
Great info, thanks for the replies.
Clearly, different strokes for different folks!
Drivetrain is 52/42/30, 12-25, and is all Shimano 5500 except for a 5603 FD.
I went with A, and chain length seems good.
Now, though, I've developed a different problem...it is reluctant to drop down into the 12 cog.
Limit is fine, and the RD is clean and lubed.
Also, the FD dropshifts hard...should I suspect this is normal?
UPDATE: Shifting is better, but not yet perfect. Using the micro-adjuster, I believe that loosening it tightens the cable, and vice-versa. So, if it hesitates a bit climbing up the cassette, that means I need a slightly tighter cable, right?
Dropping down the cogs is usually fine, trouble spots seem to be in the smaller 3 or 4 cogs, and usually when climbing up the cassette.
Liked 2,216 Times
67tony Did you check your chain line?
Quoted: 1104 Post(s)
Liked 1,825 Times
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
I have always held that the goal is to have optimally crisp and reliable shifting over the useable range of gears. The short-short method rarely accomplishes this, in my experience. I'm not saying 'never', though. Again, the goal is optimally crisp shifting for whatever combination of kit you have.
Does Campagnolo know what they're talking about? I have no idea, and don't care.
Quoted: 380 Post(s)
Liked 541 Times
JMO of course
Liked 2,216 Times
So if big-big =2+2 is shorter and small-small is longer. How much difference is there?
Oh and when is the B screw adjusted?
When that is sorted out, do the limits next. I prefer to adjust the limit screws while in friction mode if available, or by pulling on the cables if not. When this is dialed in, then dial in the cable length to adjust the indexing. I suppose because I started in the friction era, this order feels more comfortable.
RE the FD, hard to say. Could be normal. Old non ramped and pinned chainrings were not nearly as smooth shifting as modern ones. Is the FD height set at one penny from the big chainring? Angle adjustment good?
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
I have a tendency to ask too much of my drive trains. On this account I like big big. If it wont pull up all the slack in little little I don't care. I'll never be there.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3889 Post(s)
Liked 6,488 Times
Agree. No matter where I start when adjusting chain length, I make sure that the chain and rear mech work well in the gears actually used, which never includes big/big nor small/small.
