How smart would it be to use this pump for "everything"?
Quoted: 23 Post(s)
I recently bought a new Joe Bloe Sport 3 floor pump and i planned to use it for bikes only,but how smart it'd be to use for other things too?For example for those a bit bigger blow up pools?
Quoted: 645 Post(s)
Liked 797 Times
It's a pump - you can use it for anything. - the only problem with blowing up a very high volume very low pressure object like a pool with a pump designed for relatively low volume/high pressure applications is that it's take you forever.
Likes For Litespud:
Quoted: 630 Post(s)
Liked 369 Times
Totally fine they even include the adapters for those. But you might have to do several hundred pumps to get one of those larger pools inflated.
Quoted: 18409 Post(s)
Liked 15,518 Times
+1. Try inflating a car tire with a bicycle pump.
Likes For indyfabz:
Bikes: 1969 Peugeot PX10, 1992 Della Santa, Linus Roadster 8, Biria 700C ST-8
Quoted: 794 Post(s)
Liked 508 Times
My daughters fancy BMW 3something has a front tire that leaks just a little bit. About every two weeks it starts complaining about low tire. I just apply my Serfas floor pump to it for a few minutes and its back up. There’s no reason a bicycle pump can’t pump up car tires. Never understood that attitude. Just do it.
Likes For Joe Bikerider:
Quoted: 3450 Post(s)
Liked 420 Times
I have attempted to blow up a single airbed using a bicycle floor pump. Attempt being the operative word.
They are WAY too slow.
Mad bike riding scientist
Quoted: 6212 Post(s)
Liked 4,210 Times
Yea, there are better ways to blow up pools. My neighbors were blowing up a pool with an electric inflator. I told them that that was cheating. We had to have our parents...our 3 pack a day smoking parents...blow up our pools. I was 14 before we ever had a wading pool.
Stuart Black
Stuart Black
Quoted: 4802 Post(s)
Liked 3,922 Times
I had a fun thought reading this thread - to gain more social distancing in prisons, grant those on good behavior their freedom, but only after they have pumped up every tire on an 18 wheeler from flat with a mini-pump (only with the knowledge that should they be back, their new sentence starts with those tires all over again).
This should help our bicycle economy. A weight lifting inmate could go through a case of those pumps.
Ben
Ben
Quoted: 1068 Post(s)
Liked 780 Times
https://www.amazon.com/Coleman-20000.../dp/B00V85CDSS
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Pump away and AWAY and AWAY!!! on a pool or the easy--peasy way >>>
Yeah, a $25 car plug compressor is actually a great pump for large volumes, and should probably be kept with your car whenever you're driving.
Quoted: 668 Post(s)
Liked 529 Times
The trunk compressors are also painfully slow with even air mattresses let alone pools
Battery powered pumps made for air mattresses are pretty cheap and do a good job on pools. Shop vacs are even better.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
We're drifting off topic here, but I just had the same thing happen on my bike, very slow leak, wouldn't even notice unless I didn't ride/top-off tire for a couple days. Luckily I caught it before I started taking things apart to get to the tube
Likes For bikecrate:
Quoted: 1324 Post(s)
Liked 927 Times
I did that around 1987 with a car at night. The guy was flat and I had a Mount Zefal pump and was able to get his tire up to where he could safely albeit slowly drive it to the nearest gas station with an air hose. What a workout that was.
Cheers
Cheers
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Quoted: 794 Post(s)
Liked 508 Times
Good suggestion. I used to have one of those valve caps that had the prongs on it for just this occasion. It sat on my garage desk in the little spot under the monitor. Lots of little nuts and washers too. Then the wife came along and “cleaned up”. Sigh. One of the negative outcomes of families huddled together during this plague I guess.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Using bike pumps for big jobs usually kills my lower back before the goal is achieved. Once used a big Zefal to pump up the four LR70-15 radials on my old Chevy panel that had been parked in my parents' yard while I was off on a long tour. Unlike most pumps, that one with its two chambers had resistance on the upstroke as well as the downstroke since it was pumping both ways. As opined above, not recommended.
That said, I do keep my old Zefal Husky in our VW camper, just in case. I have tire plug kits in every vehicle and some means of inflation in each, as well.
Anything with greater volume than a car tire, get a compressor or hire some chucklehead to do it.
