clip on moutain bike rear fender
Hey commuters, I'm putting an old mountain bike in service and after riding today was reminded why I have fenders on my other bikes! I have a rack already on it and want to add a clip on, quick remove fender like SKS X-tra dry. I can't tell if something like this will work with a rack - anyone know?
I'm slow, go around
I'm slow, go around
Pedalin' Erry Day
Unless your rack is the kind that mounts to your seatpost, I don't see how the fender in question would help at all. Either way, no, that little fender isn't going to provide much more coverage than the rack you already have installed.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Stuart Black
Stuart Black
It would depend on the rack. There are lots and lots of racks that are completely open. There are other reasons to use clip-on vs stayed fenders. A more open fender with more clearance between the tire and fender is especially useful with wider tires and in snow or mud conditions. I use a clip-on and other pieces of fenders to give more complete coverage. The coverage I get in the picture below is better than many stayed fenders with far more clearance.
I'm slow, go around
I'm slow, go around
Liked 4,218 Times
SKS makes a similar fender called the Beaver Tail which might be stiffer. The front fender is a SKS Shockboard which is much better then the Planet Bike fender
Stuart Black
Stuart Black
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
I have a few bikes with fenders too. The ones that have fenders that fit under a rack are all typical stayed fenders. On one of my snow bikes I had a cut off piece of a fender just bolted onto the back of a rack with a solid plate in it. You can make a flat fender and just strap it to your
existing rack, and extend it out the back more, or forward more if there is room. I saw a temporary fender make of flat corrugated cardboard with a plastic bag over the cardboard to keep it dry, Just attached to the underside of the rack. You could make one out of plastic and keep it on.
I consider plastic fenders as a starting point, then I just cut them or attach them the way I want.
Yup, just ordered some SKS adventures from amazon for $15, about the same as cyccommute's planet bike set. At worst I'll zip tie them under the rack
I'm slow, go around
I'm slow, go around
Liked 4,218 Times
so that you can put the ziptie through
Now use an old ziptie that you have cut off...I keep the cut off for just this purpose...and slide it onto the end of the ziptie
Pull up the head and clip it.
You can see how it works at the bottom of this picture
This picture also shows how I use a water bottom mount to hold the lower fender section.
Stuart Black
Stuart Black
SwampDude
General Cycling Discussion
6
04-06-14 12:23 PM
amgarcia
Commuting
18
12-01-11 09:07 AM
