Flat Pedal Recommendations Please
Quoted: 41 Post(s)
Liked 26 Times
A friend gifted me an older model Bianchi Giro and I need a set of flat pedals for it.
I checked online and there are zillions of choices, many of course stating for MTB.
Are there some obvious choices I should consider or is any, good, named brand pedal as good as the others?
Thanks
Thanks
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1155 Post(s)
Liked 2,051 Times
Crank Bros seems like the popular choice these days. Their lil spikes offer good grip.
"Leave the gun. Take the Colnagos."
Likes For Robvolz:
You can pretty much set a budget and choose a brand-name model. Wellgo, Crank Bros, DMR, Race Face, VP ... I've forgotten the many brands with good reps.
One distinguishing factor is the length and width of the various models, and width was paramount for me. I wanted something fairly light, long, wide, with sealed bearings, and under $60 when I bought mine 6 or 7 years ago. I settled on DMR V12s, which have been trouble-free for about 8,000 miles.
I obsessed over the choice. In retrospect that was wasted effort. My reco is to decide what the distinguishing factors are for you and your budget and pick the first one you come across that meets your requirements.
Likes For philbob57:
Likes For freeranger:
Bikes: 2019 26" surly long haul trucker, 1984 fuji espree (converted to fixed/single), 1999 fuji touring series
I'm a big fan of my MKS x Sylvan Gordito pedals. Like their classic touring pedals, but a bigger surface.
Likes For douis:
What can vary widely is the width of the pedal and this is important for most riders. Crank Brothers that was mentioned has some of the widest pedals available. These pedals are designed for use with mountain bike type shoes that have a very firm sole, like the ones from Five Ten. Not the best choice if using running shoes or sneakers.
Likes For Calsun:
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1252 Post(s)
Liked 338 Times
I've been using $50 or $60 Vsixty pedals for 60,000 miles. What's better about these is the pegs screw in from the bottom and do NOT twist out.
They have 1 sealed bearing on the inside and a bushing on the other. I lube them once or twice a year.
They all have a good solid alu body.
Beware of cheap pedals, they may have MORONIC 1/16" loose bearings that can NEVER be adjusted to spin properly.
Damn ads don't show you what bearings are in there.
Likes For GamblerGORD53:
Quoted: 76 Post(s)
Liked 41 Times
I run the Shimano M324 pedals on my classic bike, they kind of fit that vintage look/feel and one side is a platform while the other accepts SPD. I typically ride with SPD shoes, but it gives me the option to jump on it for a quick grocery/errand run with sneakers.
https://ride.shimano.com/collections...61a6ffe6&_ss=c
Likes For ericlowney:
Quoted: 3521 Post(s)
Liked 1,498 Times
My folding bike has platform only pedals, MKS brand. They work fine but I do not have tens of thousands of miles of experience on them.
I usually use SPD pedals and cleats for most of my distance riding, whether that is randonneuring or bike touring. For touring, I also like a platform side so I can ride with normal shoes too.
I like both the M324 pedals cited above (although they are heavy) and A530 pedals (lighter) that I think are now discontinued, both of which are Shimano. Shimano has made a model similar to the A530 to replace it, I do not recall the model number.
If you get Shimano pedals, if you get a Shimano model that can be worked on with the Shimano tool TL-PD40 (only a few bucks), you can add grease to the pedals later when they need it. There are several youtube videos on how to use that tool. Every few years I add grease to the A530 pedals that I have on several bikes. That tool does not work on the M324 pedals.
Likes For Tourist in MSN:
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1128 Post(s)
Liked 257 Times
Lots of flat pedals out there, most have removeable pins which is always good so you have the option.
I don't think there is any best flat pedal, there maybe some bad ones, but I have a feeling there are mostly good ones on the market. Most of the money you would spend is for subtracting weight.
On my touring bike I decided to go with Bontrager Line Elite MTB Platform Pedals, they weigh 350 grams, made of nylon, and cost only $52.
However there are cheaper ones like the Race Face Chester pedal, around $40, only weighs 10 grams more than my Bontragers, 10 grams is nothing.
I saw the RockBros pedals at another bike shop in town when I was looking for mine, and they have a smaller platform than the Bontrager, but they are cheap at just $30, but I wanted the largest platform pedal I could find, those are about 15 grams heavier than the Bonts, but again not a big deal.
There are some flat pedals that are dual sided but they will cost at least twice as much as non-dual sided. Shimano EH500 is a great example, these pedals are excellent for the money, and they simply work great, though they cost $80, not bad.
I had a dual sided pedal on my touring bike and decided I didn't like it, but that was because I had to keep flipping the pedal to get the side I wanted, plus it wasn't as wide as I found out I needed sometime later.
Everyone is listing very good pedals, just research all of them and find one you think you'll like best.
Likes For rekmeyata:
Bikes: BMC Road V2; '17 Marin Pine Mountain 2; '91 Marinoni Special TSX; '89 Specialized Stumpjumper Comp; '98 Salsa La Cruz; '79 Centurion Pro Tour; '77 Romic custom sport-tour; '77 Centurion Semi-Pro; '23 Kona Sutra LTD
Quoted: 62 Post(s)
Liked 220 Times
The Xpedo Spry pedals are excellent--light (276g/pair), narrow profile, good platform, durable, and not terribly expensive compared to other flat pedals of similar quality. I use them on several touring/long distance road bikes with good results, and I'm just as happy with them on my mountain bike or on a commuter. YMMV, but they're the best option I've yet to find.
Likes For fvernon:
Quoted: 1871 Post(s)
Liked 670 Times
Thanks
Thanks
There is a lot you can experiment with, and there are a of choices which might not be to your liking.
Likes For Road Fan:
Likes For john m flores:
Deraill this!
Bikes: 18 Cdale Quick 1, 94 S-Works M2, 98 730 Multitrak, and a few others
Quoted: 151 Post(s)
Liked 461 Times
I have RaceFace Chesters on my vintage mountain bike and really like them. I put a pair of RF Rides on my wife’s Verve to replace the Trek platform pedals. Rides are pretty much Chesters without the metal pins.
Likes For Trav1s:
Bikes: Franklin Frames Custom, Rivendell Bombadil
Quoted: 125 Post(s)
Liked 216 Times
I've been riding 2 sets of VP Vice for 10-12 years on my road bikes and they've been flawless, including the cartridge bearings/bushings. Every year I remove the axle and slather on grease so that it oozes out the ends when tightened. From the factory they have little so I take the liberty to slather on as much as possible. The platform is large/wide enough to support size 14 shoes, and is dead flat, which Is my preference. The flat head allen head pins are medium length. I paid maybe $30/pair back then and I bought a couple more sets for upcoming bikes for about the same price last winter. I never pay retail, I usually shop from reputable long standing shops who sell on ebay.
Likes For Garthr:
Must be symmetrical
I have found a lot of modern mountain bike flat pedals with tons of aggressive pins to be way too . . . aggressive. I tried the MKS Gauss pedals. They held my foot so tight I started to develop knee pain, and apparently this isn't that unusual and catches people off guard when they think they will get a lot more foot freedom with a flat pedal. I ended up removing every single pin and now they work nicely, but that entirely defeats the point.
I think the more traditional MKS models offer a good compromise in terms of grip and slip. I use the RMX on a couple bikes and am considering trying out the MKS GR-9 or GR-10 where aesthetics are more important.
Race Face Chesters and Crank Bros whatever model looks like Race Face Chesters is the only acceptable answer on this board. All others are either inferior or you get accused of being an accessory to theft per the know-it-alls on here. If you get any other brand or model, even if they are cheaper and work just as well you should keep it a secret or else.
However I bought a pair of Rock Bros and they have worked great thus far.
I have these on my mountain bike and love them:
https://nukeproof.com/collections/co...35459352592538
