Cervelo R3 2013 BB
Quoted: 34 Post(s)
Cervelo R3 2013 BB
Hi
I bought a Cervelo R3 2013 with SRAM Red gear and I disassembled every nut and bolt to give the bike the TLC it apparently never got.
The BB does not spin smoothly and I want to buy a replacement one.
Can anybody determine from the pictures the type of BB I need ?
Caliper shows inner diameter of the BB bearing in mm.
Quoted: 34 Post(s)
hi
i bought a cervelo r3 2013 with sram red gear and i disassembled every nut and bolt to give the bike the tlc it apparently never got.
The bb does not spin smoothly and i want to buy a replacement one.
Can anybody determine from the pictures the type of bb i need ?
Caliper shows inner diameter of the bb bearing in mm.
Quoted: 34 Post(s)
Based on the lettering on the BB shown in the second picture it is this one:
https://www.tradeinn.com/bikeinn/en/...up/136338463/p
Right ?
Right ?
Quoted: 860 Post(s)
Liked 1,100 Times
You could also pry off the outer bearing seals with a thin blade of some sort, flush with solvent and add new grease, then check for smoothness and play from wear in the bearings before buying a new one.
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 886 Post(s)
Liked 1,235 Times
BBright.
Don’t cheap out, I’d suggest a one piece like Hambini.
I’ve done two R3’ s and when my R5 needs it, it’ll get a Hambini as well.
Barry
Barry
Likes For Barry2:
I am potato.
Quoted: 1815 Post(s)
Liked 1,679 Times
I am inclined to think that this *may* be it:
https://rotoramerica.com/collections...=3521977614363
Perhaps this will be helpful: https://web.archive.org/web/20130121...series/r3.html
Quoted: 4577 Post(s)
Liked 1,722 Times
These bikes came with basic PF30 BBs from SRAM and others. The overlapping plastic shells that hold the BB will work in any 46mm opening between 68mm and 90mm. BBRight is 79mm and asymmetric.
I think alot of these wore out simply because the cranks weren't adjusted properly.
Quoted: 34 Post(s)
The condition of my current BB is so bad that I just want to replace it and not clean it.
I am not a mechanic so forgive me for the lack of knowledge.
AFAIK BBright is the type of BB. It is a standard of BB.
If my current BB IS "PRESS FIT" type (see first link below) does this mean BBright is not the actual type I need ?
What I currently have on my bike is this exact type :
So this is one option to buy (60$ + shipping to the **** hole where I live)
Having said that, Is this a better choice ?
More options ?
More options ?
Liked 1,722 Times
More options ?
More options ?
But many cranks that came with BBRight bikes were BB386, and used 7mm spacer under the driveside crank to fill in that distance. That was the way the Rotor equipped bikes did it. So if you have one of those cranks and wanted to use an adapter BB like the Rotor one you've linked to, you would remove that thick driveside spacer, possibly substituting a very thin spacer. You'd need to look up the correct spacer configuration for your crank.
Otherwise, the BB in your first link is the PF30 that you currently have. You'll need to remove the old one by punching it out and then use a bearing press to put the new one in. Fancier BBs like the Rotor are often screwed in, so you'd need that wrench size.
Clear as mud?
Quoted: 34 Post(s)
There is a 3mm thick spacer on one of the Rotor cranks. It closes on the crank but if I tighten it too hard it slides and I think the bad thread is on the crank itself.
Can I just tighten it with a Loctite threadlocker ? It is not not suppose to move anyway ....
Liked 1,722 Times
Depends. Either it is stripped, or you just turned it too far out of its range and you need to start with more spacers. And you might just have a stripped adjuster ring, not a stripped crankarm.
If it is stripped, you can make the system work with a wave washer on the NDS.
Quoted: 34 Post(s)
Does this include the bearings ?
Liked 1,722 Times
These cups essentially glued to the bearings.
Quoted: 34 Post(s)
This is the one I need to buy ? Again, does it include bearings ?
https://www.tradeinn.com/bikeinn/en/...E&gclsrc=aw.ds
Quoted: 860 Post(s)
Liked 1,100 Times
Below is the picture of the current headset I have.
Liked 1,722 Times
Quoted: 34 Post(s)
The entire headset in bikeinn costs me (with shipping) a third of the price of just the bearings in any store that ships to where the Ayatollahs just launched 300 cruise missiles yesterday ;-)
Liked 1,722 Times
That one won't work. The R3 has a tapered steerer tube. The one you link to is for a straight 1 1/8" tube, but the lower on your bike is 1 3/8".
Quoted: 34 Post(s)
OK. So basically for Cervelo R3 2013 I need these 2, right ?
Upper: MH-P03K - 30.15 x 41 x 6.5 - 36/45
Lower: MR031 - 37 x 48.9 x 6.5 - 36/45
Based on the info here :
https://www.airevelobearings.com/pro...2012-2017-kit/
Liked 1,722 Times
You can confirm those dimensions yourself.
Quoted: 34 Post(s)
Is anybody familiar with an online store called Aire Velo Bearings. They carry the bearings I need from an unknown brand manufactured in China.
Today everything is manufactured in China. SKF nor NSK do not manufacture the MH-P03K & MR031 which I need as they are headset specific bearing.
Do I have any other choice ?
Quoted: 34 Post(s)
I just noticed that in addition to ruined BB bearings the BB axle is very scuffed. Not replacing it will put load and destroy the new BB bearings.
I wan't able to find any catalog for rotor axles.
The only thing I know is that the axle is 30mm in diameter and 123mm in length (including the hidden thread).
