Dura ace 7800 long cage ?
Bikes: Workswell Carbon road bike and flyxll Carbon hard tall
Quoted: 7 Post(s)
Where can I buy a long cage for a dura ace 7800?
Likes For leicanthrope:
Bikes: All 80s Schwinns: 88Prologue, 88Circuit, 88Ontare, 88KOM, 86SS, 88Tempo, 88V'ger, 80V'ger, 88LeTour, 82LTLuxeMixte, 87 Cimarron, 86H.Sierra, 92Paramount9c
Quoted: 188 Post(s)
I think that would be custom since they were not available in long cage. 7800 was available in SS (short cage) and GS (medium cage) but not SGS (long cage). Generally speaking the long cages were for triple chainsets, which didn't exist in DA back then. DA seemed to be more about having minimum weight for racing, not about triples and long cages...
https://www.bikeforums.net/bicycle-me...atibility.html
Dura ace did make a triple group for 7800's
7803 .
If you insist on a D/A it will likely have to hunt one down on ebay.
7803 .
Likes For SSRI:
Quoted: 49 Post(s)
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
@SSRI is correct. They did make a DA 7800 triple. I know a guy who had that setup on a Calfee.
There is a brand new Dura-Ace 7800 long cage derailleur on Ebay right now.
New Shimano Dura Ace RD 7800GS Long Cage Rear Derailleur 10 Speed | eBay
Quoted: 188 Post(s)
[URL="https://www.ebay.com/itm/NEW-Shimano-Dura-Ace-RD-7800GS-Long-Cage-NIB-Rear-Derailleur-10-speed-/331880104137"
New Shimano Dura Ace RD 7800GS Long Cage Rear Derailleur 10 Speed | eBay[/URL]
Quoted: 49 Post(s)
To clarify there was a short cage (ss) and a long cage (gs) no medium cage.
Quoted: 188 Post(s)
Ahh I had the GS/SGS terms backwards darnit.
pan y agua
Quoted: 1447 Post(s)
Liked 724 Times
We have Dura Ace 7800 triple on our Co-Motion Tandem. Gearing is 53-39-26, and an 11-28 cassette in the rear. So a 44 tooth difference and it works fine.
You could get lost and die.
You could hit a tree and die.
Quoted: 188 Post(s)
FWIW here is a screenshot from the 7800 installation guide of the specs:
pan y agua
Liked 724 Times
Does it shift all the way from big/big to small/small? You can certainly run gears that exceed your total derailleur capacity as long as you don't mind loosing some on the end, but those you wouldn't really ever need to use / shouldn't use anyhow. Shimano has been known to underrate by a few teeth though.
In my experience, Shimano is pretty conservative in their specs. It has to work to their standard on every bike (regardless of chain stay length, and other variables from bike to bike) So, most of the times, Shimano derailleurs will work well past their official specs.
Quoted: 1199 Post(s)
Liked 1,354 Times
Instead of a new thread i figure id get info here. Being that its on the topic of a mid cage 7800 rear derailleur.
Would I be able to run a 11-32 or larger cassette?
I currently have a 12-25 with 53-39 front chainring.
Cost me a shiny penny some 5 years back for this 7800 derailleur
Quoted: 1528 Post(s)
Liked 718 Times
Suck it and see. If not, get one of those wolf tooth things.
Likes For Kimmo:
Get a XTR 9-speed rear derailleur. The 9-speed versions can be had for much less than $100. I've seen a few pass through our local bike Co-op - donated.
The XTR units are made to the same level of quality of workmanship and materials as the contemporaneous Dura-Ace 9-speed units.
Of course, Shimano road and MTB derailleurs and shifters of this era were cross-compatible.
Likes For Dave Mayer:
Liked 1,354 Times
Likes For malcala622:
Expired Member
Quoted: 3671 Post(s)
Liked 5,424 Times
The cage isn't going to change whether the 32 clears the pulley. It's unlikely that it will, but depends on the configuration of the dropout. Try it and see. If it doesn't work, Wolf Tooth, MTB derailleur or reversed B screw are some options. Why not go to a compact crank if you need easier gearing?
Likes For shelbyfv:
Quoted: 344 Post(s)
Liked 20 Times
Keep in mind that the parallelogram design of the rear derailleur governs how wide the rang is for the mech to shift. The cage will not guarantee the size of the cassette to be used.
Licensed Bike Geek
Liked 1,354 Times
Thanks for this straight up answer. 2nd option was going 12-28 cassette and 50t big chainring. Theyre easily avaipable.
@shelbyfv thanks for that suggestion. It was a option i had in mind.
In the wind
I'm using that derailleur with a 12-30 cassette with zero problems. I don't think anything larger would fit.
