3/32 or 1/8 drivetrain for flip flop hub?
Quoted: 28 Post(s)
Wondering if there is an advantage to one or the other when using a flip flop hub that will see use on both the fixed and the freewheel side. 130 bcd. I’m kind of leaning towards going 3/32 for the lighter weight but that’s not a major concern. The biggest thing would be durability of the drivetrain so I’m not constantly spending money replacing worn parts. I’m a small dude that pushes lower gears so I guess that could help in the longevity of the drivetrain? Thanks for any help.
Quoted: 1332 Post(s)
Liked 398 Times
Doesn't really matter in a practical sense, unless you're using a 3/32 chain (which would not be compatible with 1/8 parts).
aire díthrub
Bikes: Raleigh Competition, Pashley Roadster Sovereign, Mercian Vincitore Speciale
Quoted: 259 Post(s)
Liked 55 Times
Unless you’re an actual track racer, then 1/8 doesn’t offer you any advantage. I know a lot of people will take issue with that, but I don’t know of any evidence one could cite to refute it. A 3/32 chain is plenty strong enough for every day fixed or single speed use. Which one you choose should more or less depend on the rest of your drivetrain. 1/8 components for fixed/ss are more common because they’re more popular, so you have a wider selection generally. But that’s really only true if you have a 144bcd crank. If you have a 130bcd crank, then you actually have a larger selection in 3/32 chainrings. you can purchase 3/32 cogs/freewheels and chainrings just as easily and cheaply as 1/8. I run 3/32 on my ss/fixed, have been for years. Good thing about 3/32 components is that they are compatible with a 1/8 chain. Obviously 1/8 isn’t compatible with 3/32 chains, but I’m sure you knew that. You wanna run 3/32, go for it mate. As far as longevity, I don’t think you’ll get less life out of a 3/32 setup, especially if you’re pushing an easier ratio. I normally push 78 (ss) and 88 (fixed) inches using a connex 808 chain with no issues.
Liked 398 Times
The Germans used 11-speed chains and sprockets at the Rio Olympics and won the match sprint on them. The strength argument for 1/8 is pretty much void but there probably is a difference in durability over time. For the average user, just go with whatever's more convenient/afforardable for you.
https://bikerumor.com/2017/03/09/bfs...xed-gear-bike/
Quoted: 4802 Post(s)
Liked 3,923 Times
The plus of 1/8" chains is that they are harder to throw off the cog. Not an issue on the track where cranksets are of high quality and round and chain slack is carefully monitored. Where flats are never repaired then the wheel but back on in the dark by an inebriated rider. Where potholes are never hit. But in the real world of road fix gears, 1/8" chains are simply more rock-solid and stay on better, allow you to use cogs and chainrings longer and are more forgiving with lower quality cranksets, hubs and cogs (that don't run especially round, leading to the chain tightening and loosening every revolution and requiring more slack at its slackest to keep the tightest from being too tight.
I started on 3/32" chains and rode them for 25 years. Life has simply been better since I switched. 1/8" starts at higher prices, but over time, that levels out as everything lasts longer.
Ben
Ben
aire díthrub
Quoted: 259 Post(s)
Liked 55 Times
the only true advantage of a track chain is it’s better performance under high torque load, because that’s what it was specifically designed for. This goes back to the first sentence of my first comment ...”unless you’re a track racer...”
i ride a dura ace 7400 130bcd crank on a 7400 bb, using an early dura ace 3/32 road chainring. I run a connex 808 chain. A white industries freewheel and an EAI deluxe fixed cog. My chainring isn’t 100% perfectly true round. It’s not even remotely an issue. Been running for years and I routinely push about 90 inches on fixed. I’ve had more than one dura ace track chainring that wasn’t perfectly round as well, just for FYI. I knew someone would end up spouting this nonsense in defence of 1/8, because if heard it many times before but none of it’s true. More importantly none of it matters if the OP has a 130bcd crank and has already stated they were using an easier ratio.
to the OP: for easier clarification to get above this cloud of nonsense, both 1/8 and 3/32 are perfectly fine for everyday use. there is absolutely no danger in using 3/32 unless you don’t setup your drivetrain properly, and I’ll give you the benefit of the doubt in believing you’re smart enough to do it proper.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
IMO, there's no benefit to running 3/32" chain on a SS/FG bike.
aire díthrub
Quoted: 259 Post(s)
Liked 55 Times
lighter weight.
Much larger selection of chainring sizes and styles.(especially if you’re running 130bcd like the OP)
Larger selection of quality chains.
equal selection of quality cogs and freewheels.
Running 3/32 gives you cross compatibility with 1/8 chains should decide to use one.
There are track specific/track quality components for 3/32 if you choose to spend that much.
bonus: if you have a slightly mismatched chainline, a 3/32 chain which is designed for side flex, is more forgiving and is less likely to be thrown off.
there are individual benefits to both sizes and running either one is perfectly fine, but to say there is no benefits to 3/32 is just silly. I get that in a way, we’re all just defending our personal choices but I would argue there are more practical benefits to 3/32 for the average non sport/competition rider. The main reason track riders still predominantly use 1/8 is part tradition and part performance on the track. If you’re not on the track or you’re pushing less than 100 inches, then using 1/8 is perfectly fine, but perfectly unnecessary.
Old fart
Liked 3,400 Times
Ok. I'll give you that, if the trivial weight savings is important to you.
1/8" chain can use every 3/32" ring or cog out there, and any 1/8" ring or cog. So, 1/8" chain will actually give you more selection.
Isn't that what I wrote?
aire díthrub
Quoted: 259 Post(s)
Liked 55 Times
the weight savings isn’t trivial, especially if you want to run larger sprockets and chainrings. The cogs, chainrings, chains and often the cranks are all lighter weight. Every defence so far of 1/8 is only beneficial to someone putting down heavy torque pushing heavy gears on a velodrome. Which, surprise! is exactly where 1/8 shines. But the OP isn’t a track racer and they aren’t building a track bike. So I’ll defer you back to my very first sentence in this thread and then repeat: both are fine, but for the non sport/competition rider, there are more practical benefits to 3/32 over 1/8.
Old fart
Liked 3,400 Times
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12762 Post(s)
Liked 7,677 Times
aire díthrub
Quoted: 259 Post(s)
Liked 55 Times
Here, have a 🍪 for your experience. Cheers mate.
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2632 Post(s)
Liked 3,147 Times
Bikes: everywhere
Liked 7,677 Times
My Raleigh Preston came with 1/8" chain, but 3/32" cog and chainring. I dunno whether to blame the British or the Chinese.
Bikes: I don't even
Quoted: 81 Post(s)
Liked 193 Times
The main benefit of 1/8" chain is that you can mix and match 1/8" and 3/32" cogs and chainrings without issues. Run a 3/32" cog on one side of your flip/flop hub and a 1/8" cog on the other -- no problem. Run a 3/32" chainring with a 1/8" cog -- no problem. Run a 1/8" chainring with a 3/32" cog -- no problem.
Most of my experience is on the track, but this holds even more true there. Whoever is running 3/32" chain is always odd man/woman out whenever they are looking to borrow a different cog or chainring, but 1/8" users can borrow any gear from anyone. Mix and match does not present any problems in the real world.
Weight difference is negligible. On the street where so many riders use no brakes, why someone would want to shave weight from their only means of stopping is beyond me.
Bikes: I don't even
Quoted: 81 Post(s)
Liked 193 Times
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Look at the badass new guy in this thread! He knows all the decent bike mechanics, and if they approve of 1/8" chain on 3/32" sprockets, they're not decent!
Clark W. Griswold
Quoted: 4348 Post(s)
Liked 3,984 Times
I just wanted to say that whatever standard you choose to run unless it is my standard you are probably doing it wrong.
