Chain length help
Chain length help
So I just got a 19T cog for my bike to replace the 17T during the winter and I'm having a bit of trouble deciding on the right chain length. Heres my predicament:
If I leave the chain its current length, I have to completely slam the rear wheel into the dropouts and break the chain in order to get the wheel on and off when using the 19T cog.
Option number 2 is adding an extra link to the chain. However, if I do that, here's what happens when I try to use the 17T cog...
Both not exactly ideal scenarios as I would like to be able to use both cogs interchangeably without switching chains.
Which is the better option? Slammed 19T or 17T way in the ends of the dropouts?
Also, I definitely think a half-link would be perfect in this situation. Does anybody know where I could find a half-link compatible with a KMC K710SL chain?
Quoted: 71 Post(s)
Liked 12 Times
Definitely don't go the slammed wheel route, breaking a chain just to change a flat is more work than it's worth.
With the extra link added and using the 17t cog you don't need to have it backed out that far. Looks like you could scoot the wheel forward and have a little slack in the chain.
On the other hand though, I really don't like riding with a slack chain, it feels too sluggish
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
My method, for consideration:
Every winter, I not only flip my wheel around to use the bigger cog, but swap to a smaller chainring. By losing 3 teeth in front and gaining 3 teeth in rear, I'm able to use the same chain throughout the year without changing the axle position. It works for me, but I could understand that being too much futzing for some people. You could also get dedicated summer and winter chains that are allowed to be different lengths.
If I went down a few teeth on the chainring I think that might effect my gear ratio too much for my liking though. For reference, my summer setup is 46-17 which equates to around 72 gear inches. For winter I'm using 46-19 which is around 64. 42-19 or 44-19 would get me down to like 60 which might be a bit too low for my taste.
I decided to go for the longer chain setup for now and I am really liking the 46-19 ratio with my fatter winter tires. What Ill probably do is either use dedicated summer and winter chains like you said, or get a half-link chain like the KMC HL710 that will allow me to fine tune the chain length more.
Liked 2,568 Times
If you go to dedicated chains, a half-link chain is probably overkill to get the right length(s). Track ends like yours allow a lot of adjustment.
Quoted: 18373 Post(s)
Liked 4,509 Times
I'm not sure I'd worry about the place of the wheel bolts as long as it is in the dropouts. If the chain stretches, say 1/2", then that will push your wheel back just under 1/4", and you will be close to being too far back (but then it will be time to change your chain.
As @hardboiled718 mentioned, getting the wheel off to fix flats will be important.
KMC does sell 1/8" half-links that should work.
https://www.amazon.com/KMC-Half-Link.../dp/B00288K96C
It won't mach perfectly, but as long as you keep pedaling, nobody will notice.
Liked 4,509 Times
Here's the silver one.
Half Link 1-Pitch type Wide Silver Z510HX for Tour, City & Fixed Gear | KMC Chain
Assuming you don't want galvanized.
Half Link 1-Pitch type Wide RB (Anti Rust) for Tour, City & Fixed Gear | KMC Chain
You could, of course, break up the half-link chain, and have over a hundred of the half-links for dirt cheap.
Then, get a bunch of the "bullet pins".
https://www.amazon.com/KMC-Bullet-Pi.../dp/B008XHU6CY
(or then again maybe its just me)
Liked 4,509 Times
https://www.kmcchain.com seems to be in Chinese. The English version appears to be the .eu site.
With the part number, you should be able to order the part, although the black links seem more common than the silver ones.
If you chew through enough chains, I'd be tempted to hunt down a half-link chain + a bunch of chain pins. But, say 2 chains a year... 100 links, that could last you 50 years.
https://www.ebay.com/itm/KMC-HL710-S...e/303001269173
https://www.ebay.com/itm/6-Count-Car...s/321767839104
Odd...
https://kmcchain.us
I cant even seem to find the black single 1/8in half links on there though. The only thing I see are the entire half link chains:
https://kmcchain.us/chain/hl710-silver/
MSRP is only $15 though so I figure it might just make sense to just swap my whole chain and be done with it (just using those from now on.) Either that or I could go with something funky like this:
https://kmcchain.us/chain/kk710np-kool-knight/
cant decide if i love it or hate it. Bit pricy though.
Edit: Dont know why these links didnt show up as hyperlinks...
Liked 4,509 Times
Perhaps the color of that single half-link won't make a big difference. It will be easier to find on the chain.
Z410-OL - KMC Chain
But, it is odd, the selection.
This one comes with the silver half link as part of the chain, which would just seem natural as part of the design of the single-speed chains.
Z510HX - KMC Chain
Of course, you were using the "super-light" version of the chain.
K710SL Silver - KMC Chain
I think I'd still tend to buy the half-link chain, and start whittling off pieces. Or... how much do you have to shorten your chains? Perhaps use the half-link chain, and re-use all the extra half-links.
I cant even seem to find the black single 1/8in half links on there though. The only thing I see are the entire half link chains:HL710 Silver - KMC Chain
Liked 2,568 Times
Half-link chains are known to elongate quicker than full-link chains, that's why I recommend against if you don't need one.
Liked 4,509 Times
I've wondered for some time of the "stretching" of chains was actually occurring in the chain plates rather than at the pins, especially in multi-speed bikes.
So, I could imagine the shaped half-link plates would be at greater risk for stretching.
Liked 2,568 Times
Odd, the number of pins is the same, as well as the basic pin design.
At least, that's my understanding. I'd be surprised if plate deformation played more than an infinitesimal role in all of this.
plus Ill have a lifetime supply of half links...
Here's a question from a relatively inexperienced bike mechanic: when I'm breaking a chain, can I not just reuse those extra links no problem? How come I need these bullet pins you linked to?
Edit: I see there is a discussion around this, interesting stuff guys
Maybe its OCD on my part, but would you want to ride that? It just feels a bit icky to me. But hey, I'm the one asking you guys.
Liked 4,509 Times
It's not a big mystery in this case. With a full-link chain, the pin-to-pin spacing is fixed for each outer link. No matter how much the pins and bushings wear, the two pins for each outer link will never get further apart. So all of the elongation you see is the slop that allows the inner links to migrate outward from each outer link. With a half-link chain, you get that migration in both directions at every single pin, so the elongation adds up twice as fast.
So, a 100 link chain will have 100 outside connections, and 100 inside connections, no matter whether it is made up of 100 full links, or 100 half links.
I've seen images on the web about chain pins with deep notches. But, I've felt some of my pins that I've removed, and they still seem smooth. Perhaps I'll have to look a bit closer at how the pins fit into the inner links.
Liked 4,509 Times
yeah that might be my easiest option if I want to keep using my current chain, which I do kinda like.
Here's a question from a relatively inexperienced bike mechanic: when I'm breaking a chain, can I reuse those links no problem? How come I need these bullet pins you linked to?
However, the vintage chains had essentially round cylinders pushed into the plates. (or the hollow cylinders used in your Super-Light chains), and held in place with friction (and a little pin sticking out).
With the advent of 9/10/11 speed chains, companies started mushrooming the ends of the chain pins.
When you press out a mushroomed head, a ring of steel breaks off.
Push the pin back in, and you no longer have that ring of steel, and even worse, the end may be tapered from where the ring broke off, or the plate may be slightly enlarged from pushing the mushroomed pin through.
There likely is little need to mushroom the pins on 1/8" chain, especially for the casual non-racing users.
However, looking at the KMC website, it looks like half of their 1/8" chain pins are mushroomed, and half are not.
So, the answer really depends on what you actually have on your chain.
In theory, one can 100% remove a pin, and push it back in. But most amateur mechanics have learned that it is a pain to push a pin back in that was fully removed. And, one takes care to only push the pins out 90% of the way (and wiggle the chain slightly to get it loose).
The new "Bullet Pins" are designed for easy installation. I'm not seeing a lot of notes on sizes. They should be listed for 1/8, 3/32, 9spd, 10spd, 11spd. As far as I can tell, the KMC Bullet Pins that I'm seeing are all for the 1/8 chain.
Liked 4,509 Times
Interesting, looking at the KMC site. Some of the 1/8" chains appear to have full bushings, rather than the pressed half bushings that have been common on chains in the last few decades.
Bushing Construction
CITY HUNTER - KMC Chain
410H-NP Silver - KMC Chain
410H - KMC Chain
One gets lost in their wear estimates for each chain design.
Double-X Durability
Triple-X Durability
Diamond Like Coating
E-Bike
Salt Spray
Stretch Proof Treatment
etc.
410H - KMC Chain
Double-X Durability
Triple-X Durability
E-Bike
Salt Spray
etc.
Liked 4,509 Times
BTW: I got the .com page working. Don't know why it wasn't working earlier.
This is your half link.
https://www.kmcchain.com/en/product/...l-single-speed
Some items have a buy link, not others.
Product numbers seem to vary slightly between websites.
You probably don't need 'Em.
I don't make that mistake anymore but I do notice when I take links apart and put them back together, they are always too tight. I have to pry the plates a tiny bit further apart after I drive the pin through them in order to get a nice 'wiggly' connection (am I perhaps doing it wrong? Idk)
I was kinda figuring I didnt need those bullet pins though because, like you alluded to, my chain doesnt have mushroomed pins
Really appreciate all the info! Thanks!
Exactly...
I mean you're right this is exactly what I'm looking for. Now kmc just needs to take my money and give me one. I followed the link on the .com website to the "global store" where they then link to the .us and .eu stores. The .us site doesnt seem to sell these individual half links while the european one does.
so I guess us north americans have to just buy a whole half link chain just to use one link, huh? Cool kmc... cool.
