Giving up Ti and going back to carbon
6-4 Titanium
Quoted: 92 Post(s)
Liked 36 Times
I really like my Litespeed titanium road bike but to properly convert it to disc brakes it would cost a fortune. Basically $1100 to get the disc tabs welded in the rear, remove the original brake studs, and a bunch of other miscellaneous stuff. Then it would cost me probably around $300 for shipping, and probably another $600 for an Enve carbon road bike disc brake fork. Then on top of that I'd still need to change my group to a disc brake group...and to keep things budget I'd probably settle on a 105 disc brake group which is another $600.
So total cost to convert an old Litespeed Ti road bike to disc...$2600...lol and who knows how good those welds are gonna be. I'm sure it'll be fine but who knows a lot can go wrong I guess.
I can easily get a carbon bike with a full Ultegra disc groupset, thru axles, all the bells and whistles, etc. easily for less than the cost of that modification/upgrade.
Unfortunately a new disc brake ti bike equivalent to my current Litespeed is going to cost around $6k with a good group. Just can't justify spending over $3k and up on a bike however.
So as much as I love Ti I am back to carbon.
Quoted: 1163 Post(s)
Liked 442 Times
Is converting a rim brake classic Litespeed road bike to disc even possible? Maybe somebody that does a lot of custom ti work might take on the task of retrofitting a flat disc caliper mount on the rear non-driveside chainstay but then there is the issue of rear dropout spacing from QR 130 to QR 135mm. Not ideal at all.
So how does the bike ride right now? Is the rim braking lacking in some way? Can you optimize it in some way?
If you really want disc and titanium I 2nd what the previous poster put up about the Bikes Direct “Motobecane” model. There was a thread about that bike last week & it sounds like a great value @ ~$2,000.
Having a titanium hydraulic disc sloping top tube tapered fork through axle properly designed road bike frame to me is a great investment. Paying the upcharge for something really special is probably worth it. I imagine if you keep looking, you’ll find some more affordable options out there.
But rebuilding a classic ti road bike into a configuration it was not originally designed for, would account to future disappointment. For one, your tire size options would be terribly limited. This nullifies one of the coolest things about disc road frames, the flexibility to use disc only rims with whatever tires your heart desires.
Better to start with a proper, modern disc platform...
Likes For masi61:
Likes For noodle soup:
Duke Ulysses
Bikes: An old orange one for dirt, and for the other stuff: a white one, a kinda mint green one, and a black one.
Quoted: 165 Post(s)
Liked 175 Times
What's wrong with the "full rim brakes" on your Vortex?
Likes For growlerdinky:
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Nice bikes are expensive to build today. Is this shocking news? Buy a carbon frame and build it up with Ultegra--it will cost a similar $4-$5K easily. Buy it pre-built and it will still easily cost $3K+....unless you're shopping used or wicked sales.
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
Likes For Pirkaus:
Liked 8,925 Times
Quoted: 1020 Post(s)
Liked 463 Times
I once owned a Litespeed Classic. It was a very nice bike; I sold it because it didn’t fit me quite right (I bought it used).
I wouldn’t get rid of a nice Ti bike just to get disc brakes. Lots of alternative rim brakes, such as the TRP mentioned by others.
Quoted: 942 Post(s)
Liked 527 Times
Why don’t you just sell it and pick up a disc version on sale from Litespeed, Lynski, or Moto?
I’m the opposite I will not go back to carbon. My carbon bike is now my secondary bad weather bike.
Likes For jadocs:
6-4 Titanium
Quoted: 92 Post(s)
Liked 36 Times
Yes it’s possible, I got the quote to do it, it’s like $1100 for a full retrofit including rear dropout spacing to 135mm..This is from a reputable place that most people recommend. The litespeed vortex rides great…it’s as optimized as it can be as far as braking...good pads, toe in, etc. Disc brakes would perform better since I ride in the fog a lot.
As for the Moto I’m sure that’s fine for most, but I’ve tested that frame actually. Any real power on that bike and there is some ridiculous flex near the BB area. I literally felt like I was yoyoing when pedaling on that thing. You can’t really compare a 6-4 Ti litespeed vortex with oversized diamond shaped tubing and bladed rear triangle to some run of the mill motobecane ti frame. I’d say newer litespeed and Lynskey 6-4 ti frames are good but most run over $3k.
No you would not need to change groups. You need to do more research if you think so. The calipers are called TRP HyRd BTW.
Not shocking I was hoping to get away with not spending more than $500 for the modification. I was reading some threads on how some guys got a guy who knows a guy ti do it for $300.
Lynskey, has complete bikes in your price range.
Ya they still run over a thousand more than a carbon offering. I want to stay in the $2k range with ultegra disc group and can’t do that with Lynskey or litespeed. I think the extra grand might be worth it but can’t justify spending more than 3k. Seeing a couple of shattered carbon frames in the TDF this year sure gives me pause though about going carbon. Carbon is inferior to Ti without a doubt.
Nothing. Full Rim brakes simply don't perform as well as full disc brakes with all the fog / moisture in SF / Norcal.
Considering it actually. Lynskey's prices are not too bad. After tax though probably looking at $3500 after taxes with 105 for a complete bike where as a carbon with better specs...full Ultegra will be $2k.
Quoted: 942 Post(s)
Liked 527 Times
I think you can do better than that. This way you have a bike that is designed from the ground up for disc and you are not jerry rigging it.
Liked 442 Times
[QUOTE=MyTi;21026685]
That's a big expense to hot rod your Litespeed Vortex. The stiffer diamond shaped tubing and bladed rear triangle do sound nice. I'm building a Wittson Illuminati titanium disc bike. This Lithuanian builder is less known in the US but you might check him out.
I have procrastinated completing this build but apparently it is time. I have ridden about 1400 miles this year on my titanium bike, a Veritas with rim brakes and Dura Ace 7800 components. The ride is amazing compared with my old friend, my aluminum Flyte SRS-3 (which I have ridded over 10x as many miles on). The innate shock absorption of the titanium, combined with the oversized tubing of my Veritas (Ohio made) frame, added to my 28 x 28 hole Dura Ace 7700/Mavic Open Pro 2 cross wheels with lightweight DT Swiss butted spokes (not the standard butted ones) along with Vittoria latex inner tubes run at medium pressures (85 front, 89 psi rear) provide stiffness but with a non-jarring ride that I accidentally discovered. The bike I bought used and paid $675 for it. It is fantastic. The 7800 dual pivot calipers can handle rain and fog quite well.
Quoted: 3241 Post(s)
Liked 2,512 Times
Bikes: 2020 T-Lab X-3 w/GRX Di2, 2018 Trek FX-5S with GRX/Xt 1x drive train
Quoted: 44 Post(s)
Liked 41 Times
I just swapped my fork to one that has a disc caliper mount and a disc front wheel. That's where you need the best braking power anyway. it would be nice to have it on the rear too, but not $1100 nice. The rest of my frame is in great shape so no reason to upgrade more than required.
Likes For SCTinkering:
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
I vote for getting a disc front fork and keeping the frame standard. The fredlyness of mixed brakes is well deserved, and you can rage on both sides of the disc vs rim threads at your leisure.
Likes For znomit:
Quoted: 18415 Post(s)
Liked 15,545 Times
It's only a LiteSpeed. No real loss.
(geese)
(geese)
Likes For indyfabz:
Quoted: 601 Post(s)
Liked 779 Times
Just N+1 and keep your LiteSpeed as is.
You may then realize its still a pretty nice ride.
For the upgrade costs you could get a very nice N+1 especially if your willing to get a NOS or used model.
Likes For joesch:
Bikes: Norco search xr
Quoted: 198 Post(s)
Liked 146 Times
I would buy a disc frame from Lynskey and transfer parts. Shoot, I forgot you would need wheels and brakes too. Added costs, my bad.
Likes For Gconan:
Liked 8,925 Times
I would also suggest that if, for some reason, you are dead-set on disc brakes and want to stick with Ti, you should mosey on over to bikedirect.com, I believe they have options that are priced quite reasonably.
(ducks again)
(ducks again)
Quoted: 4717 Post(s)
Liked 1,882 Times
