Picking the Correct Size Seatpost, 26, 26.2, 26.4?
The Left Coast, USA
It's an old Japanese frame, had a non-stock 26.8 seatpost installed. Way too tight, I needed to twist it out with a pipe wrench. However, the seat tube and compression cut wasn't deformed, just over-tight at 26.8.
Would it be safe to replace with a 26.4, or perhaps down to a 26.2? Not clear on how much difference .4 actually makes in a seatpost fit.
Thanks.
Thanks.
There is more to life than simply increasing its speed. - Gandhi
Quoted: 453 Post(s)
Liked 104 Times
Buy some vernier calipers and measure, guesswork seems to have failed the previous owner, better not make the same mistake twice,
Try 26.6. I came into a 2000 KHS Flite with a 26.8 post wedged in. I looked up the bike online and the spec'd post was 26.6. I thought, "huh, I've never heard of that..." but duly went down to my LBS and there was a small bin of used seatposts of various odd sizes among larger bins of the more popular. Long story short, using the spec'd seatpost size worked like a charm. FWIW, the frame was Reynolds 520, of which I also previously hadn't heard.
Friendship is Magic
Bikes: old ones
Quoted: 26404 Post(s)
Liked 10,374 Times
...one of the things you realize after you've encountered enough of them is that seat posts are not always standardized at the diameter marked on them, and frames are not always reamed to the standards you expect. So if it's an alloy post, there's no reason not to carefully sand down the portion that goes into the seat tube a skosh to get .the fit you need.
If 26.8 went in there without deforming anything, and was just a little tight, going to something like 26.4 or less is a bad idea.
I cam measure ten 27.2 seatposts out in the collection in the garage, and only 5 of them will come in at what I need on a particular frame. Which is why I have a milk cratefull of seat posts.
Quoted: 836 Post(s)
Liked 1,061 Times
You might want to look into getting the seat tube reamed to accept a 27.2mm post as you'll have many more posts to choose from. BUT...…., have a good mechanic inspect it first to determine if the frames wall thickness is enough to do this. The .2mm that would need to be shaved off is very, very minor but still needs someone who knows what they're doing to make a judgement.
Quoted: 4201 Post(s)
Liked 3,856 Times
The time tested way to insure the best seat post fit it to try various posts and go with the best fit.
One question about the old/tight post. When removed were there any gouges from a burr inside the seat tube? If so then at least hone smooth the seat tube before testing for size. Andy
AndrewRStewart
AndrewRStewart
Quoted: 318 Post(s)
Liked 149 Times
The Left Coast, USA
The previous seatpost was pretty smooth, obviously some twist marks. OK, so I ordered a 26.6 replacement and keeping fingers crossed.
These sizes of seatposts aren't in my junkbox, circa 1980 frame.
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,217 Times
Thanks.
Thanks.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 4,217 Times
I don’t know where you get your posts or what is wrong with them but I’ve never had a problem swapping posts on a bike. My Moots 27.2 post will fit in my Dean frame (although they are dissimilar frames and might explode due to the incompatibility). My wife’s mountain bike uses a 27.2mm post and I put a generic post, a Race Face, and a Tito titanium post in it. My Cannondale takes a 27.2mm post and I’ve had the OEM Cannondale post, a couple of Race Face posts and a Thomson post in it without any issues of size. The same holds for the other 10 bikes in my garage. I’ve never had to measure a seatpost of any size for any bike...ever. I’ve been through a lot of posts in 39 bikes over my life while suffering from a severe case of upgradeitis.
Stuart Black
Stuart Black
Quoted: 604 Post(s)
Liked 1,063 Times
Both my 80s Panasonic frames, take 26.6 seat posts. Both from Japan obviously, ditto on the suggestion to try a 26.6 one.
Tim
Tim
Quoted: 5888 Post(s)
Liked 3,471 Times
It is difficult to measure seatposts with calipers and get an accurate reading. I keep meaning to buy a seat tube sizing gauge like this,
https://www.universalcycles.com/shop...BoC0MoQAvD_BwE
Quoted: 1062 Post(s)
Liked 665 Times
I've measured a few frames for seatposts. Calipers have worked -- either poorly or not at all. The reason is that, if I'm resorting to measuring the frame, it's often because I also have a reason not to trust the diameter at the top of the tube. I've had good results with an inside spring caliper for going a couple inches down into the post and see if the diameter is uniform before making the final call. Getting within 0.2 mm takes some practice, and there's a good reason why machinists don't use those tools any more if they can avoid it.
An error of 0.2 mm in diameter would be 0.6 mm in circumference -- enough to notice in deformation of the slot.
This thread reminded me yet again of my seatpost woes. My Kuota takes a 30.0 post, a size only available in alloy from Thompson as a replacement. I tried a cheap Chinese carbon post in 27.2 (nothing wrong with it at all) and a shim, but I can't get it to stay put. It is always slipping down on a ride until it bottoms out on the bottle boss. Yes, I tried carbon paste too. The original post from Kuota had the ridges stripped that held the saddle and the saddle wouldn't stay with that one. So I went on ebay and lo and behold an original Kuota was up for cheap. I bought it but my concern is it will have the same problem as my original. We'll see.
I'll use the Chinese carbon post on my commuter as an upgrade. It won't make any difference in the ride but what the hell, it's carbon.
Most of the low-medium-level Japanese bike-boom frames use 26.4. Higher-tier frames have thicker seatposts.
Quoted: 1324 Post(s)
Liked 927 Times
Cheers
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
i have a schwinn super le tour spec'd for a 26.4 post. i wanted to try a 26.8 post before i knew what it was spec'd for and it simply wouldn't fit. sounds like you made the right choice
Liked 3,856 Times
Seatpost size is a frequent topic here. Almost a year ago I took the time to measure a few posts I have. here's a link to that thread.
https://www.bikeforums.net/bicycle-m...post-size.html
BTW the sizing tool (Stein's or other copies) is only the start of proper sizing. It will gage the top of the seat tube, about .5" depth (this for my Odyssey brand size gage). Great to have a sort of first size to trial fit. But seat tube distortion (from either heat and fit up at the time of the frame's being made or too small a post being used previously) is often focused at the bottom of the lug (or where the top tube or seat stays attach). Way too deep for the sizing gage to reach. I've fitted test posts fine at the seat tube's top only to have that post jam when inserted a few inches more. Andy
AndrewRStewart
AndrewRStewart
Friendship is Magic
Bikes: old ones
Liked 10,374 Times
I replace a lot of seatposts at my local co-op and if a frame takes a 27.2mm post, for example, I can pull out any post stamped with 27.2mm at random and it will fit. That includes posts made by Thomson to generic steel posts taken out of 1980s practically throwaway bicycles. There’s lots of seatposts out there and there’s really no need to sand one down.
On that we can agree.
Likes For 3alarmer:
Liked 4,217 Times
I have 11 bikes and 2 frames in my garage. One of the bikes and one frame use 30.8mm posts. The rest use 27.2mm posts. That’s 9 bikes with that post size. I have swapped posts around on all of them. Not a single post has every not fit in any of the frames. Not too tight or too loose. Each has fit exactly as I would expect it to fit...i.e. just right. I have exactly the same experience with the 30.8mm posts. I have the same experience at my co-op where I replace a lot of posts. That’s not opinion. It’s fact.
I replace so many posts at my local co-op that I’ve gotten pretty good at guessing the size and being close in most cases. And, again, if the bike takes a certain size, all of the post marked with that size fit like they were made to fit.
And, since I know you’ll never believe me on anything, check Andrew R Stewart’s link. He saw some variance but , honestly, it would be so small as to not make any difference in the way the posts fit in a frame. He certainly didn’t seem to find that 50% of the posts were out of the standard.
Stuart Black
Stuart Black
Friendship is Magic
Bikes: old ones
Liked 10,374 Times
Considering that you are the one who claimed that seatposts vary all over the place, I find it rather interesting that you claim my experience is “opinion”. I don’t measure posts on a regular basis but I don’t find that there is enough variance that once a post size is known that any other post of the same size won’t fit. I certainly have never found only half of all posts of a given size will fit in the same frame.
Not sure why you continue to tell me about all the bikes you have now, have had in the past, and your continuing work as an unpaid volunteer. Keep your day job, though.
I only have about four project bikes going right now out in the garage, but I think at one time I had as many as 20 of them, all lined up and ranging in age from the 1950's to the 1980's (maybe one or two from the 90's). Which is why I have the milk crate full of various sized seat posts. Right now I'm working on a '58 Lenton.
I tell you this not to impress you, only to point out that once I quit managing the co-op here on Saturdays, I had a lot more time to work on them. The Lenton and a Raleigh Record Ace from 1973 might be the last of them,
It's wrong to say I don't ever believe you. You're my go to guy on chemistry.
Friendship is Magic
Bikes: old ones
Liked 10,374 Times
Liked 4,217 Times
Yes. And I saw nothing that suggested that half of all seatposts are the wrong size. Did you see something there to suggest that? Please provide a link.
Stuart Black
Stuart Black
Liked 4,217 Times
...seat posts and steel frames (my particular interest...I honestly don't know much about aluminum) are made to standard. The standard varies. In seatposts and steel frames it's not uncommon to see variations as much as .1 mm. That's enough to make for a good fit, a loose fit, or a tight fit. Which is the OP's issue. If you don't measure posts on a regular basis, why are you an expert on this topic ? (As you are on so many, many others, Stewart.)
...the fact that you replace a lot of posts in a co-op environment is unimpressive. I've worked in a co-op environment, and I know the QC standards for what rolls out the door. Your idea of a good solid slip fit between post and seat tube is not the same as mine. Some of us have high standards, Stewart.
....again, and for the last time I hope, your idea of a good fit and mine may or may not be the same. I want the post I ride on to have a solid contact with the seat tube it rides within, so I don't need to worry about over tightening the seat clamp if and when something that is a little loose in how it slides slips. I'm glad that this has worked out so simply and so well for you, because you seem to have a penchant for the absolute. In this case, over the years that frames and posts have been manufactured, it saddens me that we, the rest of the world, have let you down. "Out of standard" is a pretty poor describe what's going on here. "Standard" varies with your particular purpose and use.
I agree that there is some variance in seatpost diameter. That’s normal. But it ‘s a matter of magnitude. I just don’t see variance as large as you make it out to be.
Stuart Black
Stuart Black
Friendship is Magic
Bikes: old ones
Liked 10,374 Times
...just to be clear, Stewart, I don't know jack about chemistry.
