Silly question about frame geometry of gravel bikes
I've noticed that all of the gravel bikes that I have seen so far have top tubes that are shorter than their respective 'effective top tubes' (i.e. the top tubes are more parallel with the down tubes).
The above mentioned trend is so dominant that I have to ask: in the industry's terms, would a bike still be considered a 'gravel bike' if it has nearly all the same forks, wheels, tyres, and other parts but uses a 'Randonneur type' frame instead (where the top tubes are parallet to the theorectically flat ground; where the top tubes are the 'effective top tubes')?
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,057 Times
Well, ask a silly question, get a silly answer. My silly answer is that if this "sloping top tube" trend continues unabated, then 20 years from now, us guys will all be riding girl's step-through frames (as well as wearing dresses and playing with dolls).
Why are virtually all gravel specific bikes made and bought with sloping top tubes?
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Higher stack + crotch room. Without the crotch room it's just a rando bike.
Seriously, I think the whole slanted top tube thing is to allow a single frame size to accommodate a wider range of human sizes, so a manufacturer can get by with 5 frame sizes instead of 6. Yet another way to cut costs.
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
if a level top tube frame and a sloping top tube frame have identical HTA, STA, trail, bottom bracket drop, tire clearance, chainstay length, stack height, and reach- then yeah they are capable of doing the same things and feel free to call them the same thing.
a decent real world example-
I have a black mountain cycles gravel frame with canti brakes that uses a level top tube. The disc brake frame has almost identical geometey, but uses a sloping top tube to get a higher stack height as that's the one measurement thats different.
both are gravel frames.
If the important geometry is the same, then sure it's a gravel bike. Call it that if you want...it isn't a big deal either way.
Virgo
You probably won't see many level top tube frames MARKETED/SOLD as gravel bikes, but I don't think there are that many level top tube frames on the market anyway. My commuter has a slightly sloping top tube, was sold as a hybrid when new, has cantis, clearance for 38mm tires, gravel/cross geometry, etc. I think I could call it a gravel bike if I wanted to, but I don't do "gravel rides" aside from an occasional 1 mile stretch of a gravel road on my commute, which my bike handles admirably. In other words, if a frame works for a certain purpose, isn't it whatever you make it to be?
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
Sloping top tubes has been the industry norm for road bikes for many years. This is not something specific to gravel bikes. There are some exceptions, but not very many that I am aware of.
Quoted: 6963 Post(s)
Liked 10,964 Times
A sloping TT might be a small advantage with a gravel bike, as it will better allow a fast and sloppy dismount when the going gets rough. It also allows for more seatpost extended beyond the frame, which might dissipate some shocks and chatter that would otherwise be transmitted to the saddle. But that's not why the manufacturers are putting them on bikes.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Virtually all bikes made recently utilize compact frames with sloping top tubes. This is not a uniquely "gravel bikes" phenomenon, this has been an industry-wide trend for years.
I think gravel vs rando, the gravel bike will tend to have less BB drop, and a shorter chainstay. So, slightly higher BB and quicker rear end that a rando bike. That said if you compare geometries on multiple bikes there's overlap all over the place.
Bikes: Specialized Ruby Sport
Quoted: 318 Post(s)
Liked 314 Times
I never understood why men's bikes had the horizontal top tube. Seems you guys need the clearance more than us ladies do. We don't have dangling bits to worry about smashing.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Occam's Rotor
Liked 2,331 Times
Occam's Rotor
Liked 2,331 Times
(Then there are people like me who have short legs, so all our bikes look like this.)
Bikes: K2 (Marzocchi/Fox), Trek 6000 (red) MARS Elite up front, Specialized Hardrock Sport -> eBike (R7 Elite up front), lastly TREK 820 loaner. Recently sold Peugeot du Monde Record and 1956 Schwinn (owned since new).
Quoted: 75 Post(s)
Me too. 5'11'' with 29" inseam. I'll take a sloping top tube any day
