Schwinn Voyageur 11.8
aka: Mike J.
I just picked this one up this weekend, don’t know if it is a keeper or not.
I’m having a little trouble finding the serial number on it. The headbadge is stsmped with 0347, and on the bottom of the bottom bracket there is 80 12 13817 . I find no numbers around the headtube, none on the rear dropouts, none elsewhere around the bottom bracket unless they are hiding under the paint. Based on the headbadge I’m guessing it is from 1977 or 1987. Gearing is 2x6, Altus LT rear derailleur, 27” wheels (and I just sold off all my 27” wheels except for a French pair).
The fit works for me at 57ctc seat tube and top tube. 170mm Super Maxy cranks with some Kyokuto Top-Run pedals. The seatpost and stem are not stuck.
Handlebars still have some cloth tape wrapped on the lower portions. The dangerously sketchy looking tires held air enough for me to ride the bike sround the block.
The bike is made in Japan, 4130 double butted tubes. Right now just trying to confirm the age and pricing a set of tires for it.
Life happens, don't be a spectator.
aka: Mike J.
It does have sort of an interesting saddle clamping system.
Good snag! They are fine bikes to fix up and ride. I have the same one and size as yours. I believe you have an 81. They were made only in 81-82 years. Might be wrong. Yours could have been strapped in 80 for the next year run.
The black and red accents are quite smashing when you get it cleaned up. Components are quite good but not high end. Certainly nothing for some to sneer at.
You can make 700 wheels wrk with the brake set it came with. The seatpost is a pain to work with.
Keep us informed as you proceed!
BTW... 11.8 is in reference to the weight, 26lbs. Easy to beat it with simple upgrades if you so desire.
Quoted: 796 Post(s)
Liked 522 Times
Nice chrome "socks" looks like it will clean up into a nice rider. I have had good luck with Panaracer Pasalea's and Swift Sand Canyons for a nice plush ride in a 27" tire.
aka: Mike J.
I found an old saddle in a corner of my garage that says Voyageur on the rear of it and it even has some red accents that make a nice match to the bike. Has sort of a grippy cloth-like covering that I’m not sure how long it will last, but that one is on the bike now. And that saddle clamp is a hassle to deal with.
I’ve got a couple sets of old 700c wheels that I’ve still kept hold of so I will play around with those to see how the brakes match up.
Not decided what I might do with the gumbo brake hoods on the bike. I’ve got some aero Tekro brake levers that I might play with as well on this bike. Not overly long ago I sold off the 1989 Letour I had and I still miss that bike (it lost the coin flip during a downsizing purge session).
I took the risk with the tires and took the bike for another lap around the block, it is kind of growing on me.
Bikes: 1968 Raleigh Super Course, 1972 Raleigh Professional, 1975 Raleigh International, 1978 Raleigh Professional, 1985 Raleigh Prestige, 1972 Schwinn Paramount, 1980 Schwinn Voyageur 11.8, 1960 Carlton Franco Suisse Peugeot PX10, 1972 Motobecane Le Champ
Quoted: 323 Post(s)
Liked 690 Times
Is there any chance that the last digit on your headbadge is a 1 and not a 7? This bike was definitely not available in 77 or 87, but right in the middle; 80, 81, 82.
aka: Mike J.
Headbadge
Quoted: 323 Post(s)
Liked 690 Times
Okay, thanks for the pic. It’s clearly a 7. Still, your bike with its color scheme and decals appears in the Schwinn catalogs for 1980, 81, and 82 and no other years at all.
Friendship is Magic
Bikes: old ones
Quoted: 26419 Post(s)
Liked 10,380 Times
^^^what the other guys said on dating. I have one that was pretty clean when I bought it for $125 on the local Craigslist here from the original owner. I believe it's a three main tubes butted tubing bike, and don't know what the stays and fork were made from.
It was always a little doggy to ride with the original wheels, but I liked the geometry and feel of it, so I took a chance and built new wheels for it that have better bead hooks to allow full inflation of a more modern high pressure tyre. I kept it at 27" wheels on instinct, using Sun rims. After that, it became a favorite rider, and I even put fenders on it.
The components are nothing fancy, but are very serviceable. I think it might have been an MTB group to get a larger gear range to fit with the light touring motif.
Likes For 3alarmer:
Quoted: 323 Post(s)
Liked 690 Times
That’s a nice one 3alamer! Not a blemish to be seen on the drive side. I believe the entire frame is 4130 Chromoly but only the top and down tubes are double butted. I could be mistaken but that’s the way it reads according to Schwinn.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Check component codes, I bet they are newer than 1977. Headbadge may have been a mistake.
Not lost wanderer.
Quoted: 885 Post(s)
Liked 992 Times
aka: Mike J.
I think I’ll just call it a model year 1977+6-or-so
bwilli88,
I will keep you in mind
bwilli88,
aka: Mike J.
I took a few minutes tonight and tried the 700c wheels with 700x28c tires off the Univega and tried them out on the Schwinn since both were 6-speeds on back. They fit and ran with the brakes just fine, or at least close enough to not be an issue. So I swapped the wheels back since the Sportour is currently up for sale, and put the Schwinn back on a hook until I have the time to give it some proper attention. Should be a fun project.
Quoted: 796 Post(s)
Liked 522 Times
Looks like the one on my 78 Moto GT, took me a while to wrap my head around the orientations for clockwise vs counter clock - kinda upside down and backwards, but its done a fine job of keeping the saddle clamped. Much easier to adjust and tighten/loosen off the bike imho.
