The Pugsley’s obsolescence
Jet Jockey
This is little more than a rant/lamentation about the obsolescence of my Pugsley.
Since Surly no longer makes Marge Lite or Rabbit Hole rims, future wheel builds are pretty much out of the question, should I either need or desire. (I currently swap mine between full fat and 29er configs.) It’s obvious that the parts-base for this bike is slowly going extinct.
4” is no longer adequate for width, apparently. Tires are getting harder to buy too.
The thing I like most about the Pugs is that I can use standard spaced MTB parts...particularly the Alfine 8. Maybe it’s time to sell it now though before it gets so obsolete that it can’t be sold.
How often do you need new rims?
Plenty of rims available in all kind of widths. No need for Surly stuff. I bet Surly just relabels the rims anyway.
Quoted: 5877 Post(s)
Liked 3,445 Times
Given that parts are still available for old French Pugs like my Peugeot PX 10, I reckon you'll be able to get parts for your new Pug for a few more years yet.
Quoted: 2236 Post(s)
Liked 1,313 Times
Jet Jockey
I did a cursory search for Marge Lites and Rabbit Holes. Came up pretty much empty, due to products being discontinued.
Given the unique offset of the Pugs, not just any old rim will do.
4” tires are getting pretty rare too. Not fat enough, apparently.
Liked 1,313 Times
The Pug currently comes with 4.3 Ednas and other brother Darryl's - symmetrical or offset 80mm, both of which are available:
https://surlybikes.com/parts/edna
https://surlybikes.com/parts/my_other_brother_darryl
If you're looking for only Surly parts, that may be true, but there are still many other choices out there that should fit your bike.
Jet Jockey
All of this may be true, but the fact that Surly itself is essentially no longer producing a lot of the parts that are pretty fundamental to this bike says that the writing is on the wall.
Good night...and good luck
I doubt Surly actually produced any part of it to begin with. It was all sourced from various manufacturers from all over the globe. "Surly" is just a part of a larger organization that resells stuff with their stickers on it.
Liked 1,313 Times
What writing? I linked to the current parts listed on their website above.
It's sorta like the idea that 26" mtb tires are obsolete. Maybe as a trend or in the magazine but you can still buy them everywhere.
I build wheels for a living. I still have 20+ Pugs-compatible rims on the shelf.
If you're really hard on rims you might eventually run out of options. But if you're *that* hard on rims you should probably think hard about technique, pressures, etc... since riding any bike that way is going to be expensive.
