Patch tube, Yes/No?
Patch tube, Yes/No?
Old 07-02-19, 02:39 PM
GlennR
On Your Left
GlennR's Avatar
Quoted: 3004 Post(s)
Liked 2,433 Times in 1,187 Posts
Patch tube, Yes/No?
So in the past few months i've had 3 slow leaks. Each time I put the old tube in a bucket of water to find the hole, check the tire and then install a new tube. So far all 3 are tiny holes most likely caused by a thorn.
Since I mostly ride solo and can get 30-40 miles from home at times, I've opted to always use a new tube. But at $10 per it's starting to get expensive.
I once went 18 months without a flat and am concerned of a patch failing over time.
GlennR is offline
Old 07-02-19, 02:41 PM
datlas
Should Be More Popular
datlas's Avatar
Quoted: 22579 Post(s)
Liked 8,919 Times in 4,153 Posts
Yes. Use permanent patches, not peel-off ones. Properly patched, it's as good as new.
I do suggest "batch patch" i.e. do a few at a time, for efficiency.
Originally Posted by rjones28
Addiction is all about class.
datlas is offline
Old 07-02-19, 02:44 PM
nomadmax
Quoted: 1104 Post(s)
Liked 1,824 Times in 878 Posts
I patch my tubes when I get home, reinstall it and pump it up. I buy a new tube after three patches. Not because I think they will fail (I've never had a patch fail) but because I'm a bit of a weight weenie when it comes to tires, tubes and wheels.
nomadmax is offline
Likes For nomadmax:
Old 07-02-19, 02:45 PM
GuitarBob
Kit doesn't match
GuitarBob's Avatar
Bikes: 5
Quoted: 187 Post(s)
Liked 27 Times in 19 Posts
For me, yes. Some of my tubes have 4 or 5 patches and they still work perfectly.
I live and ride in the land of thorns, so I flat all too regularly. I collect the tubes and patch them in a batch when I have about 10. After patching, I fill them up with air, and if they are still holding air in the morning, they get stashed for later use -- the ones that fail (maybe 5-10%) get binned. I've never had a good patch fail -- and it's pretty easy to tell if you got a good bond.
Plus it's pretty satisfying work.
GuitarBob is offline
Likes For GuitarBob:
Old 07-02-19, 02:46 PM
kcblair
Old Legs
kcblair's Avatar
Bikes: '80 Strayvaigin, '84 Ciocc Aelle-Shimano 105, '90 Concorde Astore /Campy Triple ,85 Bridgestone 500/Suntour, 2005 Jamis Quest, 2017 Raleigh Merit 1, Raleigh Carbon Clubman
Quoted: 302 Post(s)
Liked 33 Times in 22 Posts
I usually put a permanent patch on when I get home . Re-install in tire and if it holds over night, I leave it installed. Put good tube back into tool kit, for another use. KB.
kcblair is offline
Likes For kcblair:
Old 07-02-19, 02:53 PM
GlennR
On Your Left
GlennR's Avatar
Thanks guys, it give me the confidence to try patching them.
I have Zipp 303s and use the Zipp tubes with their valve extenders, they're $10 each so not cheap. My spare tube is a Bontrager with a 60mm threaded stem. The tube is bullet proof as i've used it and reused in more times than i can remember. The stem rattles a bit where the Zipp tubes do not... and the Zipp tube just looks better.
I'll have to stop by the LBS and get a permanent patch kit and give it a try.
Thanks again.
GlennR is offline
Old 07-02-19, 03:11 PM
GuitarBob
Kit doesn't match
GuitarBob's Avatar
Bikes: 5
Quoted: 187 Post(s)
A wrap or two of electrical tape at the base of the value should fix that right up.
Old 07-02-19, 03:18 PM
WhyFi
WhyFi's Avatar
Quoted: 20808 Post(s)
Liked 9,450 Times in 4,668 Posts
Off the subject - are you younger now? Or just faster?
WhyFi is offline
Old 07-02-19, 03:20 PM
GlennR
On Your Left
GlennR's Avatar
Don't really care since I replace it once I get home.
GlennR is offline
Old 07-02-19, 03:21 PM
GlennR
On Your Left
GlennR's Avatar
Yes.
GlennR is offline
Old 07-02-19, 03:34 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3870 Post(s)
Liked 2,563 Times in 1,577 Posts
Thanks again.
I use $16 tubes, so I'm definitely a fan of patching. Get the Rema patch kit, and when in doubt, wait a bit longer for the glue to dry before applying the patch. Good luck, Glenn!
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Likes For ThermionicScott:
Old 07-02-19, 03:43 PM
GlennR
On Your Left
GlennR's Avatar
Checked the LBS website and they carry them. also watch a video on using them and it seems pretty simple.
thanks
GlennR is offline
Old 07-02-19, 03:51 PM
mantis
Don't Bug Me
mantis's Avatar
Bikes: Canyon Aeroad CF SL 8.0 Disc, Cervelo S2, Look 585, Specialized Rockhopper
Quoted: 19 Post(s)
Liked 27 Times in 16 Posts
Yes, patch it. I can’t remember a patch problem and I have used Park peel back patches for years.
What I do is always carry a spare tube and if I have a flat on the road I install it. Once I get home I patch the leaky tube and reinstall it in the wheel and pump it up to my road pressure. This will really force the patch on the affected area. I then roll up the new tube I just removed, roll it up, and carry it as my spare again.
mantis is offline
Likes For mantis:
Old 07-02-19, 04:03 PM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 18883 Post(s)
Liked 10,646 Times in 6,054 Posts
You might also try putting sealant in your tubes of you keep getting slow leaks.
Seattle Forrest is offline
Old 07-02-19, 04:31 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4729 Post(s)
Liked 1,531 Times in 1,002 Posts
Curious.. so you'd always in the past spend the time with a bucket of water to find a leak, but then throw away the unpatched punctured tube anyway?
Sy Reene is offline
Old 07-02-19, 04:42 PM
GlennR
On Your Left
GlennR's Avatar
Not much time. I do it so I know where to look for what caused the puncture.
I still have the tubes.
GlennR is offline
Old 07-02-19, 04:52 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Ahh ok.. though a bit late to check for something in the tire, because you have already installed a new tube and then finished your ride, no?
Sy Reene is offline
Old 07-02-19, 04:59 PM
GlennR
On Your Left
GlennR's Avatar
Correct, I do check the tire before replacing the tube. But if I don't find the cause I like to know where to double check. I use a cotton ball since it will catch in the smallest imperfection.
GlennR is offline
Old 07-02-19, 05:12 PM
colnago62
Quoted: 741 Post(s)
Liked 412 Times in 230 Posts
I buy tubes in bulk at about $2.70 a tube. I generally don’t patch tubes
colnago62 is offline
Old 07-03-19, 05:13 AM
rubiksoval
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times in 711 Posts
^ Same. Never patch. I buy tubes on sale. Even my latex tubes are less than $7.00 a pop and my backup butyls were under $5 last time I got some. Certainly would never spend 10 bucks on a butyl tube.
The latex have the added benefit of having removable valve cores. I've been able to save quite a few of those with sealant.
rubiksoval is offline
Old 07-03-19, 05:56 AM
Jasper Storm
Quoted: 15 Post(s)
Liked 9 Times in 7 Posts
I always patch tubes.
I have a 100 pack of Rema patches, along with many tubes of cement in my tool box.
I had a winter training wheel tube that had 18 patches, many overlapping. I figured I was running Gatorskin tires anyways.
Also, I've patched every brand of latex tube that I've run, even the ultra-thin Vredesteins, using the same Rema patches and liquid cement.
Jasper Storm is offline
Likes For Jasper Storm:
Old 07-03-19, 06:02 AM
noimagination
Quoted: 365 Post(s)
Liked 418 Times in 247 Posts
When I read posts like this, I always wonder what people did when they were kids and their bike had a flat. My Dad certainly wasn't always around to patch a flat, he showed me (and brothers and sister) how to do it and when we had a flat, we patched it. We certainly didn't have the money to go buy tubes. If an 8 year old can apply a patch that holds, then I'm sure an adult can do it.
It also seems bad for the environment to just throw away tubes with a small hole that can easily be fixed. Simply wasteful.
noimagination is offline
Likes For noimagination:
Old 07-03-19, 06:08 AM
jon c.
Quoted: 1591 Post(s)
Liked 1,017 Times in 571 Posts
We always patched them as kids. As I recall we lit the patch on fire briefly on the theory that it helped the seal. I have no idea if it helped.
Now I'm too lazy and I just replace the tube.
jon c. is offline
Old 07-03-19, 06:40 AM
MoAlpha
Bikes: Shmikes
Quoted: 10152 Post(s)
Liked 5,843 Times in 3,147 Posts
When you do retire a tube, they make, without exception, the most secure lashing material in the universe. They are indispensable for securing objects to auto roof racks and I keep a couple on the boat in case of a rig failure. You can build a scrap lumber or bamboo hut with them when your place blows away in a hurricane.
MoAlpha is offline
Likes For MoAlpha:
Old 07-03-19, 07:18 AM
TakingMyTime
Bikes: Canyon Endurace
Quoted: 1041 Post(s)
Liked 922 Times in 539 Posts
Do you guys leave the cellophane on the outside of the patch or remove it before installation?
TakingMyTime is offline
