Cup and cone versus cartridge BB
Just curious on thoughts about switching to a sealed cartridge bottom bracket from my current cup and cone setup. I noticed some grit on my well worn setup the other day. I ended up pulling everything apart, cleaned, regreased and reinstalled. (Same bearings honestly, probably should have replaced while I was at it.) It's definitely smoother now, I guess I was questioning the adjustment part a little bit but I think I figured it out...
Still wondering if cartridge is the way to go though. Would it be worthwhile to swap it out? Any advantages or disadvantages? I was looking at either a Sunrace BBS 15 or a Shimano UN55 (68x118).
Thanks
Thanks
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Since you just rebuilt the bottom bracket, ask yourself if you really want to go through that every 6 months to a year versus not having to take it apart and put it back together ever? The choice is yours but I'd opt for not having to do anything to the bottom bracket for 10 to 15 to 20 years over rebuilding every year.
Stuart Black
Stuart Black
Half way there
Quoted: 986 Post(s)
Liked 880 Times
If your current BB is working for you, there is no compelling reason to switch. IMO, the only advantages for a cartridge are no adjustment and no maintenance.
If you do switch at some time, be aware that you may have spindle taper issues. The Sunrace and Shimano BBs have JIS tapers. Many cranks may not work with them.
I have over 40,000 miles on a Sugino cup and cone BB, which shows little signs of wear. I just replaced it this month with a UN55 cartridge, but only because I wanted to switch cranks. The newer, but still vintage, cranks did not work with the Sugino spindle.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
You are probably safe to assume JIS, though some of the older, higher end Japanese cranks used non-JIS tapers. What particular crank is on it?
The bike is nothing special at all honestly. I just happen to really like the frame dimensions, seems to fit me like a glove and I'm totally not worried about scratching it ;-).
Friendship is Magic
Bikes: old ones
Quoted: 26418 Post(s)
Liked 10,380 Times
...who rebuilds their cup and cone BB every year ? That's just OCD foolishness.
Friendship is Magic
Bikes: old ones
Liked 10,380 Times
Quoted: 1975 Post(s)
Liked 232 Times
Thanks
Thanks
I have both types and, if adjusted properly, there is no noticeable difference.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Have you found that servicing the current bottom bracket is an undue burden? If not, why bother replacing it? After all, you know that the current unit works with your crank and drivetrain. The SunRace and Shimano cartridges are decent, but not spectacular bottom brackets. When they do fail, you will replace the whole cartridge rather than simply cleaning it out and replacing the balls and grease. Seems kind of wasteful to me; I'm still using cup-and-cone bottom brackets that are several decades old and have only required service every 3 to 5 years. I could keep doing that for decades more before I'd reach the cost of even a mediocre cartridge.
Quoted: 6193 Post(s)
Liked 4,809 Times
Might be part of the advantage of the sealed cartridge bb's that you can't take them apart and see if there is grit in them.
Never took one apart myself, so maybe the seals actually work well. If you aren't a high mileage rider, then your old bb will probably last a long time grit or no grit.
Quoted: 5888 Post(s)
Liked 3,471 Times
have you found that servicing the current bottom bracket is an undue burden? If not, why bother replacing it? After all, you know that the current unit works with your crank and drivetrain. The sunrace and shimano cartridges are decent, but not spectacular bottom brackets. When they do fail, you will replace the whole cartridge rather than simply cleaning it out and replacing the balls and grease. Seems kind of wasteful to me; i'm still using cup-and-cone bottom brackets that are several decades old and have only required service every 3 to 5 years. I could keep doing that for decades more before i'd reach the cost of even a mediocre cartridge.
Oh, the drama. Most of my bikes use square taper cup and cone. I ride in all conditions year round in the rainy Pac NW.
Unless someone is regularly submerging their bikes in salt water for some reason, 5 years is a reasonable overhaul interval. It takes me 30 minutes, which is only a little longer than replacing the entire unit with something new.
As far as economics, the spindle wears first (pitting), followed by the balls and the cups. It takes an immense amount of abuse and neglect to kill the cups. I can get new replacement spindles at my local Coop for $5 each. We have a 30 pound bin of spindles stamped: Campagnolo, Dura-Ace, Stronglight, TA, etc. I'm not worried about running out of replacement cup and cone BB parts.
Likes For Dave Mayer:
The Shimano UN** bottom brackets are an answer to a commuters problems. On my commute bike the BB had to be overhauled every month to keep it running in winter months, and probably should have been done every week. Same with the hubs. Snow, salt, grit carried by the snow all got into the hubs and bottom bracket. No way around it. Even with this high level of maintenance the BB had to be replaced every season after the winter commute months.
Along came the UN52 and I have yet to service it. Going on 30 years with the same Shimano UN52 bottom bracket. Works flawlessly. Every bike I have a UN** BB in, I have had zero maintenance and zero failures. Cannot claim the same for traditional cup and cone with the exception of the Campagnolo Nuovo Record bottom bracket used on my race bikes, but then again, I serviced the hubs and BB every other week!
Liked 4,218 Times
It depends. Do you ride in wet conditions? Dirty conditions? Is the bottom bracket one with rubber seals or one without? All of those are going to have an impact on how long you can go between rebuilds. I’d say that 1500 miles is somewhat close to the max.
Stuart Black
Stuart Black
Liked 4,218 Times
On the other hand, I see lots and lots and lots of loose bearing bottom brackets that have to be replaced. Even a number of very new ones.
Stuart Black
Stuart Black
Take your cup and cone BB and throw it in the trash, replace it with a cartridge type. Don't look back. If it ever gets loose, or gritty, or not smooth, just replace it.
ANY cup and cone will wear out well before a cartridge.
Liked 4,218 Times
Bad bartridge bearing bottom brackets show up only a few times per year. They are so rare, in fact, that it's something to take note of.
I've had no end of wear issues with bottom brackets back before cartridge bearing bottom brackets. In the early days of mountain biking, I had to replace the bottom bracket very often and had to rebuild on a roughly 6 month schedule. Modern bikes...new ones from HelMart...that have loose bearing bottom brackets are a total waste of time and effort. The bearings wear to dust in about 200 miles. I see hemispherical bearings in those on a regular basis. The "steel" (SLO? steel like object) that is used for the cups is often so poorly constructed that the cup pulls apart as it's being extracted. I've had to tell several people that their bike is irreparable because the bottom bracket has started to separate and we can't get the cup out of the frame.
Nope. Got no love for loose bearing bottom brackets.
Stuart Black
Stuart Black
Friendship is Magic
Bikes: old ones
Liked 10,380 Times
How? I see bottom brackets at my local co-op that are from the 90s that are still working well. I’ve personally never had a sealed bottom bracket fail on me. I’ve replaced a lot of them through upgrades but not one of them has been because the BB failed.
Friendship is Magic
Bikes: old ones
Liked 10,380 Times
I've never had a problem with any cartridge bearing bottom bracket and seldom see a bad one at my local co-op. I see roughly 1500 bikes a year with all kinds of problems.
Friendship is Magic
Bikes: old ones
Liked 10,380 Times
I certainly use sealed units. They're nice because they simplify swapping out crank spindles....all you need to worry about is length, spindle taper, and threading in selecting the new one. I love them for that reason alone. But you're wrong on the average user's requirements in terms of service intervals on an older cup and cone unit, and you have some mistaken notions about the range of quality available and failure rates in sealed units. (Based on my own experience...which is not insignificant.)
