Dyno wiring question
Quoted: 455 Post(s)
Liked 112 Times
I need to reattach the wire for my system. On the downtube I used electrical tape but that is not holding up.
Any suggestions would be great!
Jedi Master
I run the wires along with the cables and use heat-shrink to attach it to the outers and small o-rings to attach it to the inners. I use hvac tape to stick the wires to the inside of the fender.
Likes For kingston:
Randomhead
Liked 3,698 Times
I use gorilla repair tape. Others use helicopter tape. A high quality electrical tape (3M) should work fine, but you probably have to go all the way around the tube.
on my most recent wiring job, I only used zip ties. I went through the head lug and out the back of the bb shell for the DT wire. Not sure I would do that with a welded bike, but for lugged it made sense
Quoted: 455 Post(s)
Liked 112 Times
I thought it was 3M. I have been running the tape length wise down the underside of the down tube. It seems like Gorilla tape,clear, is only available in 1.88" width.
Randomhead
Liked 3,698 Times
yes, I trim the gorilla tape to the width I need. Also required are sharp scissors and latex gloves. No electrical tape is going to work in the long direction, you have to wrap it around the tube. Not sure that the repair tape will work that way either, but it's considerably less visible. But it's definitely stickier, so if you want to go lengthwise, it might be worth a try. You probably need to go wider than the width of electrical tape to get it to work. Electrical tape isn't that visible if your bike is a dark color.
Quoted: 2604 Post(s)
Liked 1,933 Times
It's not pretty, but zip ties work well.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Either zip tie it to the rest of your cables or take the plunge and run it inside your frame for that really clean look.
Bikes: 1 x carbon Domane (broken after a minor fall); 1 x custom steel (unbroken after being doored at 30 kmh)!
Quoted: 5 Post(s)
Amalgamating / self welding tape is useful for wrapping around tubes or cable housing.
