Garmin 520-cannot upload to Garmin Connect
Old 09-08-19, 11:51 AM
lennyparis
lennyparis's Avatar
Bikes: 2017 Tarmac Pro, 2014 S-Works Tarmac, 2011 Trek Madone 6.2, 2014 Trek Madone 5.9 & 2009 Specialized Hardtail
Quoted: 28 Post(s)
will not upload wirelessly and when plug in Garmin Connect says cannot import this type of data file
Hope file is not corrupt
I attached the file below in case anyone has a thought on how to fix this. Thanks
https://www.dropbox.com/s/ssivqwh2ds...05-50.fit?dl=0
lennyparis is offline
Old 09-08-19, 12:02 PM
gregf83
Quoted: 1186 Post(s)
Liked 289 Times in 177 Posts
File looks fine. It loads into Golden Cheetah without any problems.
Edit: but it doesn't load into Garmin Connect for some reason. Is that your ultimate destination for the file or are you trying to load to Strava or some other site?
I exported from Golden Cheetah to a fit file which loads correctly into Garmin Connect. Try this file: https://www.dropbox.com/s/2tn0me4znt..._ride.fit?dl=0
gregf83 is offline
Likes For gregf83:
Old 09-09-19, 01:41 PM
FlashBazbo
Chases Dogs for Sport
FlashBazbo's Avatar
Quoted: 983 Post(s)
Liked 141 Times in 94 Posts
Contact Garmin. They can and will help.
Are you trying to upload via WiFi or Bluetooth? Garmin doesn't like doing both at the same time. If you want to go Bluetooth to your phone, be sure to pull up the Connect app before syncing. (No, you shouldn't have to, but you do.)
FlashBazbo is offline
bgrider
Road Cycling
4
07-17-19 02:43 PM
sprocket52
5
02-20-19 04:29 AM
sdmc530
General Cycling Discussion
1
04-03-17 06:31 PM
dustind2103
Road Cycling
21
11-17-16 04:17 PM
TrojanHorse
Road Cycling
7
05-28-12 09:52 AM
